1 Reply Latest reply on Sep 29, 2016 8:39 AM by Peter Spier
    Where are my colors going?
    masonhamrick
      I have a document with the page color set to a shade of grey. When I export to .pdf everything is showing up white. What's the fix?
        • 1. Re: Where are my colors going?
          The [Paper] swatch is a visual aid and does not print. You can edit it to help you see what your layout will look like on colored stock, but it doesn't add the color to the paper.
          If you need a gray background, add a gray filled frame as a background in the file. Best to put it on its own locked layer at the back, and don't forget to let it bleed.
