7 Replies Latest reply on Sep 30, 2016 6:09 AM by BarbBinder
    Tried several options. But InDesign fails to create pdf everytime. Please help!
    karanpreets59069165 Level 1
      Hello! Team Adobe,
      I am not sure why is this happening all of a sudden. But, when I export an InDesign file to PDF (High Quality), it gives me an error and does not create a complete PDF. In short, the elements go missing.
      I am using:
      • Mac OS Sierra 10.12 (16A323)
      • Adobe InDesign CC 2015
      When I or my client open the PDF, we get the following error, regardless of any computer we use:
      An error exists on this page. Acrobat may not display the page correctly. Please contact the person who created the PDF document to correct the problem.
      Also,  I tried the same with a new blank file: A4, print. Still the same issue.
      Below is the report I saved while preparing the PDF in InDesign:
          1) The preset specifies source profiles that don't match the current colour settings file. Profiles specified by the colour settings file will be used.
          Use these settings to create Adobe PDF documents for quality printing on desktop printers and proofers.  Created PDF documents can be opened with Acrobat and Adobe Reader 5.0 and later.
      PDF Preset: [High Quality Print]
      Compatibility: Acrobat 5 (PDF 1.4)
      Standards Compliance: None
          Pages: All
          Spreads: Off
          View: Default
          Layout: Default
          Full Screen: Off
          Generate Thumbnails: Off
          Optimise PDF: On
          Create Acrobat Layers: N/A
          Export Layers: Visible and Printable Layers
          Include Bookmarks: Off
          Include Hyperlinks: Off
          Export Nonprinting Objects: Off
          Export Visible Guides and Baseline Grids: Off
          Create Tagged PDF: On
          Interactive Elements: Do Not Include
          Colour Images
              Bicubic Downsample at: 300 ppi
              for images above: 450 ppi
              Compression: Automatic
              Tile Size: N/A
              Quality: Maximum
          Greyscale Images
              Tile Size: N/A
              Quality: Maximum
          Monochrome Images
              Bicubic Downsample at: 1200 ppi
              for images above: 1800 ppi
              Compression: CCITT Group 4
          Compress Text and Line Art: On
          Crop Image Data to Frames: On
      Marks and Bleeds
          Crop Marks: Off
          Bleed Marks: Off
          Registration Marks: Off
          Colour Bars: Off
          Page Information: Off
          Page Mark Type: Default
          Weight: 0.25 pt
          Offset: 2.117 mm
          Use Document Bleed Settings: Off
          Bleed Top: 0 mm
          Bleed Bottom: 0 mm
          Bleed Left: 0 mm
          Bleed Right: 0 mm
          Include Slug Area: Off
          Colour Conversion: No Colour Conversion
          Destination: N/A
          Profile Inclusion Policy: Include Tagged Source Profiles
          Simulate Overprint: N/A
          Output Intent Profile Name: N/A
          Output Condition: N/A
          Output Condition Identifier: N/A
          Registry Name: N/A
          Subset Fonts Below: 100%
          Omit PDF: Off
          Omit EPS: Off
          Omit Bitmap Images: Off
          Transparency Flattener Preset: N/A
          Ignore Spread Overrides: N/A
          Display Title: File Name
          Language: English: UK
      Please help!
      Thank you.
