2 Replies Latest reply on Sep 30, 2016 12:53 AM by easypay_mdb
    Automaticly Jump to part inside a topic using Map-id
    easypay_mdb Level 1
      When you use following code you can open a page xxx.htm and jump directly to a part of the screen. This by setting an id-name behind the #-sign.
      window.open("http://servername/xxxx.htm#idlink", "_blank", "toolbar=no,scrollbars=yes,resizable=yes,top=100,left=500,width=700,height=400");
      I use Robohelp versie 2015. I link a word-document to a project of Robohelp.
      When attempting to create a map-id (.h-file), you see in the right pane items such as
      xxxx
      xxxx#yyyy
      I assumed that xxxx#yyyy opens the topic xxxx and jumps into the topic to the item yyyy. (according to the html-code above).
      When I use the view-button, xxxx and xxxx#yyyy, the result is the same. The topic xxxx opens at the first line.
      I assing the following in the map-id (left pane)
      Map ID        Map #         Topic
      imgxx          1000            xxxx#yyyy
      By using the script RoboHelp_CSH.js, you can call the function RH_ShowHelp.
      <a href='javascript:RH_ShowHelp(0, http://servername/xxxx.htm>largeWindow", HH_HELP_CONTEXT, 1000)'><img id="imgxx" name="imgxx" align="absMiddle" SRC="blue_question.png" height="10"></a>
      I open a frameset starting from the page index.htm, which opens the page xxxx.htm at the right screen.
      Is it possible to jump to a part of the page xxxx.htm by using the function RH_ShowHelp, just like the way I open a page directly (see window.open(...) above )?
      When you selectively can jump to a specific part, the advantage is, that you can scroll directly to another part without using the TOC.
