2 Replies Latest reply on Sep 30, 2016 11:10 PM by Willi Adelberger
    Changing Colors
    capovilla
      I am using Indesign CC2014 and I am having problems with colors.
      I have a picture that out of Indesing it is Lime Green, but when I place it on Indesing, it is not that bright...
      Does anyone know why is it happening?
      Thank you
      How it shows:
      How it should be:
        • 1. Re: Changing Colors
          If there's any transparent object on the page and your Transparency Blend Space is set to CMYK or, if you have Overprint/Separation Preview turned on, the green will preview as it would convert to CMYK. For an all RGB preview set your blend space to RGB and turn off Overprint Preview.
          • 2. Re: Changing Colors
            Your image seems to be in an RGB space.
            Your document settings are probably set up for CMYK output for print.
            RGB and CYMK have different gamuts, that is the color spectrum which can be technically reproduced. In the greens and pink spectrum, the CMYK gamuts are much smaller than the RGB can do. So you will always get a different color if you try to print these lightning colors.
            You can choose a different intent when converting the colors (to choose in the import options in the place image dialog) but differences will remain.
            You have to live with it, either change your design or use a spot color which will increase costs.
