1 Reply Latest reply on Feb 21, 2009 10:07 AM by butimawizard
    help: symbol shifting between mac and windows, flash cs3
    butimawizard
      I'm doing work reviewing flash files created by other users on mac and windows. I'm using os x 10.5.6. When I open a file created in windows / flash cs3 some symbols on the stage will have shifted upwards on the y axis. If I correct the shift and then send it back to the windows user they see the symbols incorrectly aligned, as if I had moved symbols around on a correctly aligned file.
      The strange thing is not everything on the stage is shifted. Only particular symbols will move, and it's usually symbols only (not text frames, drawing objects, etc).
      I believe there's a general history of bad behavior when saving flash files and trading them back and forth between mac and windows, but does anyone know what may be causing this? Or a remedy?
      Thank you in advance.
      Peter
