3 Replies Latest reply on Oct 2, 2016 2:35 PM by cameronh333
    Can't open my puppet in scene says "OpenGL Setup failed"
    cameronh333
      Renderer: Intel(R) HD Graphics 3000
      Vendor: Intel
      Memory: 2108 MB
      Version: 3.1.0 - Build 9.17.10.4229
      Shading language version: 1.40 - Intel Build 9.17.10.4229
      Max texture size: 8192 x 8192
      Max vertex texture image units: 16
      Max texture image units: 16
      Max geometry texture units: 0
      Max anisotropic filtering value: 16
      Max viewport size: 8192 x 8192
      Max Clip Distances: 6
      Max samples: 4
      Extensions: 129
      GL_3DFX_texture_compression_FXT1
      GL_ARB_color_buffer_float
      GL_ARB_compatibility
      GL_ARB_copy_buffer
      GL_ARB_depth_buffer_float
      GL_ARB_depth_clamp
      GL_ARB_depth_texture
      GL_ARB_draw_buffers
      GL_ARB_draw_buffers_blend
      GL_ARB_draw_elements_base_vertex
      GL_ARB_draw_instanced
      GL_ARB_explicit_attrib_location
      GL_ARB_fragment_coord_conventions
      GL_ARB_fragment_program
      GL_ARB_fragment_program_shadow
      GL_ARB_fragment_shader
      GL_ARB_framebuffer_object
      GL_ARB_framebuffer_sRGB
      GL_ARB_half_float_pixel
      GL_ARB_half_float_vertex
      GL_ARB_instanced_arrays
      GL_ARB_map_buffer_range
      GL_ARB_multisample
      GL_ARB_multitexture
      GL_ARB_occlusion_query
      GL_ARB_occlusion_query2
      GL_ARB_pixel_buffer_object
      GL_ARB_point_parameters
      GL_ARB_point_sprite
      GL_ARB_provoking_vertex
      GL_ARB_sampler_objects
      GL_ARB_seamless_cube_map
      GL_ARB_shader_bit_encoding
      GL_ARB_shader_objects
      GL_ARB_shading_language_100
      GL_ARB_shadow
      GL_ARB_sync
      GL_ARB_texture_border_clamp
      GL_ARB_texture_buffer_object_rgb32
      GL_ARB_texture_compression
      GL_ARB_texture_compression_rgtc
      GL_ARB_texture_cube_map
      GL_ARB_texture_env_add
      GL_ARB_texture_env_combine
      GL_ARB_texture_env_crossbar
      GL_ARB_texture_env_dot3
      GL_ARB_texture_float
      GL_ARB_texture_non_power_of_two
      GL_ARB_texture_query_lod
      GL_ARB_texture_rectangle
      GL_ARB_texture_rg
      GL_ARB_texture_rgb10_a2ui
      GL_ARB_timer_query
      GL_ARB_transpose_matrix
      GL_ARB_uniform_buffer_object
      GL_ARB_vertex_array_bgra
      GL_ARB_vertex_array_object
      GL_ARB_vertex_buffer_object
      GL_ARB_vertex_program
      GL_ARB_vertex_shader
      GL_ARB_vertex_type_2_10_10_10_rev
      GL_ARB_window_pos
      GL_ATI_separate_stencil
      GL_EXT_abgr
      GL_EXT_bgra
      GL_EXT_blend_color
      GL_EXT_blend_equation_separate
      GL_EXT_blend_func_separate
      GL_EXT_blend_minmax
      GL_EXT_blend_subtract
      GL_EXT_clip_volume_hint
      GL_EXT_compiled_vertex_array
      GL_EXT_draw_buffers2
      GL_EXT_draw_range_elements
      GL_EXT_fog_coord
      GL_EXT_framebuffer_blit
      GL_EXT_framebuffer_multisample
      GL_EXT_framebuffer_object
      GL_EXT_gpu_program_parameters
      GL_EXT_multi_draw_arrays
      GL_EXT_packed_depth_stencil
      GL_EXT_packed_float
      GL_EXT_packed_pixels
      GL_EXT_rescale_normal
      GL_EXT_secondary_color
      GL_EXT_separate_specular_color
      GL_EXT_shadow_funcs
      GL_EXT_stencil_two_side
      GL_EXT_stencil_wrap
      GL_EXT_texture3D
      GL_EXT_texture_array
      GL_EXT_texture_compression_s3tc
      GL_EXT_texture_edge_clamp
      GL_EXT_texture_env_add
      GL_EXT_texture_env_combine
      GL_EXT_texture_filter_anisotropic
      GL_EXT_texture_integer
      GL_EXT_texture_lod_bias
      GL_EXT_texture_rectangle
      GL_EXT_texture_shared_exponent
      GL_EXT_texture_snorm
      GL_EXT_texture_sRGB
      GL_EXT_texture_swizzle
      GL_EXT_transform_feedback
      GL_IBM_texture_mirrored_repeat
      GL_INTEL_map_texture
      GL_INTEL_performance_queries
      GL_NV_blend_square
      GL_NV_conditional_render
      GL_NV_primitive_restart
      GL_NV_texgen_reflection
      GL_SGIS_generate_mipmap
      GL_SGIS_texture_edge_clamp
      GL_SGIS_texture_lod
      GL_WIN_swap_hint
      WGL_ARB_buffer_region
      WGL_ARB_create_context
      WGL_ARB_extensions_string
      WGL_ARB_framebuffer_sRGB
      WGL_ARB_make_current_read
      WGL_ARB_multisample
      WGL_ARB_pbuffer
      WGL_ARB_pixel_format
      WGL_ARB_pixel_format_float
      WGL_EXT_depth_float
      WGL_EXT_extensions_string
      WGL_EXT_pixel_format_packed_float
      WGL_EXT_swap_control
      WGL_EXT_swap_control_tear
      Core features
      v3.0 (100 % - 23/23)
      v3.1 (100 % - 8/8)
      v3.2 (70 % - 7/10)
      v3.3 (70 % - 7/10)
      v4.0 (21 % - 3/14)
      v4.1 (0 % - 0/7)
      v4.2 (0 % - 0/13)
      v4.3 (0 % - 0/23)
      v4.4 (0 % - 0/10)
      v4.5 (0 % - 0/11)
      vARB 2015 (0 % - 0/13)
      OpenGL driver version check (Current: 3.1.0 - Build 9.17.10.4229, Latest known: 9.17.10.4229):
      Outdated version of display drivers detected
      According the database, you are might be not using the latest version of display drivers for your video card.
      No ICD registry entry
      The current OpenGL driver doesn't expose the SOFTWARE/Microsoft/Windows (NT)/CurrentVersion/OpenGLDrivers registry entry. Unable to detect the driver version, driver revision name and filename.
      Extension verification:
      GL_EXT_color_subtable was not found, but has the entry point glColorSubTableEXT
      GL_EXT_paletted_texture was not found, but has the entry point glColorTableEXT
      GL_EXT_paletted_texture was not found, but has the entry point glGetColorTableEXT
      GL_EXT_paletted_texture was not found, but has the entry point glGetColorTableParameterfvEXT
      GL_EXT_paletted_texture was not found, but has the entry point glGetColorTableParameterivEXT
