1 Reply Latest reply on Oct 2, 2016 11:33 PM by David Asch
    How to make this error message disappear?
    fotimex
      ﷯2 Warnings
      Web Widget 'Video Backgrounds' on page 'Home' is still using the default value of ' ' for 'Video File (.webm)' option. Use the Widget Option UI to change this to something appropriate for your website.
      Web Widget 'Video Backgrounds' on page 'Home' is still using the default value of ' ' for 'Pattern Overlay' option. Use the Widget Option UI to change this to something appropriate for your website.
      I can not figure out where to change the setting in the widget, any suggestions?
      Thank you,
        • 1. Re: How to make this error message disappear?
          David Asch Adobe Community Professional
          It's difficult to answer this without knowing exactly which widget you're using. The message is telling you that two of the widget's required options have not been set. It sounds like it needs a secondary video source in .webm format and also an overlay file, probably an image. There should be areas in the widget options to choose these files.
          I hope this helps.
          David
          Creative Muse
