6 Replies Latest reply on Oct 7, 2016 12:39 AM by advancityd26979134
    Phonegap iOS build issues
    advancityd26979134
      Hi everyone,
      I have some issues.
      Sometimes this issues
      Error - The following core plugin is causing the build to fail and may need to be updated to a newer version: dialogs
      And sometimes this.
      Error - The following 3rd-party plugin is causing the build to fail and may need to be updated to a newer version: com.phonegap.plugins.PushPlugin
      What should I do?
      my config file
        <gap:plugin name="org.apache.cordova.device" spec="0.3.0" />
          <gap:plugin name="org.apache.cordova.device-motion" spec="0.2.11"/>
          <gap:plugin name="org.apache.cordova.device-orientation" spec="0.3.11" />
          <gap:plugin name="org.apache.cordova.inappbrowser" source="npm" spec="1.5.0"/>
          <gap:plugin name="org.apache.cordova.network-information" spec="0.2.15" />
          <gap:plugin name="org.apache.cordova.splashscreen" spec="1.0.0" />
          <gap:plugin name="org.apache.cordova.console" spec="0.2.13" /> <!-- required -->
          <gap:plugin name="org.apache.cordova.geolocation" spec="0.3.12" /> <!-- needed only if you use geolocalization -->
          <gap:plugin name="org.apache.cordova.dialogs" spec="0.3.0" /> <!-- required -->
        <gap:plugin name="com.phonegap.plugins.pushplugin" spec="2.5.0" /> <!-- required -->
