2 Replies Latest reply on Oct 4, 2016 3:08 PM by marciot
    IPHONEOS_DEPLOYMENT_TARGET error
    marciot
      Hello,
      I am having some troubles compiling an app (app id 2290446)  after I added a plugin (cordova-plugin-iosrtc). The error message is the following:
      The provisioning profile "iOS Team Provisioning Profile: com.marciot.MazeWar-VR" is expiring soon
      Swift is unavailable on iOS earlier than 7.0; please set IPHONEOS_DEPLOYMENT_TARGET to 7.0 or later (currently it is '6.0').
      But if I scroll up in the logs I see that the correct variable is being exported:
      Libtool build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/libCordova. a normal arm64
        cd /project/CordovaLib
        export IPHONEOS_DEPLOYMENT_TARGET=7.0
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/li btool -static -arch_only arm64 -syslibroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -L/project/build -filelist /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/Cordova.LinkFileList -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/libCordova.a
      So I believe something else might be amiss.
      Any help would be appreciated. Thank you. Logs are attached.
      -- Marcio
      Build Date: 2016-10-04 09:47:49 -0700
      PLUGIN OUTPUT
      Fetching plugin "cordova-plugin-iosrtc@~3" via npm
      Installing "cordova-plugin-iosrtc" at "3.1.0" for ios
      cordova-plugin-iosrtc enables use of the JavaScript WebRTC APIs (as defined by the W3C) in iOS devices.
      Learn more at https://github.com/eface2face/cordova-plugin-iosrtc
      Fetching plugin "cordova-plugin-battery-status@~1.1.1" via npm
      Installing "cordova-plugin-battery-status" at "1.1.2" for ios
      Fetching plugin "cordova-plugin-camera@~2.1.1" via npm
      Installing "cordova-plugin-camera" at "2.1.1" for ios
      Fetching plugin "cordova-plugin-media-capture@~1.2.0" via npm
      Installing "cordova-plugin-media-capture" at "1.2.0" for ios
      Fetching plugin "cordova-plugin-file" via npm
      Installing "cordova-plugin-file" at "4.3.0" for ios
      Fetching plugin "cordova-plugin-compat" via npm
      Installing "cordova-plugin-compat" at "1.0.0" for ios
      The Android Persistent storage location now defaults to "Internal". Please check this plugins README to see if you application needs any changes in its config.xml.
      If this is a new application no changes are required.
      If this is an update to an existing application that did not specify an "AndroidPersistentFileLocation" you may need to add:
        "<preference name="AndroidPersistentFileLocation" value="Compatibility" />"
      to config.xml in order for the application to find previously stored files.
      Fetching plugin "cordova-plugin-console@~1.0.2" via npm
      Installing "cordova-plugin-console" at "1.0.4" for ios
      Fetching plugin "cordova-plugin-contacts@~2.0.1" via npm
      Installing "cordova-plugin-contacts" at "2.0.1" for ios
      Fetching plugin "cordova-plugin-device@~1.1.1" via npm
      Installing "cordova-plugin-device" at "1.1.3" for ios
      Fetching plugin "cordova-plugin-device-motion@~1.2.0" via npm
      Installing "cordova-plugin-device-motion" at "1.2.2" for ios
      Fetching plugin "cordova-plugin-device-orientation@~1.0.2" via npm
      Installing "cordova-plugin-device-orientation" at "1.0.4" for ios
      Fetching plugin "cordova-plugin-dialogs@~1.2.0" via npm
      Installing "cordova-plugin-dialogs" at "1.2.1" for ios
      Plugin "cordova-plugin-file" already installed on ios. Making it top-level.
      Fetching plugin "cordova-plugin-file-transfer@~1.5.0" via npm
      Installing "cordova-plugin-file-transfer" at "1.5.1" for ios
      Dependent plugin "cordova-plugin-file" already installed on ios.
      Fetching plugin "cordova-plugin-geolocation@~2.1.0" via npm
      Installing "cordova-plugin-geolocation" at "2.1.0" for ios
      Fetching plugin "cordova-plugin-globalization@~1.0.3" via npm
      Installing "cordova-plugin-globalization" at "1.0.4" for ios
      Fetching plugin "cordova-plugin-inappbrowser@~1.3.0" via npm
      Installing "cordova-plugin-inappbrowser" at "1.3.0" for ios
      Fetching plugin "cordova-plugin-media@~2.2.0" via npm
      Installing "cordova-plugin-media" at "2.2.0" for ios
      Fetching plugin "cordova-plugin-network-information@~1.2.0" via npm
      Installing "cordova-plugin-network-information" at "1.2.1" for ios
      Fetching plugin "cordova-plugin-splashscreen@~3.2.1" via npm
      Installing "cordova-plugin-splashscreen" at "3.2.2" for ios
      Fetching plugin "cordova-plugin-statusbar@~2.1.2" via npm
      Installing "cordova-plugin-statusbar" at "2.1.3" for ios
      Fetching plugin "cordova-plugin-vibration@~2.1.0" via npm
      Installing "cordova-plugin-vibration" at "2.1.2" for ios
      Fetching plugin "cordova-plugin-whitelist@~1.2.1" via npm
      Installing "cordova-plugin-whitelist" at "1.2.2" for ios
      Build settings from command line:
        ARCHS = armv7 arm64
        CONFIGURATION_BUILD_DIR = /project/build
        CORDOVALIB = /project/CordovaLib
        EMBEDDED_CONTENT_CONTAINS_SWIFT = YES
        ENABLE_BITCODE = false
        LD_RUNPATH_SEARCH_PATHS = @executable_path/Frameworks
        ONLY_ACTIVE_ARCH = NO
        OTHER_CODE_SIGN_FLAGS = --keychain /secure.keychain
        PROVISIONING_PROFILE = e4ebf862-4825-482a-ba4c-487dbdd9df57
      === BUILD TARGET CordovaLib OF PROJECT CordovaLib WITH THE DEFAULT CONFIGURATION (Release) ===
      Check dependencies
      Not running swift-stdlib-tool: EMBEDDED_CONTENT_CONTAINS_SWIFT is enabled, but the product type 'Static Library' is not a wrapper type.
      Write auxiliary files
      write-file /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own- target-headers.hmap
      write-file /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap
      /bin/mkdir -p /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64
      write-file /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/Cordova.LinkFileList
      write-file /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova.hmap
      /bin/mkdir -p /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr
      write-file /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch.pch.hash-criteria
      /bin/mkdir -p /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey
      write-file /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch.pch.hash-criteria
      /bin/mkdir -p /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7
      write-file /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/Cordova.LinkFileList
      write-file /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all- target-headers.hmap
      write-file /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all- non-framework-target-headers.hmap
      write-file /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap
      CpHeader Classes/Public/CDVWebViewEngineProtocol.h /project/build/include/Cordova/CDVWebViewEngineProtocol.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVWebViewEngineProtocol.h /project/build/include/Cordova
      CpHeader Classes/Public/CDVScreenOrientationDelegate.h /project/build/include/Cordova/CDVScreenOrientationDelegate.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVScreenOrientationDelegate.h /project/build/include/Cordova
      CpHeader Classes/Public/CDV.h /project/build/include/Cordova/CDV.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDV.h /project/build/include/Cordova
      CpHeader Classes/Public/CDVCommandDelegateImpl.h /project/build/include/Cordova/CDVCommandDelegateImpl.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVCommandDelegateImpl.h /project/build/include/Cordova
      CpHeader Classes/Public/CDVCommandQueue.h /project/build/include/Cordova/CDVCommandQueue.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVCommandQueue.h /project/build/include/Cordova
      CpHeader Classes/Public/CDVWhitelist.h /project/build/include/Cordova/CDVWhitelist.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVWhitelist.h /project/build/include/Cordova
      CpHeader Classes/Public/CDVAppDelegate.h /project/build/include/Cordova/CDVAppDelegate.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVAppDelegate.h /project/build/include/Cordova
      CpHeader Classes/Public/CDVPlugin+Resources.h /project/build/include/Cordova/CDVPlugin+Resources.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVPlugin+Resources.h /project/build/include/Cordova
      CpHeader Classes/Public/CDVAvailability.h /project/build/include/Cordova/CDVAvailability.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVAvailability.h /project/build/include/Cordova
      CpHeader Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.h /project/build/include/Cordova/CDVUIWebViewDelegate.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.h /project/build/include/Cordova
      CpHeader Classes/Public/NSMutableArray+QueueAdditions.h /project/build/include/Cordova/NSMutableArray+QueueAdditions.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/NSMutableArray+QueueAdditions.h /project/build/include/Cordova
      CpHeader Classes/Public/CDVInvokedUrlCommand.h /project/build/include/Cordova/CDVInvokedUrlCommand.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVInvokedUrlCommand.h /project/build/include/Cordova
      CpHeader Classes/Public/CDVPluginResult.h /project/build/include/Cordova/CDVPluginResult.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVPluginResult.h /project/build/include/Cordova
      CpHeader Classes/Public/NSDictionary+CordovaPreferences.h /project/build/include/Cordova/NSDictionary+CordovaPreferences.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/NSDictionary+CordovaPreferences.h /project/build/include/Cordova
      CpHeader Classes/Public/CDVPlugin.h /project/build/include/Cordova/CDVPlugin.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVPlugin.h /project/build/include/Cordova
      CpHeader Classes/Public/CDVURLProtocol.h /project/build/include/Cordova/CDVURLProtocol.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVURLProtocol.h /project/build/include/Cordova
      CpHeader Classes/Public/CDVCommandDelegate.h /project/build/include/Cordova/CDVCommandDelegate.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVCommandDelegate.h /project/build/include/Cordova
      CpHeader Classes/Public/CDVAvailabilityDeprecated.h /project/build/include/Cordova/CDVAvailabilityDeprecated.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVAvailabilityDeprecated.h /project/build/include/Cordova
      CpHeader Classes/Public/CDVUserAgentUtil.h /project/build/include/Cordova/CDVUserAgentUtil.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVUserAgentUtil.h /project/build/include/Cordova
      CpHeader Classes/Public/CDVTimer.h /project/build/include/Cordova/CDVTimer.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVTimer.h /project/build/include/Cordova
      CpHeader Classes/Public/CDVConfigParser.h /project/build/include/Cordova/CDVConfigParser.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVConfigParser.h /project/build/include/Cordova
      CpHeader Classes/Public/CDVViewController.h /project/build/include/Cordova/CDVViewController.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/st rip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVViewController.h /project/build/include/Cordova
      ProcessPCH /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch.pch CordovaLib_Prefix.pch normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        export LANG=en_US.US-ASCII
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c-header -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/armv7 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -MD -MT dependencies -MF /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch.d -c /project/CordovaLib/CordovaLib_Prefix.pch -o /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch.pch --serialize-diagnostics /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch.dia
      ProcessPCH /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch.pch CordovaLib_Prefix.pch normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c-header -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/arm64 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -MD -MT dependencies -MF /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch.d -c /project/CordovaLib/CordovaLib_Prefix.pch -o /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch.pch --serialize-diagnostics /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch.dia
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewCont roller.o Classes/Public/CDVViewController.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/armv7 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVViewController.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVViewController.dia -c /project/CordovaLib/Classes/Public/CDVViewController.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVViewController.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionar y+CordovaPreferences.o Classes/Public/NSDictionary+CordovaPreferences.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/armv7 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/NSDictionary+CordovaPreferences.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/NSDictionary+CordovaPreferences.dia -c /project/CordovaLib/Classes/Public/NSDictionary+CordovaPreferences.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/NSDictionary+CordovaPreferences.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVAppDeleg ate.o Classes/Public/CDVAppDelegate.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/armv7 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVAppDelegate.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVAppDelegate.dia -c /project/CordovaLib/Classes/Public/CDVAppDelegate.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVAppDelegate.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebVie wDelegate.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/armv7 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVUIWebViewDelegate.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVUIWebViewDelegate.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVUIWebViewDelegate.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandD elegateImpl.o Classes/Public/CDVCommandDelegateImpl.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/armv7 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVCommandDelegateImpl.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVCommandDelegateImpl.dia -c /project/CordovaLib/Classes/Public/CDVCommandDelegateImpl.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVCommandDelegateImpl.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON_pri vate.o Classes/Private/CDVJSON_private.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/armv7 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVJSON_private.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVJSON_private.dia -c /project/CordovaLib/Classes/Private/CDVJSON_private.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVJSON_private.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelis t.o Classes/Public/CDVWhitelist.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/armv7 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVWhitelist.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVWhitelist.dia -c /project/CordovaLib/Classes/Public/CDVWhitelist.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVWhitelist.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedU rlCommand.o Classes/Public/CDVInvokedUrlCommand.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/armv7 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVInvokedUrlCommand.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVInvokedUrlCommand.dia -c /project/CordovaLib/Classes/Public/CDVInvokedUrlCommand.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVInvokedUrlCommand.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.o Classes/Public/CDVTimer.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/armv7 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVTimer.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVTimer.dia -c /project/CordovaLib/Classes/Public/CDVTimer.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVTimer.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgen tUtil.o Classes/Public/CDVUserAgentUtil.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/armv7 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVUserAgentUtil.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVUserAgentUtil.dia -c /project/CordovaLib/Classes/Public/CDVUserAgentUtil.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVUserAgentUtil.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigPa rser.o Classes/Public/CDVConfigParser.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/armv7 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVConfigParser.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVConfigParser.dia -c /project/CordovaLib/Classes/Public/CDVConfigParser.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVConfigParser.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVGestureH andler.o Classes/Private/Plugins/CDVGestureHandler/CDVGestureHandler.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/armv7 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVGestureHandler.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVGestureHandler.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVGestureHandler/CDVGestureHandler.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVGestureHandler.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVHandleOp enURL.o Classes/Private/Plugins/CDVHandleOpenURL/CDVHandleOpenURL.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/armv7 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVHandleOpenURL.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVHandleOpenURL.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVHandleOpenURL/CDVHandleOpenURL.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVHandleOpenURL.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebVie wNavigationDelegate.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewNavigationDelegate.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        cd /project/CordovaLib
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/armv7 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVUIWebViewNavigationDelegate.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVUIWebViewNavigationDelegate.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewNavigationDele gate.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVUIWebViewNavigationDelegate.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableAr ray+QueueAdditions.o Classes/Public/NSMutableArray+QueueAdditions.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/armv7 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/NSMutableArray+QueueAdditions.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/NSMutableArray+QueueAdditions.dia -c /project/CordovaLib/Classes/Public/NSMutableArray+QueueAdditions.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/NSMutableArray+QueueAdditions.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQ ueue.o Classes/Public/CDVCommandQueue.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/armv7 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVCommandQueue.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVCommandQueue.dia -c /project/CordovaLib/Classes/Public/CDVCommandQueue.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVCommandQueue.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginRe sult.o Classes/Public/CDVPluginResult.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/armv7 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVPluginResult.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVPluginResult.dia -c /project/CordovaLib/Classes/Public/CDVPluginResult.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVPluginResult.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin+R esources.o Classes/Public/CDVPlugin+Resources.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/armv7 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVPlugin+Resources.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVPlugin+Resources.dia -c /project/CordovaLib/Classes/Public/CDVPlugin+Resources.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVPlugin+Resources.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProto col.o Classes/Public/CDVURLProtocol.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        export LANG=en_US.US-ASCII
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/armv7 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVURLProtocol.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVURLProtocol.dia -c /project/CordovaLib/Classes/Public/CDVURLProtocol.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVURLProtocol.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebVie wEngine.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewEngine.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/armv7 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVUIWebViewEngine.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVUIWebViewEngine.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewEngine.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVUIWebViewEngine.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.o Classes/Public/CDVPlugin.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/armv7 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVPlugin.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVPlugin.dia -c /project/CordovaLib/Classes/Public/CDVPlugin.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVPlugin.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalSto rage.o Classes/Private/Plugins/CDVLocalStorage/CDVLocalStorage.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/armv7 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVLocalStorage.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVLocalStorage.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVLocalStorage/CDVLocalStorage.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVLocalStorage.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVIntentAn dNavigationFilter.o Classes/Private/Plugins/CDVIntentAndNavigationFilter/CDVIntentAndNavigationFilter.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/armv7 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-gshzqygqrkfwlzhbgbysrruyxcey/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVIntentAndNavigationFilter.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVIntentAndNavigationFilter.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVIntentAndNavigationFilter/CDVIntentAndNavi gationFilter.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/CDVIntentAndNavigationFilter.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewCont roller.o Classes/Public/CDVViewController.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/arm64 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVViewController.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVViewController.dia -c /project/CordovaLib/Classes/Public/CDVViewController.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVViewController.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionar y+CordovaPreferences.o Classes/Public/NSDictionary+CordovaPreferences.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/arm64 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/NSDictionary+CordovaPreferences.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/NSDictionary+CordovaPreferences.dia -c /project/CordovaLib/Classes/Public/NSDictionary+CordovaPreferences.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/NSDictionary+CordovaPreferences.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVAppDeleg ate.o Classes/Public/CDVAppDelegate.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/arm64 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVAppDelegate.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVAppDelegate.dia -c /project/CordovaLib/Classes/Public/CDVAppDelegate.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVAppDelegate.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebVie wDelegate.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/arm64 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVUIWebViewDelegate.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVUIWebViewDelegate.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVUIWebViewDelegate.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandD elegateImpl.o Classes/Public/CDVCommandDelegateImpl.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/arm64 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVCommandDelegateImpl.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVCommandDelegateImpl.dia -c /project/CordovaLib/Classes/Public/CDVCommandDelegateImpl.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVCommandDelegateImpl.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON_pri vate.o Classes/Private/CDVJSON_private.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/arm64 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVJSON_private.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVJSON_private.dia -c /project/CordovaLib/Classes/Private/CDVJSON_private.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVJSON_private.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelis t.o Classes/Public/CDVWhitelist.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/arm64 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVWhitelist.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVWhitelist.dia -c /project/CordovaLib/Classes/Public/CDVWhitelist.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVWhitelist.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedU rlCommand.o Classes/Public/CDVInvokedUrlCommand.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/arm64 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVInvokedUrlCommand.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVInvokedUrlCommand.dia -c /project/CordovaLib/Classes/Public/CDVInvokedUrlCommand.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVInvokedUrlCommand.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.o Classes/Public/CDVTimer.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/arm64 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVTimer.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVTimer.dia -c /project/CordovaLib/Classes/Public/CDVTimer.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVTimer.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgen tUtil.o Classes/Public/CDVUserAgentUtil.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/arm64 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVUserAgentUtil.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVUserAgentUtil.dia -c /project/CordovaLib/Classes/Public/CDVUserAgentUtil.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVUserAgentUtil.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigPa rser.o Classes/Public/CDVConfigParser.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        cd /project/CordovaLib
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/arm64 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVConfigParser.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVConfigParser.dia -c /project/CordovaLib/Classes/Public/CDVConfigParser.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVConfigParser.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVGestureH andler.o Classes/Private/Plugins/CDVGestureHandler/CDVGestureHandler.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/arm64 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVGestureHandler.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVGestureHandler.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVGestureHandler/CDVGestureHandler.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVGestureHandler.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVHandleOp enURL.o Classes/Private/Plugins/CDVHandleOpenURL/CDVHandleOpenURL.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/arm64 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVHandleOpenURL.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVHandleOpenURL.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVHandleOpenURL/CDVHandleOpenURL.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVHandleOpenURL.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebVie wNavigationDelegate.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewNavigationDelegate.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/arm64 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVUIWebViewNavigationDelegate.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVUIWebViewNavigationDelegate.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewNavigationDele gate.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVUIWebViewNavigationDelegate.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableAr ray+QueueAdditions.o Classes/Public/NSMutableArray+QueueAdditions.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/arm64 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/NSMutableArray+QueueAdditions.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/NSMutableArray+QueueAdditions.dia -c /project/CordovaLib/Classes/Public/NSMutableArray+QueueAdditions.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/NSMutableArray+QueueAdditions.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQ ueue.o Classes/Public/CDVCommandQueue.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        export LANG=en_US.US-ASCII
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/arm64 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVCommandQueue.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVCommandQueue.dia -c /project/CordovaLib/Classes/Public/CDVCommandQueue.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVCommandQueue.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginRe sult.o Classes/Public/CDVPluginResult.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/arm64 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVPluginResult.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVPluginResult.dia -c /project/CordovaLib/Classes/Public/CDVPluginResult.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVPluginResult.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin+R esources.o Classes/Public/CDVPlugin+Resources.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/arm64 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVPlugin+Resources.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVPlugin+Resources.dia -c /project/CordovaLib/Classes/Public/CDVPlugin+Resources.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVPlugin+Resources.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProto col.o Classes/Public/CDVURLProtocol.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/arm64 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVURLProtocol.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVURLProtocol.dia -c /project/CordovaLib/Classes/Public/CDVURLProtocol.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVURLProtocol.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebVie wEngine.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewEngine.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/arm64 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVUIWebViewEngine.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVUIWebViewEngine.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewEngine.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVUIWebViewEngine.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.o Classes/Public/CDVPlugin.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/arm64 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVPlugin.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVPlugin.dia -c /project/CordovaLib/Classes/Public/CDVPlugin.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVPlugin.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalSto rage.o Classes/Private/Plugins/CDVLocalStorage/CDVLocalStorage.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/arm64 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVLocalStorage.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVLocalStorage.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVLocalStorage/CDVLocalStorage.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVLocalStorage.o
      CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVIntentAn dNavigationFilter.o Classes/Private/Plugins/CDVIntentAndNavigationFilter/CDVIntentAndNavigationFilter.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cl ang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -gmodules -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/org.llvm.clang/Modu leCache/Session.modulevalidation -fmodules-validate-once-per-build-session -Wnon-modular-include-in-framework-module -Werror=non-modular-include-in-framework-module -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=7.0 -g -Wno-sign-conversion -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-gene rated-files.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-ow n-target-headers.hmap -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-al l-target-headers.hmap -iquote /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-proj ect-headers.hmap -I/project/build/include -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces/arm64 -I/project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSou rces -F/project/build -include /var/folders/lt/xxbrk07x45bdj1fl3wjgf8yc0000gn/C/com.apple.DeveloperTools/7.1-7B91b/Xcode /SharedPrecompiledHeaders/CordovaLib_Prefix-fdoalobqtroxzycbgsbovpeptbvr/CordovaLib_Prefix .pch -MMD -MT dependencies -MF /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVIntentAndNavigationFilter.d --serialize-diagnostics /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVIntentAndNavigationFilter.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVIntentAndNavigationFilter/CDVIntentAndNavi gationFilter.m -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/CDVIntentAndNavigationFilter.o
      Libtool build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/libCordova. a normal armv7
        export IPHONEOS_DEPLOYMENT_TARGET=7.0
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/li btool -static -arch_only armv7 -syslibroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -L/project/build -filelist /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/Cordova.LinkFileList -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/libCordova.a
      Libtool build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/libCordova. a normal arm64
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/li btool -static -arch_only arm64 -syslibroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPh oneOS9.1.sdk -L/project/build -filelist /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/Cordova.LinkFileList -o /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/libCordova.a
      CreateUniversalBinary /project/build/libCordova.a normal armv7\ arm64
        /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/li btool -static /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/armv7/libCordova.a /project/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-norm al/arm64/libCordova.a -o /project/build/libCordova.a
      === BUILD TARGET WebRTCTest OF PROJECT WebRTCTest WITH THE DEFAULT CONFIGURATION (Release) ===
      Check dependencies
      The provisioning profile "iOS Team Provisioning Profile: com.marciot.MazeWar-VR" is expiring soon
      Swift is unavailable on iOS earlier than 7.0; please set IPHONEOS_DEPLOYMENT_TARGET to 7.0 or later (currently it is '6.0').
      ** BUILD FAILED **
      The following build commands failed:
      Check dependencies
      (1 failure)
