8 Replies Latest reply on Oct 5, 2016 8:02 PM by Deb Newman
    RH 2015 - Cannot open RH Project File - RH hangs
    Deb Newman Level 1
      I have a client who is having trouble with the RoboHelp 2015 Project File. It appears that something has been corrupted.  I have received the Project Files and the same thing has happened to on my laptop. Are there files that I can remove that would help resolve this situation? Something like this happened to me a long time ago and I thought I was able to remove one of the files and RoboHelp rebuilt the file when I reopened it. For the life of me I can't remember what it was. Here's the steps that I can reproduce again and again:
      1. Launch RoboHelp
      2. Click File > Open Project
      3. Navigate to Project File Location
      4. Select RoboHelp HTML Project File
      5. RoboHelp starts to open the File. The cursor goes into a loading spin, appearing like it is trying to load the files. But does nothing. Client has left it running for hours but nothing changes.
      6.  Then this appears
        • 1. Re: RH 2015 - Cannot open RH Project File - RH hangs
          Hi there
          Perhaps try deleting the CPD?
          If you aren't sure how to do that, I've got a handy video that will show you how.
          Click here to view
          Cheers... Rick
          • 2. Re: RH 2015 - Cannot open RH Project File - RH hangs
            Deb Newman Level 1
            Thanks Rick. It was the CPD file that I was thinking of. I deleted the CPD file in the Project Folder, then tried to open the Project File. Here are the error messages that I am getting when I try to open the project. These are in the order that I see them:
            • 3. Re: RH 2015 - Cannot open RH Project File - RH hangs
              One thing I would suggest to try would be to create the following folder:
              C:\Projects\ITSM_Online_User_Guide
              Then copy the project to this folder and try opening it from there.
              Cheers... Rick
              • 4. Re: RH 2015 - Cannot open RH Project File - RH hangs
                Deb Newman Level 1
                Thanks Rick. I did as you suggested and moved it to c:\Projects\assyst_Guide.
                I got the same error messages as before.
                However, I've noticed a couple of things:
                1. The original CPD file was 11,972 KB in size. The one that I keep getting an error on is 892.
                I had an earlier version of the CPD (August 2016)... would it work if I copied it into the latest version that I keep getting errors on?
                2. There is an assyst Guide folder under the first one and it looks like a complete RoboHelp project. Could that have corrupted things?
                3. The first error message starts with assyst_Guide\rhfontset.apj> <1>
                I don't really know what that means or where to find it.
                • 5. Re: RH 2015 - Cannot open RH Project File - RH hangs
                  The CPD file is simply what is known as a "Cache Database" file. Basically, it's a Microsoft Access Database file using a custom file extension. While RoboHelp accesses it and will use it, if it is missing when the project loads, RoboHelp will create a fresh one for you as part of the loading process.
                  Recent versions of RoboHelp store the project in many files. Many of these are XML files. The main database file bears a file extension of .XPJ. Inside that file are references to other XML files. One of these is named rhfontset.apj.
                  From what I'm seeing of the messages, it would seem you either haven't been successful in copying everything to the folder that was mentioned, or you have some files that are munged somewhere. Certainly the fact that you are reporting seeing duplicate project files is suspect.
                  Have you tried navigating to the folder where the duplicate files live and opening the project from there?
                  Cheers... Rick
                  • 6. Re: RH 2015 - Cannot open RH Project File - RH hangs
                    Deb Newman Level 1
                    Thanks for explaining the CPD. I had also thought of opening the duplicate set of files (discovered that it is from an earlier version of RoboHelp). I did try to open the duplicate files and got the same set of errors.
                    I have successfully opened the August version of the RoboHelp Project Files that I helped them with this summer. I'm not sure what you mean by files that are munged somewhere.
                    I tried to remove the duplicate set of files but I got an error even thought I have closed everything. I may have to reboot and remove it then.
                    • 7. Re: RH 2015 - Cannot open RH Project File - RH hangs
                      Amebr Level 4
                      This thread suggests deleting the rhfontset.apj file - RH should recreate the file when you open the project. It will be in the same folder as the xpj and cpd files.
                      Errors when opening a RH project.
                      Perhaps rename it initially to see if it helps - if you have created custom font sets you may need to recreate them.
                      • 8. Re: RH 2015 - Cannot open RH Project File - RH hangs
                        Deb Newman Level 1
                        Thank you both for your help (Rick and Amerbr). I viewed the Errors when opening a RH project link in Amebr's answer.
                        Please note that in RH 2015 the location of the Option referenced in her answer is now here: File > Options. I checked the checkbox next to Clear project cache (CPD file) before opening any project.
                        However, I got the rhfontset.apj error when I tried to open the Project File. As suggested, I deleted the rhfontset.apj file and reopened the project file. Everything opened the way it should.
                        Thank you so much for your help. My client will be very happy when I send instructions on how to solve the problem.
                        I truly appreciate your expertise in the Community.
