2 Replies Latest reply on Oct 5, 2016 3:15 PM by ethan64333755
    "Error: /project/gradlew" when building Android app
    ethan64333755
      Hello all,
      Whenever I submit my app (as of last Thursday 9/29/16) the build fails with this error, "Error: /project/gradlew". It does not matter if this project if this project would build a month ago, and has not been edited since, or if it was changed the night before. I feel like this is a platform bug, but I need help figuring it out.
      Any reason why this would not work, anything I am not seeing. I am expecting to use cli-6.3.0, because that is the default.
      Here is my build log:
      Build Date: 2016-10-05 20:01:01 +0000
      PLUGIN OUTPUT
      Fetching plugin "cordova-plugin-whitelist" via npm
      Installing "cordova-plugin-whitelist" at "1.3.0" for android
        This plugin is only applicable for versions of cordova-android greater than 4.0. If you have a previous platform version, you do *not* need this plugin since the whitelist will be built in.
      Fetching plugin "phonegap-plugin-push@1.6.0" via npm
      Installing "phonegap-plugin-push" at "1.6.0" for android
      Fetching plugin "cordova-plugin-device" via npm
      Installing "cordova-plugin-device" at "1.1.3" for android
      COMPILE OUTPUT
      Configuration on demand is an incubating feature.
      Incremental java compilation is an incubating feature.
      :preBuild UP-TO-DATE
      :preDebugBuild UP-TO-DATE
      :checkDebugManifest
      :preReleaseBuild UP-TO-DATE
      :CordovaLib:preBuild UP-TO-DATE
      :CordovaLib:preDebugBuild UP-TO-DATE
      :CordovaLib:compileDebugNdk UP-TO-DATE
      :CordovaLib:compileLint
      :CordovaLib:copyDebugLint UP-TO-DATE
      :CordovaLib:mergeDebugProguardFiles
      :CordovaLib:packageDebugRenderscript UP-TO-DATE
      :CordovaLib:checkDebugManifest
      :CordovaLib:prepareDebugDependencies
      :CordovaLib:compileDebugRenderscript
      :CordovaLib:generateDebugResValues
      :CordovaLib:generateDebugResources
      :CordovaLib:packageDebugResources
      :CordovaLib:compileDebugAidl
      :CordovaLib:generateDebugBuildConfig
      :CordovaLib:mergeDebugShaders
      :CordovaLib:compileDebugShaders
      :CordovaLib:generateDebugAssets
      :CordovaLib:mergeDebugAssets
      :CordovaLib:processDebugManifest
      :CordovaLib:processDebugResources
      :CordovaLib:generateDebugSources
      :CordovaLib:incrementalDebugJavaCompilationSafeguard
      :CordovaLib:compileDebugJavaWithJavac
      :CordovaLib:compileDebugJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      Note: Some input files use or override a deprecated API.
      Note: Recompile with -Xlint:deprecation for details.
      :CordovaLib:processDebugJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForDebug
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug
      :CordovaLib:mergeDebugJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForDebug
      :CordovaLib:transformNative_libsWithSyncJniLibsForDebug
      :CordovaLib:bundleDebug
      :CordovaLib:preReleaseBuild UP-TO-DATE
      :CordovaLib:compileReleaseNdk UP-TO-DATE
      :CordovaLib:copyReleaseLint UP-TO-DATE
      :CordovaLib:mergeReleaseProguardFiles
      :CordovaLib:packageReleaseRenderscript UP-TO-DATE
      :CordovaLib:checkReleaseManifest
      :CordovaLib:prepareReleaseDependencies
      :CordovaLib:compileReleaseRenderscript
      :CordovaLib:generateReleaseResValues
      :CordovaLib:generateReleaseResources
      :CordovaLib:packageReleaseResources
      :CordovaLib:compileReleaseAidl
      :CordovaLib:generateReleaseBuildConfig
      :CordovaLib:mergeReleaseShaders
      :CordovaLib:compileReleaseShaders
      :CordovaLib:generateReleaseAssets
      :CordovaLib:mergeReleaseAssets
      :CordovaLib:processReleaseManifest
      :CordovaLib:processReleaseResources
      :CordovaLib:generateReleaseSources
      :CordovaLib:incrementalReleaseJavaCompilationSafeguard
      :CordovaLib:compileReleaseJavaWithJavac
      :CordovaLib:compileReleaseJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      :CordovaLib:processReleaseJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForRelease
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease
      :CordovaLib:mergeReleaseJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForRelease
      :CordovaLib:transformNative_libsWithSyncJniLibsForRelease
      :CordovaLib:bundleRelease
      :prepareComAndroidSupportSupportV132340Library
      :prepareComAndroidSupportSupportV42340Library
      :prepareComGoogleAndroidGmsPlayServicesBase940Library
      :prepareComGoogleAndroidGmsPlayServicesBasement940Library
      :prepareComGoogleAndroidGmsPlayServicesGcm940Library
      :prepareComGoogleAndroidGmsPlayServicesIid940Library
      :prepareComGoogleAndroidGmsPlayServicesTasks940Library
      :prepareProjectCordovaLibUnspecifiedDebugLibrary
      :compileDebugAidl
      :mergeDebugShaders
      :mergeDebugAssets
      :mergeDebugResources
      :processDebugResources FAILED
      FAILURE: Build failed with an exception.
      * What went wrong:
      Execution failed for task ':processDebugResources'.
      > com.android.ide.common.process.ProcessException: org.gradle.process.internal.ExecException: Process 'command '/android-sdk/build-tools/24.0.1/aapt'' finished with non-zero exit value 1
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 3.288 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      * What went wrong:
      * Try:
        at ChildProcess.whenDone (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)
        at emitTwo (events.js:106:13)
        at ChildProcess.emit (events.js:191:7)
        at maybeClose (internal/child_process.js:877:16)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
      And here is my config.xml:
      <widget xmlns     = "http://www.w3.org/ns/widgets"
              xmlns:gap = "http://phonegap.com/ns/1.0"
              id        = "com.phonegap.helloworld"
              version   = "1.0.0">
          <name>Hello World</name>
          <description>
              Hello World sample application that responds to the deviceready event.
          </description>
          <author href="http://phonegap.com" email="support@phonegap.com">
              PhoneGap Team
          </author>
      <content src="calendar.html"/>
      <plugin name="cordova-plugin-whitelist" source="npm" />
      <plugin name="phonegap-plugin-push" spec="1.6.0">
          <param name="SENDER_ID" value="244192342021" />
      </plugin>
      <plugin name="cordova-plugin-device" source="npm" />
      <icon src="icon.png" />
      <access origin="*" />
      <access origin="https://secure-island-66271.herokuapp.com/calendar/" />
      <platform name="android">
          <preference name="orientation" value="portrait" />
      <!-- a preference specific to android only here -->
      </platform>
      <platform name="ios" >
          <icon src="res/icon/ios/Icon-72.png" width="72" height="72" />
          <icon src="res/icon/ios/Icon-Small-50@2x.png" width="114" height="114" />
          <icon src="res/icon/ios/Icon-72@2x.png" width="144" height="144" />
          <icon src="res/icon/ios/Icon-60@2x.png" width="120" height="120" />
          <icon src="res/icon/ios/Icon-76@2x.png" width="152" height="152" />
          <icon src="res/icon/ios/Icon-76.png" width="76" height="76" />
          <icon src="res/icon/ios/Icon-60@3x.png" width="180" height="180" />
          <icon src="res/icon/ios/icon-83.5@2x.png" width="167" height="167" />
      </platform>
      <feature name="Device">
      <param name="android-package"
      value="org.apache.cordova.device.Device"/>
      </feature>
      </widget>
