4 Replies Latest reply on Oct 6, 2016 7:16 AM by colt-ger
    Compare PDF fields with imported xml in a loop
    colt-ger
      Hello,
      At the beginning I am a newbie in Acrobat and Javascript.
      I have create a PDF-form with Acrobat Pro, my next idea is to fill the PDF with related data via an XML-Import.
      Actual I can import the xml and fill the PDF-Fields hardcoded, this works already via Javascript.
      My problem actual is, I want to fill the PDF with the XML-data via an for-loop, because we want to use this script in several PDF-forms and not each form has the same amount of fields.
      Here my working script:
      var xmldoc = util.readFileIntoStream();
      var xmlstring = util.stringFromStream();
      var myXML = XMLData.parse(xmlstring,false);
      var oNode = XMLData.applyXPath(myXML,"//Customer");
      this.getField("CustomerName").value=oNode.Customer.CustomerName.value;
      this.getField("CustomerStreet").value=oNode.Customer.CustomerStreet.value;
      this.getField("CustomerPlace").value=oNode.Customer.CustomerPlace.value;
      this.getField("CustomerSiteName").value=oNode.Customer.CustomerSiteName.value;
      this.getField("CustomerSiteStreet").value=oNode.Customer.CustomerSiteStreet.value;
      this.getField("CustomerSitePlace").value=oNode.Customer.CustomerSitePlace.value;
      Here my problem
      for(var i=0;i<oNode.length;i++){
      if(this.getField(????)==oNode.Order.???){
      this.getField(???[i]).value=oNode.Order.???[i].value;
      I hope anyone understand what I mean and can help me.
      thx in advance
      Regards
      Dirk
