4 Replies Latest reply on Oct 6, 2016 10:23 AM by Axel Matt
    Wacom Tablet Problems in Lightroom 6
    BaldEagle63
      Hi Guys,
      I've recently upgraded from Lightroom 5.7 to Lightroom 6 (Standalone - don't want to use the Adobe subscription mullarky ;) ) and am having a few problems with my Wacom Bamboo.
      Specifically with the spot healing brush - when I try and draw a shape to be healed, the on screen graphics lags terribly and quite often draws further lines - although I've lifted the pen from the tablet..
      If I turn off the "Use Windows Ink" option in the Bamboo driver/properties, then it performs much better, but then I have no pen pressure capabilities with any adjustment brushes..
      I know the Bamboo isn't a "professional grade" graphic tablet - but it works absolutely fine with 5.7 - it's just with 6 that I'm getting this strange problem.
      Tried turning the graphics acceleration on and off, doesn't make any difference.. as I said, only turning off windows ink seems to relieve the problem...
      Anyone else got/had any similar issues? Anyone got any suggestions how I can overcome the problem? (without turning off windows ink)
      Cheers,
      Baldy ;)
        • 1. Re: Wacom Tablet Problems in Lightroom 6
          Akash Sharma Adobe Employee
          Hi Baldy,
          Could you please ensure that you have updated to the latest version of Lightroom 6.7
          Regards,
          Akash
          • 2. Re: Wacom Tablet Problems in Lightroom 6
            BaldEagle63 Level 1
            Hi Akash,
            Thanks for your answer, unfortunately I have already updated to 6.7 (sorry, probably should have said in my post) and it made no difference to the problem!
            In addition I have checked the Wacom drivers (they are the latest), made sure Windows (Win 7 64-bit) is fully patched and there are no updates available for Windows Ink...
            Regards,
            Baldy
            • 3. Re: Wacom Tablet Problems in Lightroom 6
              Todd Shaner Adobe Community Professional & MVP
              I'm seeing a similar issue with my Intuos 4 Medium USB tablet with LR CC 2015.7 on my Windows 7 system. Latest Wacom drivers and Windows 7 updates are installed. In my case the Heal brush works fine when painting over the area I want to fix. It's when I move the sample area spot to a location much further away that I see the behavior you mention. I also have LR 5.7.1 installed and see the same behavior. I normally don't use a sample area that is very far away from the area being repaired so never had issue until I tried it today.
