8 Replies Latest reply on Oct 6, 2016 9:58 AM by try67
    two factors JSON sorting
    MatLac Adobe Community Professional
      I found an exellent script example to sorts a JSON according to a specified key:
      function sortJSON(data, key, way) {
          return data.sort(function(a, b) {
              var x = a[key]; var y = b[key];
              if (way === '123' ) { return ((x < y) ? -1 : ((x > y) ? 1 : 0)); }
              if (way === '321') { return ((x > y) ? -1 : ((x < y) ? 1 : 0)); }
      where:
      data = JSON to sort
      key = the key you want it sorted with
      way = ascending or descending order
      My JSON is as follow:
      var POL = [
        {cName:"John Doe", cDate: new Date(2005, 4, 16), cPassword:"162151", cTeam:34, cEmail:"john.doe@email.com"},
        {cName:"Jane Doe", cDate: new Date(2005, 4, 16), cPassword:"161974", cTeam:34, cEmail:"jane.doe@email.com"},
        {cName:"Jack Doe", cDate: new Date(2013, 3, 22), cPassword:"167406", cTeam:34, cEmail:"jack.doe@email.com"},
      I need to sort the JSON by cDate first but supposed there are identical dates, I need to sort these by cPassword
      How can I update my script, maybe I need something totally different or maybe is it even possible?
        • 1. Re: two factors JSON sorting
          You can compare date objects directly, using the mathematical operators.
          If the dates are equal, then you can compare the passwords (comparing
          strings is more complicated, though).
          • 2. Re: two factors JSON sorting
            Thanks try67,
            It will only be dates and numbers that are gonna be sorted altough my example shows strings.
            Are you telling me I should create a sortedJSON with the first key and THEN sort it with the second key?  I have a feeling that this will not sort by two factors but rather sort two times adding possibilities for errors?
            • 3. Re: two factors JSON sorting
              No, you need to do it all in a single function.
              Basically it would be something like this:
              if (a.cDate==b.cDate) {
                   // compare passwords
              } else {
                   // compare dates
              • 4. Re: two factors JSON sorting
                I rewrote the function wtih your hints and added a little test to a button, works like a charm.  thanks.
                function sortJSON2(data, key1, key2, way) {
                        var x = a[key1]; var y = b[key1];
                  if (a[key1] == b[key1]){
                  var x2 = a[key2]; var y2 = b[key2];
                  if (way === '123' ) { return ((x2 < y2) ? -1 : ((x2 > y2) ? 1 : 0)); }
                  if (way === '321') { return ((x2 > y2) ? -1 : ((x2 < y2) ? 1 : 0)); }
                  else {
                console.clear()
                var POL2 = [
                  {param1:1, param2:2435},
                  {param1:2, param2:12},
                  {param1:3, param2:54},
                  {param1:1, param2:1},
                  {param1:5, param2:55},
                  {param1:1, param2:75476},
                  {param1:7, param2:5},
                  {param1:8, param2:98}
                var workArray1 = []
                var workArray2 = []
                //sort array
                var sorted1 = sortJSON2(POL2, "param1", "param2", "123")
                for (i in sorted1){
                  workArray1.push(sorted1[i].param1)
                  workArray2.push(sorted1[i].param2)
                //display new order
                console.println(workArray1+"\r"+workArray2+"\r")
                //displays correct order
                1,1,1,2,3,5,7,8
                1,2435,75476,12,54,55,5,98
                • 5. Re: two factors JSON sorting
                  I might have been quick on the response because I just applied my solution to the real JSON and it doesn't sort the second factor.  So I inserted an alert in the if statement and found out is is never triggered.
                  So definittely, comparing the two dates returns false, is there something I'm not getting?
                  function sortJSON(data, key1, key2, way) {
                    app.alert("test")                                         //never triggers
                    else {
                    app.alert("test2")                                       //triggers about 72 times
                  • 6. Re: two factors JSON sorting
                    also, I inserted
                    console.println(x+"\r"+y+"\r"+(x == y)+"\r\r")
                    ust to display each pair of days.  I found out that some are the same but the still return false when compared
                    here is an output example
                    Mon Jul 06 2009 00:00:00 GMT-0400
                    false
                    • 7. Re: two factors JSON sorting
                      Since I am trying to compare dates, it seems I must use the getTime() method of the date object for comparison.  Here is the working script.
                              var x = a[key1].getTime(); var y = b[key1].getTime();
                        if (x == y){
                        else {
                      • 8. Re: two factors JSON sorting
                        It should work even without getTime(), but might be better to include it anyway.
