3 Replies Latest reply on Oct 6, 2016 11:48 PM by gert verrept
    delete pages
    jakec88782761 Level 2
      Hi everyone,
      Im trying to delete the first and last page of a doc before exporting.
      This loop deletes every page and I can't figure out why..
      for (i = 0; i<pages.length;i++){
          if (pages[i]===page[0]||pages[i]===page[-1]){
              pages[i].remove();
      The script always runs the code in the if statement no matter what page it's on.
      Any help?
        • 1. Re: delete pages
          geert@2imagine
          Try this:
          pages[pages.length-1].remove();
          pages[0].remove();
          • 2. Re: delete pages
            Loic.Aigon Adobe Community Professional
            Maybe that's because when you remove pages[i] when i stands for 0, the previous pages[1] reference now point to the current pages[0] object. So loop after loop pages[i] is still equaling pages[0] then leading to the removal of all the pages (except final page 1).
            Prefer @geert@2imagine method.
            Loic
            • 3. Re: delete pages
              gert verrept Level 2
              I use this one (made by MVH)
              It gives you a pagerange or a just one page you can delete, if you insert the code to delete the first and last page in the dialogbox, you have it all in one script.
              if (app.documents.length == 0){
                alert("There is no document open to delete pages.");
                exit();
              var remove_pages = menu();
              if (remove_pages.show()) {
              number_pages = pages.editContents;
                try {
                remove_override();
                pages_remove();
                } catch (e) {}
              //functions
              function menu(){
              var dialoog_venster = app.dialogs.add({name:"Delete pages", canCancel:true} );
                with (dialoog_venster){
                with (dialogColumns.add() ){
                with (dialogRows.add() ){
                staticTexts.add({staticLabel:"Pagerange you want to delete:          "} );
                pages = textEditboxes.add({editContents:"", minWidth:225} ); }
                return dialoog_venster;
              function pages_remove() {
                range_test = number_pages.indexOf("-");
                if (range_test != -1) {
                split_range = number_pages.split("-");
                start = split_range[0];
                end = split_range[1];
                number = parseInt(end) - parseInt(start) + 1;
                for (i=0; i<number; i++) {
                page = parseInt(end) - i;
                page = page + "";
                app.activeDocument.pages.item(page).remove();
                } else {
                app.activeDocument.pages.item(number_pages).remove();
              function remove_override() {
                total_number_pages = app.activeDocument.pages.length;
                for (i=1; i<total_number_pages; i++) {
                page_items = app.activeDocument.pages.item(i).pageItems;
                for (j=page_items.length-1; j>-1; j--) {
                if (page_items[j].label == "") {
                if (page_items[j].overridden == true) {
                page_items[j].removeOverride();
