• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Multiple Solr Collections Error
New Here ,
Oct 09, 2016 Oct 09, 2016
I have multiple collections on my server and use cfsearch to retrieve data from them.  I have been sending requests using multiple collections like this:
<cfsearch name="mysearch" collection="collection1,collection2" criteria="test">
This works on my dev server, but fails on my production server.  I am running CF 11 (11,0,08,298512) on both (Windows Server 2008 on both too).  I can get results on my production server if I query one collection at a time, but if I try both, it crashes the AddOn service.
Any ideas?
Got an error message finally:
500 Error
There was a problem while attempting to perform a search.
Type: SearchEngine
java.net.SocketException: Connection reset : Connection reset
 coldfusion.tagext.search.SearchTag$SearchProblemException: There was a problem while attempting to perform a search. at coldfusion.tagext.search.SolrUtils.formatSearchResult(SolrUtils.java:2022) at coldfusion.tagext.search.SolrUtils.getSearchResult(SolrUtils.java:2516) at coldfusion.tagext.search.SolrUtils.getSearchResult(SolrUtils.java:2276) at coldfusion.tagext.search.SearchTag.doSolrSearch(SearchTag.java:397) at coldfusion.tagext.search.SearchTag.doSearch(SearchTag.java:243) at coldfusion.tagext.search.SearchTag.doStartTag(SearchTag.java:185) at coldfusion.runtime.CfJspPage._emptyTcfTag(CfJspPage.java:2991) at cftest2ecfm1608686197.runPage(D:\insidecbt\inc\admin\test\test.cfm:4) at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:246) at coldfusion.tagext.lang.IncludeTag.handlePageInvoke(IncludeTag.java:736) at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:572) at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65) at coldfusion.filter.IpFilter.invoke(IpFilter.java:45) at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:466) at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:42) at coldfusion.filter.MonitoringFilter.invoke(MonitoringFilter.java:40) at coldfusion.filter.PathFilter.invoke(PathFilter.java:142) at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:94) at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:28) at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38) at coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:58) at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38) at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22) at coldfusion.filter.CachingFilter.invoke(CachingFilter.java:62) at coldfusion.CfmServlet.service(CfmServlet.java:219) at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42) at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:169) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:450) at org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:197) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:625) at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:316) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) at java.lang.Thread.run(Thread.java:745)
Views
525
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Oct 11, 2016 Oct 11, 2016
Place CFTRY/CFCATCH around your CFINDEX, and either display or email a CFDUMP of the #cfcatch# object.  This should give you a better idea of what is happening.  Please post the message, here, and I'll try to provide whatever assistance I may.
V/r,
^_^
Votes
Translate
Translate
Report
Report
New Here ,
Hi WolfShade... it indexes fine with no errors and I can search and retrieve with no errors as well, as long as I am only searching one collection.
This works:
<cfsearch name="mysearch" collection="collection1" criteria="test">
This works:
<cfsearch name="mysearch" collection="collection2" criteria="test">
This does not work:
The service hangs when I submit this search.
Note that I have the same setup on my dev server and it searches two collections fine with no errors.
If do the cftry below, I don't get an error message, it just hangs there spinning:
<cftry>
     <cfsearch
         name="rs"
         criteria="test">
     <cfcatch><cfdump var="#cfcatch#"></cfcatch>
</cftry>
<cfdump var="#rs.recordcount#">
I have found a standalone AddOn service installer on the Adobe site.  Can I use this to reinstall the AddOn service in my cf11 install or is this only to create a separate stand-alone version?
Votes
Translate
Translate
Report
Report
LEGEND ,
Oct 12, 2016 Oct 12, 2016
If the CFINDEX hangs, then that explains why no CFCATCH is triggered.  Is there anything in the CFAdmin logs?  If you can, archive the coldfusion-out, application, and other logs, run the script that hangs, give it a few moments, then check the logs to see if anything new indicates what the issue is.
Then, again, how large of a collection are you searching?  Have you re-indexed it?  Is it a database or file collection?  Have you optimized the collection?
V/r,
^_^
Votes
Translate
Translate
Report
Report
New Here ,
Oct 14, 2016 Oct 14, 2016
LATEST
CFINDEX works fine, I am indexing two separate collections, one database and one files.
CFSEARCH works fine on both collections if I search them individually.
It breaks when I try to search both at the same time.
I have to wait until the weekend to work on this again, but here is one error from coldfusion-out that occured when I was testing this:
Oct 8, 2016 17:46:00 PM Error [ajp-bio-8014-exec-1] - java.lang.NullPointerException at coldfusion.tagext.search.SearchTag.doSearch(SearchTag.java:269) at coldfusion.tagext.search.SearchTag.doStartTag(SearchTag.java:185) at coldfusion.runtime.CfJspPage._emptyTcfTag(CfJspPage.java:2991) at cfsearch2ecfc591865024$funcGETSEARCH.runFunction(D:\insidecbt\plugins\search_dms\model\search.cfc:269) at coldfusion.runtime.UDFMethod.invoke(UDFMethod.java:487) at coldfusion.runtime.UDFMethod$ArgumentCollectionFilter.invoke(UDFMethod.java:383) at coldfusion.filter.FunctionAccessFilter.invoke(FunctionAccessFilter.java:95) at coldfusion.runtime.UDFMethod.runFilterChain(UDFMethod.java:334) at coldfusion.runtime.UDFMethod.invoke(UDFMethod.java:533) at coldfusion.runtime.TemplateProxy.invoke(TemplateProxy.java:648) at coldfusion.runtime.TemplateProxy.invoke(TemplateProxy.java:457) at coldfusion.filter.ComponentFilter.invoke(ComponentFilter.java:251) at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:480) at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:42) at coldfusion.filter.MonitoringFilter.invoke(MonitoringFilter.java:40) at coldfusion.filter.PathFilter.invoke(PathFilter.java:142) at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:94) at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:28) at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38) at coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:58) at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38) at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22) at coldfusion.xml.rpc.CFCServlet.invoke(CFCServlet.java:156) at coldfusion.xml.rpc.CFCServlet.doPost(CFCServlet.java:348) at javax.servlet.http.HttpServlet.service(HttpServlet.java:650) at javax.servlet.http.HttpServlet.service(HttpServlet.java:731) at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42) at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:169) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:450) at org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:197) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:625) at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:316) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) at java.lang.Thread.run(Thread.java:745)
Votes
Translate
Translate
Report
Report
Resources
Documentation
