1 Reply Latest reply: Feb 23, 2009 11:57 AM by kamckng RSS
    removing various objects from an array
    kamckng Community Member
      I have a utility function:
      function removeFromArray(item:Object, arr:Array):Object {
      for(var i:uint = 0; i < arr.length; i++) {
      if(item == arr ) {
      arr.splice(i, 1);
      return item;
      return -1;
      This function searches through an array and sees if an item exists in it, if it does, it removes it and returns a reference to that item.
      This works fine for most things. But I just ran into a problem where I need to remove an array from an array.
      so my array looks like this [ [item1a, item1b], [item2a, item2b] ]; and i need to remove [item1a, item1b] from it. But passing in the the array to remove and the full array to remove it from does not work because i guess of the casting to an object in the parameters list. Can the functionality i want be used? if so how?
      Kyle
