15 Replies Latest reply on Nov 7, 2016 8:07 AM by Marquam
    HTML working fine on localhost, but not online
    Marquam Level 1
      After updating Muse to latest version my sites doesn't work online - only see a clear white site (the HTML source is online, you can see in browser). Local on my mac, the same site loaded manually, still runs perfect. It seems that some js block the site.
      Everytime I loaded the HTML files via Dreamweaver, because I have sometimes to add a few support files, which I can't integrate in Muse.
      Why doesn't the site runs online? No error messages and every file seems to be online.
      Looking at: 2016.marquam.de
      Regards,
      Dennis Hock
        • 1. Re: HTML working fine on localhost, but not online
          ankushr40215001 Level 7
          Hello Dennis,
          Check this thread Updating one page on my Muse site  which will help you with its upload.
          • 2. Re: HTML working fine on localhost, but not online
            Marquam Level 1
            can't open the thread (link)...
            • 4. Re: HTML working fine on localhost, but not online
              Marquam Level 1
              Hi, I found it by searching. Just tried it but it still doesn't run. Now I am going to generate a new subdomain and upload again. I'll leave a feedback then ...
              • 5. Re: HTML working fine on localhost, but not online
                Marquam Level 1
                Hi, it almost doesn't run.
                watching:
                Homepage  (old version of muse) = running
                2016b.marquam.de (new version) = not running
                I think its gonna be the new js in head (some kind of verification?)
                • 6. Re: HTML working fine on localhost, but not online
                  VivekP Adobe Employee
                  Hello,
                  I can see that you have used a third party widget in the page scripts used in the widget are causing the issue. Please remove the widget from the page in the latest muse version and then publish the site and check if it loads fine.
                  Regards,
                  Vivek
                  • 7. Re: HTML working fine on localhost, but not online
                    dtgmcghee Level 1
                    I am having the same problem. I created a site for my client in Muse, and I use Dreamweaver to upload the site to the client’s server. Each time I delete all of the old file and then upload the entire site, just to make sure that all modified files are uploaded. This method has always worked in the past. The last update was 10/22/15. But now when I try to upload the site, it does not work. All I see is a clear blank page. I tried viewing with several different browsers with the same result.
                    Now when I look at the index.html from the previous site files, the source looks good.
                    <!DOCTYPE html>
                    <html class="html" lang="en-US">
                    <head>
                      if(typeof Muse == "undefined") window.Muse = {}; window.Muse.assets = {"required":["jquery-1.8.3.min.js", "museutils.js", "jquery.watch.js", "jquery.musemenu.js", "webpro.js", "musewpslideshow.js", "jquery.museoverlay.js", "touchswipe.js", "index.css"], "outOfDate":[]};
                    </script>
                      <meta http-equiv="Content-type" content="text/html;charset=UTF-8"/>
                      <meta name="generator" content="2015.0.2.310"/>
                      <link rel="shortcut icon" href="images/favicon.ico?3783381892"/>
                      <title>HOME</title>
                      <!-- CSS -->
                      <link rel="stylesheet" type="text/css" href="css/site_global.css?478931369"/>
                      <link rel="stylesheet" type="text/css" href="css/master_a-master.css?4239895287"/>
                      <link rel="stylesheet" type="text/css" href="css/index.css?4276439905" id="pagesheet"/>
                      <!-- Other scripts -->
                      document.documentElement.className += ' js';
                    var __adobewebfontsappname__ = "muse";
                    </script>
                      <!-- JS includes -->
                      <!--[if lt IE 9]>
                      <script src="scripts/html5shiv.js?4241844378" type="text/javascript"></script>
                      <![endif]-->
                      document.write('\x3Cscript src="' + (document.location.protocol == 'https:' ? 'https:' : 'http:') + '//webfonts.creativecloud.com/open-sans:n7,n8,n4:default.js" type="text/javascript">\x3C/script>');
                    </script>
                      document.write('\x3Cscript src="' + (document.location.protocol == 'https:' ? 'https:' : 'http:') + '//use.typekit.net/ik/VVkQp9KTMHs2SmeSNYutggOVX7h9GMsdep4PpG-WcaGfeG3gfJ-5wyJ152J35QqtWh9 XwAbtjcjX5QjUjhw3ZRjaFQbtwDyqZQj3wRyqweJheKuCiWZlpABkie4odWiTdYFzdKoRdhXCHKoCiWZlpABkie4od WiTdYFzdKoRdhXKfamkikuyd1sTSWmyH6qJ1h6bMg6YJMJ7fbKK-gMMeMt6MqGIQWmDZZMgc7PcCb9.js" type="text/javascript">\x3C/script>');
                    </script>
                      try {Typekit.load();} catch(e) {}
                    </script>
                    When I look at index.html from the newly revised file (with Dreamweaver) there is some strange comment in the head. about the javascript. Here is what it looks like:
                    <!DOCTYPE html>
                    <html class="nojs html css_verticalspacer" lang="en-US">
                    <head>
                      <meta name="generator" content="2015.2.1.352"/>
                       // Update the 'nojs'/'js' class on the html node
                    document.documentElement.className = document.documentElement.className.replace(/\bnojs\b/g, 'js');
                    // Check that all required assets are uploaded and up-to-date
                    if(typeof Muse == "undefined") window.Muse = {}; window.Muse.assets = {"required":["jquery-1.8.3.min.js", "museutils.js", "museconfig.js", "jquery.watch.js", "jquery.musemenu.js", "webpro.js", "musewpslideshow.js", "jquery.museoverlay.js", "touchswipe.js", "require.js", "index.css"], "outOfDate":[]};
                    </script>
                      <link rel="shortcut icon" href="images/favicon.ico?crc=3783381892"/>
                      <title>HOME</title>
                      <!-- CSS -->
                      <link rel="stylesheet" type="text/css" href="css/site_global.css?crc=4202751306"/>
                      <link rel="stylesheet" type="text/css" href="css/master_a-master.css?crc=4285483878"/>
                      <link rel="stylesheet" type="text/css" href="css/index.css?crc=198331181" id="pagesheet"/>
                    </script>
                      <!--[if lt IE 9]>
                      <script src="scripts/html5shiv.js?crc=4241844378" type="text/javascript"></script>
                      <![endif]-->
                    </script>
                       document.write('\x3Cscript src="' + (document.location.protocol == 'https:' ? 'https:' : 'http:') + '//use.typekit.net/ik/rdrB5j64hLlef5HVOBxTnCqxqafqORD-emWOW1taa7qfe7jgfJ-5wyJ152J35QqtWD6 DZ29aZ2gyjQIkFcZKFQIoFAjtZ29owDb35ebu5AwXeqS7OcUuicuojW4Xj18lih8CShN0OcFzdPUCiWZlpABkie4od WiTdYFzdKoRdhXCiaiaOcUuicuojW4Xj18lih8CShN0OcFzdPJOiW4aOAB0ie8UiAI7fbKL-gMMeMS6MKG4fH4GIMM j2KMfP6sFiWF8qMewTtYMgb.js" type="text/javascript">\x3C/script>');
                    </script>
                    </script>
                    SO...I am not sure why Muse is not generating the code correctly???
                    • 8. Re: HTML working fine on localhost, but not online
                      Can you share the url  or .muse file  that is loading blank so that we can take a look at it to find the possible root-cause.
                      Regards,
                      Vivek
                      • 9. Re: HTML working fine on localhost, but not online
                        Marquam Level 1
                        Okay, I "trying by error" ...
                        I removed the nods-class in <html>-tag -> site runs without js ....
                        • 10. Re: HTML working fine on localhost, but not online
                          Marquam Level 1
                          Hello Vivek,
                          here the url for the .muse file. I hope that I uploaded the right one ...
                          http://2016b.marquam.de/Muse/Marquam2015_Muse_(2015_2).muse
                          Regards,
                          Dennis
                          • 11. Re: HTML working fine on localhost, but not online
                            Ussnorway Adobe Community Professional
                            this is your muse file loaded onto Adobe bc Homepage
                            looks ok to me but can you point out the error?
                            • 12. Re: HTML working fine on localhost, but not online
                              Marquam Level 1
                              On businesscatalyst it works fine but not on other webspace especially on subdomains. Got the same problem when I update the website of my dog: in that page are no third party elements an it also sho a blank white page ...
                              • 13. Re: HTML working fine on localhost, but not online
                                Does this other host server have a name i.e, godady or is it a private server maintained in house?
                                Its appears to me at this point that the error is at that end so not a muse issue
                                • 14. Re: HTML working fine on localhost, but not online
                                  Marquam Level 1
                                  I don't know if the server got a name. Running on host by strato.de
                                  • 15. Re: HTML working fine on localhost, but not online
                                    Marquam Level 1
                                    Problem solved: Using the new update muse 2017. Using the muse intern ftp for site-data and dw-ftp for thirdparty html-plugins. Working fine
