3 Replies Latest reply on Oct 17, 2016 2:09 AM by K.Daube
    Nested dialogue problem
    K.Daube Level 2
      Dear experts,
      From a palette i need to divert into a dialgoue and then come back into the palette.
      This works fine for the first time i enter the dialogue. The dialogue fails when entered the second time.
      A stripped down version of my scripts is following. The palette is to the left, the 'test' dialogue to the right:
      • Usage is as follows:
      • In the palette active the checkbox and clik the Handle Content button.
      • This invokes the 'test' dialogue.
      • According to the settings in the script the OK/Return button is hidden.
      • Clicking the Cancel button closes this dialogue and we are back in the palette.
      • Since the 'test' was cancelled, an alert appears with NO as default.
      • Click NO
      • The check box is cleared for a new decision
      • Now the user 'changes the input (top field)', checks the box and clicks the Handle ... button.
      • => Error on line 48: undefined is not an object.
      What may be wrong here?
      // NestedDialogue.jsx
      #target framemaker
      // target needed for Alert ...
      var gsVariable;
      var wPalDS = new Window('palette',"FM-calc : Manage Variables",undefined);
      var wPalV  = new Window('dialog', "FM-calc : Check contents of variable", undefined);
      PaletteDocSettings();
      function PaletteDocSettings(){ //=== Outer function
          wPalDS.sVarValue = wPalDS.add('edittext',undefined,"Content to be handled", {multiline:true});
          wPalDS.sVarValue.alignment = ['right',' '];
          wPalDS.cbChkContent = wPalDS.add('checkbox',undefined,"Use secondary dialogue");
          wPalDS.btnAdd = wPalDS.add('button',undefined,"Handle content");
        wPalDS.Cancel = wPalDS.add('button',undefined,"Cancel");
        wPalDS.Cancel.onClick = function () {
          wPalDS.close();
          wPalDS.btnAdd.onClick = ButtonAddVarConst;    // externalised callback function!
        wPalDS.show();
      } //---  end PaletteDocSettings
      function ButtonAddVarConst () {
      var bContinue, content;
      // $.bp(true);
        content =  wPalDS.sVarValue.text;
        if (wPalDS.cbChkContent.value) {  // check contents
          gsVariable = "=" + content;
          DialogueVerify();                             // Inner function
          bContinue = wPalV.btnReturn.enabled;
          if (!bContinue) {
            if (Alert ("Test failed, continue anyway?", Constants.FF_ALERT_NO_DEFAULT) != 0) {
              wPalDS.cbChkContent.value = false;        // uncheck
              return;                                   // user clicked NO
          content = gsVariable.substring (1);         // skip the = sign
          wPalDS.sVarValue.text = content;
      } //--- end ButtonAddVarConst
      function DialogueVerify(){ //=== Dialogue for verifying variable contents
        wPalV.st1 = wPalV.add('statictext',undefined,"Content to check");
        wPalV.st1.graphics.font = ScriptUI.newFont(wPalV.st1.graphics.font.family,"BOLD",wPalV.st1.graphics.font.size);
        wPalV.btnReturn = wPalV.add('button',undefined,"OK / Return");
        wPalV.btnReturn.helpTip = "Return to calling dialogue";
        wPalV.Cancel = wPalV.add('button',undefined,"Cancel");
        wPalV.Cancel.alignment = ['right',' '];
        wPalV.btnReturn.onClick =   ButtonReturnV;   // externalised callback function!
        wPalV.Cancel.onClick = function () {
          wPalV.close();
        wPalV.btnReturn.enabled = false;             // test situation 1 (using Cancel to exit)
      //wPalV.btnReturn.enabled = true;              // test situation 2 (using this button to exit)
        wPalV.show();
      function ButtonReturnV () {
        wPalV.close();
      } //---  end ButtonReturnV
      Any ideas are welcome ...
        • 1. Re: Nested dialogue problem
          4everJang Level 3
          Hello Klaus,
          Just move the entire function ButtonReturnV up a couple of lines so that it is inside the function body of the DialogueVerify function. I am not sure why you externalize it, but it seems to throw off the link between the calling dialog and the external function that is working on it.
          Kind regards
          Jang
          • 2. Re: Nested dialogue problem
            K.Daube Level 2
            Hi Jang,
            It would have been too simple - but the result is the same as with the externalised call-back function: tilt in line 48.
            The changed lines from 58 downwards:
            wPalV.btnReturn.onClick = function () {
                wPalV.close();
                wPalV.close();
              wPalV.show();
            Reading Peter Kahrel's pdf about ScriptUI back and forth did not provide the magic information. From a mentioned link (Calling functions from UI palette) I also did not get a clue.
            Taking a break of 4 days now - maybe new ideas will ripe.
            Klaus
            • 3. Re: Nested dialogue problem
              K.Daube Level 2
              Trying various modification I have found a solution:
              • The secondary (nested) dialogue must not use a global definition for the window. It must be within the routine (see line 49).
              • tDue to this the status of the Cancel button is not known outside of wPalV. Hence I need the global variable reflecting it (lines 07, 36, 61)
              With this knowledge I will modify the full-blown script and hope that it works also...
              This works as intended:
              #target framemaker
              // target needed for Alert ...xxx
              var gsVariable;
              var gbOK   = false;
                  wPalDS.close();
                wPalDS.show();
              //  bContinue = wPalV.btnReturn.enabled;
                  bContinue = gbOK;
                  if (!bContinue) {
                gbOK = false;                                   // Outside there is not access to wPalV objects
                  wPalV.close();
                  wPalV.close();
                wPalV.show();
