• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Is it possible to match White Balance in a batch to a certain photo?
New Here ,
Oct 12, 2016 Oct 12, 2016
Hi there.
I have a large batch of photos with slightly varying white balance from shot-to-shot. I want to use these photos in a time-lapse sequence, so need the exposures and white balance to be consistent from shot-to-shot.
I understand that I can use Settings > Match Total Exposures to batch edit a group of photos to match the exposure of the select photo --but this does not seem to affect the white balance of the photos.
I also understand that I can Sync my adjustments to White Balance (as long as I switch to Custom WB).....  But this is not want I want really, I just want to be able to select a group of photos and have Lightroom sync the white balance so they all look the same as a selected photo --just as it does for exposure with the 'Match Total Exposures' function...
Is this possible? Any help greatly appreciated. To make things even more difficult for me I'm moderately red-green colour blind!
Thanks.
Views
21.8K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Oct 12, 2016 Oct 12, 2016
Hi Sminty,
You can sync the white balance setting across multiple photos, which will cause each to have exactly the same white balance setting for temperature and tint.
In your case, it sounds like the scene's color temperature is different from one shot to the next. In that case, you'd need to manually white balance each image. For time lapse images, if the color temperature of the scene's lighting is changing over time, it is a real challenge to post-process a lot of images to yield the appearan
Votes
Translate
Translate
Community Expert ,
Hi Sminty,
In your case, it sounds like the scene's color temperature is different from one shot to the next. In that case, you'd need to manually white balance each image. For time lapse images, if the color temperature of the scene's lighting is changing over time, it is a real challenge to post-process a lot of images to yield the appearance of constant color temperature throughout the sequence.
Mike
Votes
Translate
Translate
Report
Report
New Here ,
Oct 15, 2016 Oct 15, 2016
Oh dear...I'm in a bit of trouble then! Thanks for your clarification!!
Votes
Translate
Translate
Report
Report
LEGEND ,
Lots of good info from Mike.
That said, if you have the same object in every photo that is supposed to be white or a shade of neutral gray, you can use the eye-dropper on that object to set the white balance individually for each photo.
One of the catches here is that if the light is changing in the sequence of photos based on the time of day, then the photos will not look natural if you set them all to the same white balance.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
How I do this is to have the white balance constant throughout the series and then when I assemble the time-lapse from an image sequence in Photoshop (best way to generate the timelapses). Then I do a faded adjustment layer that corrects the white balance over time. If you don't want to go Photoshop for this, Jeffrey Friedl created a very useful plugin that allows you to fade develop settings between two extremes for a series of images: Jeffrey Friedl's Blog » Jeffrey’s “Timelapse Support” Lightroom Plugin​. This allows you to have two extreme white balance settings at the two ends of your time-lapse and fade in between. It can also do pan and zoom although that is much easier done when you assemble the time-lapse in Photoshop.
Votes
Translate
Translate
Report
Report
