1 Reply Latest reply on Oct 12, 2016 9:41 PM by philippanmei
    File type is being saved as either .pdf or .PDF
    OLeCHIT
      Hi, I'm having an issue where the file type for my PDF's are being saved with different punctuation. Some are being saved as .pdf others as .PDF
      Since these are being hosted on my website, the file type needs to be consistent, otherwise it won't show the document if the capitalization is wrong.
      Example: https://c761eecbd79071d9c578-5541377ae4e44cfbbc0efe790ed7f783.ssl.cf1.rackcdn.com/specs/01 0145/709-LPF60-12.pdf  This page won't load, but if you change the .pdf to .PDF it works.
      I can't figure out how to get the PDF's to always save as .pdf
        • 1. Re: File type is being saved as either .pdf or .PDF
          philippanmei Level 4
          While export to PDF or saving to PDF, you have to keep alert to simple one that is in Folder option you to uncheck the option "Hide extension for known file types" (uncheck this option will allows you to see the file extension while you are export to or save to any extension.
          If your file extension is showing up in your satisfaction than hit the button save if not type the extension up to your satisfaction (e.g. File name: Mathur-4.PDF = this type of extension is not your desire one than type to Mathur-4.pdf, it will allow you to change the extension easily)
          Hope it works!!
