10 Replies Latest reply on Nov 17, 2016 3:28 PM by salvadorr91388860
    cloudSky.zBar.scan failing
    smits15019292 Level 1
      For some reason, every time my app call this function, nothing happens
      And if you call it again it says "Scan is already in progress"
      cloudSky.zBar.scan(
        text_title: "OPTIONAL Title Text - default = 'Scan QR Code'", // Android only
        text_instructions: "OPTIONAL Instruction Text - default = 'Please point your camera at the QR code.'", // Android only
        camera: "front" || "back", // defaults to "back"
        flash: "on" || "off" || "auto", // defaults to "auto". See Quirks
        drawSight: true || false //defaults to true, create a red sight/line in the center of the scanner view.
        function (result) {
          alert(result)
        function (error) {
          alert(error);
      org.madmobile.cordovaplugins.zbarscanner
      Please help
        • 1. Re: cloudSky.zBar.scan failing
          ryanskihead Adobe Employee
          What platform are you on? Have you tried connecting a debugger to see if any exceptions occur?
          I'd also suggest getting in touch with the developers, and posting an issue there -- tough for us to debug their plugin.
          • 2. Re: cloudSky.zBar.scan failing
            The issue is only happening on the iOS version it seems
            • 3. Re: cloudSky.zBar.scan failing
              Using PhoneGap Build
              Here is the URL to download the build Adobe PhoneGap Build
              This is what my config.xml says
              <gap:plugin name="org.madmobile.cordovaplugins.zbarscanner" source="npm" />
              What am I missing?
              • 4. Re: cloudSky.zBar.scan failing
                VectorP Level 4
                You didn't really code it exactly this way, did you?
                • 5. Re: cloudSky.zBar.scan failing
                  To be specific,
                  Here is the code in the app
                    cloudSky.zBar.scan(
                    text_title: "SCAN BARCODE", // Android only
                    text_instructions: "RED LINE THROUGH THE ENTIRE BARCODE", //  Android only
                    camera: "back", // "front" || "back" // defaults to "back"
                    flash: "auto", // "on" || "off" || "auto" // defaults to "auto". See Quirks
                    drawSight : "true" //  "true" || "false" //default use true, create a red/green sight to center barcode
                      function (result) {
                      function (error) {
                      alert("Scanning failed: " + error);
                  Which does not have the ||
                  But the || is there in the sample provided on their website
                  The other interesting thing is that the latest release note on npm as per the author was 11 months ago
                  Not sure if PGB uses nightly builds or stable release only
                  Or if there is a way to see and select an older / stable release
                  • 6. Re: cloudSky.zBar.scan failing
                    VectorP Level 4
                    Well, I'm not sure whether or not this is related, but:
                    you have multiple document.ready handlers, and a deviceready eventhandler which is likely to be invoked prior to document.ready. That's very risky, because in your deviceready callback function, you are manipulating the DOM, which may not be completely loaded, yet. This would throw javascript error messages, effectively preventing the scan script to start.
                    You could first try and clean up that construction a bit, in such a way that such unpredictable event handling can't occur.
                    Next: you are correct: the latest plugin release is 11 months ago, and the latest (unanswered) forum entry at their website is from August. It looks like the developers of this plugin are not very active (or may even have given up).
                    I wouldn't even consider picking up an older plugin version...
                    • 7. Re: cloudSky.zBar.scan failing
                      I tried to run the script directly without even worrying about the binding but it just does not want to work
                      This was working in the same app on our last build/test a few months ago so not sure what changed
                      • 8. Re: cloudSky.zBar.scan failing
                        VectorP Level 4
                        ...a few months ago...
                        what PGB version did you use then, and what version now?
                        If those are different, you could downgrade to that previous PGB version and retry for test purposes.
                        • 9. Re: cloudSky.zBar.scan failing
                          Previously it was using 5.2
                          It now uses 6.3
                          Tried reverting to the older version and it still did not work
                          • 10. Re: cloudSky.zBar.scan failing
                            salvadorr91388860 Level 1
                            I am using <gap:plugin spec="https://github.com/tjwoon/csZBar" source="git" /> and works just great on Android and iOS.
