2 Replies Latest reply on Oct 14, 2016 8:53 AM by jasonz82977625
    Total from a checkbox
    jasonz82977625 Level 1
      lest say for this the Bonus = 1 and Modifier = 2
      with no box checked i should get 1
      if i check Pro i get 1 should be 3
      if i check EXP i get 4
         // JavaScript Document
          var x = this.getField("BONUS").value;
          var y = this.getField("Modifier").value;
          if (this.getField("PRO").value === "Yes") {
             this.getField("Total").value === x+y; }
             else
              this.getField("Total").value = y;
         if  (this.getField("EXP").value === "Yes") {
             this.getField("Total").value = x+x+y; }
            else (
          this.getField("T
        • 1. Re: Total from a checkbox
          Are you aware that JavaScript has different operators for testing for equality and setting a value?
          There are 2 equality operators, "==" and "===". The first is for a match the second is for an exact match.
          Values are set by using the "=" operator.
              if (this.getField("PRO").value == "Yes")  // Pro has been selected;
                 this.getField("Total").value = x + y;  // add values for bonus and modifier;
                 else
                       this.getField("Total").value = y; // only modifier;
          • 2. Re: Total from a checkbox
            Thanks good to know added to my notes, self learning JavaScript
            so it should look like this
                var y = this.getField("Modifier").value; //
                if (this.getField("PRO").value == "Yes") // check to see if field = yes
                   this.getField("Total").value = x+y; //should add Var x+x but does not
                   else
                    this.getField("Total").value = y; // if Pro Field does not match Total field will = Y
                if (this.getField("EXP").value == "Yes") // check to see if field = yes
                   this.getField("Total").value = x+x+y; // adds X+X+Y
                   else
                    this.getField("Total").value = y; // if EXP Field does not match Total field will = Y
            When test the each if statement independently they work as soon as i add the second if statement it seem to bypass the first one
