1 Reply Latest reply on Oct 16, 2016 7:33 PM by jingtaotan
    Create Panel in Premiere Pro that performs the same action as a script
    johnt53984649 Level 2
      So I've looked at several examples for Premiere Pro panels, but I'm still somewhat confused.  Let's say I have the following HTML file:
      <!DOCTYPE html>
      <html>
          <head>
              <meta charset="utf-8">
              <title>MyTest</title>
          </head>
          <body>
              <button onclick="myFunction()">Replace Media (BCV)</button>
              <div id="result"></div>
          </body>
      </html>
      This creates a button that I can load into a Premiere Pro panel.  I also have the following code that runs in Premiere just fine when I activate it from ExtendScript:
      var BCV_File_Suffix = ["(PREV).psd", "(BACK).mxf", "(BATT).mxf", "1(NARR)_Fixed.flac", "2(NARR)_Fixed.flac"];
      for (j = 0; j <= 4; j++)
      for (i = 0; i <= app.project.rootItem.children.numItems; i++)
          var BCVchild = app.project.rootItem.children[i];
          if (!BCVchild) continue;
          var mediaPath = BCVchild.getMediaPath();
          if (mediaPath && mediaPath.length > 0 && mediaPath.indexOf(BCV_File_Suffix[j]) > -1)
              var BCVpath = (app.project.path).toString().replace(/\\/g, '\\').replace('\\\\?\\','').replace('(PROJ).prproj',BCV_File_Suffix[j])
              app.project.rootItem.children[i].changeMediaPath(BCVpath);
              app.project.rootItem.children[i].name = app.project.name.replace('(PROJ).prproj',BCV_File_Suffix[j])
      What do I need to change in the HTML file to get the button to activate the script in Premiere Pro?  I'm confused.
        • 1. Re: Create Panel in Premiere Pro that performs the same action as a script
          jingtaotan Level 1
          Hi John,
          You will need to use the CSInterface class provided by Adobe. The CEP Cookbook demonstrates this, located at this URL CEP-Resources/CEP_6.x at master · Adobe-CEP/CEP-Resources · GitHub
          First, download a copy of CSInterface from the URL above. Place it in your extension folder and include it in your HTML.
          In your ExtendScript JSX file, wrap the logic in a function, e.g.:
          function myBcvFunction() {
          Then add the following JavaScript to your panel (not ExtendScript):
          var script = "myBcvFunction()";
          CSInterface.evalScript(script, evalScriptCallback);
          You also need to make sure that the JSX file is referenced from the <ScriptPath> element in the panel extension's manifest.xml, like this:
          <DispatchInfoList>
            <Extension Id="com.YourPanel">
            <DispatchInfo >
            <Resources>
            <MainPath>./index.html</MainPath>
            <ScriptPath>./YourScriptFile.jsx</ScriptPath>
            </Resources>
            </DispatchInfo>
            </Extension>
            </DispatchInfoList>
