5 Replies Latest reply on Oct 18, 2016 5:22 AM by Steve Grisetti
    how to change 4:3 video into a 16:9
    silviah69543173
      Hi guys
      new to video editing and i did not realise that i had to change my phone i was recording on to a higher definition...my video I uploaded onto utube all have a black border around them as i shot in 4:3.  How to i use elements 14 to change the ration to 16:9 widescreen
      I hope someone knows
      many thanks
      Silvia
        • 1. Re: how to change 4:3 video into a 16:9
          What are your Premiere Elements project settings? (You'll find them under the Edit menu.)
          What format is your phone's video? If the video is an MP4 and this MP4 is your first clip on your timeline (the Video 1 track), the program should set up automatically to match your video's specs. (Sometimes the program does not do this with MOV files.)
          Finally, just to be clear, you say that you have black borders "all around them". Is that right? You're not just seeing black bars on the right and left, right? Because these would indicate two very different issues.
          • 2. Re: how to change 4:3 video into a 16:9
            silviah69543173 Level 1
            Good evening Steve
            My settings are:   The black borders are all around.
            Many thanks for your time
            Silvia
            • 3. Re: how to change 4:3 video into a 16:9
              I still need the information I've asked for in order to help you.
              • 4. Re: how to change 4:3 video into a 16:9
                Hi
                Thanks for you time
                Editing mode : HD1080i
                TIME BASE: 29.97 frames/second
                Frame Size: 1920 Horizontal  1080 vertical
                PIXEL ASPECT RATION : Square pixels (1.0)
                Field:  upper field first
                DISPLAY FORMAT: 30fps drop frame time code
                CAPTURE FORMAT: wdm capture
                The format is MP4.  I was using the video size FHD 1920 X 1080
                I have not changed my phone to UHD 3840X2160.
                I have made a new video last night and realised that by clicking and then dragging the arrows I can expand the video to take up all the box.  Hopefully this will make the video full screen when I post it to utube.
                Many thanks
                Silvia
                • 5. Re: how to change 4:3 video into a 16:9
                  If your video is 1920x1080 and your project settings are 1920x1080, you certainly should NOT have to manually resize the video to fit the video frame.
                  So something is wrong in your workflow -- but it's just not obvious what, based on the information you've given me.
