Hi there
It isn't clear to me whether you are referring to bringing
RoboHelp 7 *Source* files or WebHelp *Output* files.
I could see where you may encounter some issues if you are
talking about the source, as these are a bit different than older
versions. I might still expect them to work, but require some
tweaking. If you are talking about the WebHelp output, you should
be able to do that as well. But keep in mind you will need to clean
the files of all the added JavaScript.
Cheers... Rick
