5 Replies Latest reply on Oct 17, 2016 1:34 PM by BetterColour
    Adding (failing to add) a toolbar button in Acrobat DC Pro 15.02
    BetterColour
      Greetings,
      I created a working menu item that removes, or scalps (as my user calls it), the first page of a pdf.
      I am attempting to add this as a toolbar button.
      Following the documentation, I wrote the following code, which I added in the Javascript folder of Acrobat DC Pro (15.02020039).
      I ensured that my jpg used for the icon is 20x20. The dummy pdf is just my business card.
      I placed both the jpg for the icon and the dummy pdf in the Javascript folder.
      I added all this here for your convenience: AddButton - Google Drive
      When I start Acrobat, nothing happens, in terms of having my button anywhere under 'Tools'.
      Being this is my first button... I beg for some guidance
      Here's the code I have:
      var LoadScalpPdfButton = app.trustedFunction( function ()
         if ( typeof LoadScalpPdfButton == "undefined" )
            ScalpPdf = true;
         else
            if (!LoadScalpPdfButton)
               app.removeToolButton("ScalpPdf");
               ScalpPdf = true;
               return;
         if ( ScalpPdf )
            app.beginPriv();
            // Get the path to the user JavaScript folder
            var atbPath=app.getPath({cCategory: "user", cFolder: "javascript"});
            try
               // Try opening the icon doc as in hidden mode, and retrieve its doc
               // object.
               var doc=app.openDoc({
                  cPath: atbPath+"/dummy.pdf", bHidden: true});
               } catch (e) { console.println("Could not open icon file"); return;}
            // Get the icon stream for myIcon1 from the hidden doc
            var iconPath = atbPath+"/scalp.jpg"
            doc.importIcon("scalped", iconPath, 0);
            var oIcon = util.iconStreamFromIcon(doc.getIcon("scalped"));
            // Add a tool button using this icon
            app.addToolButton({
               cName: "ScalpPdf",
               oIcon: oIcon,
               cExec: "ScalpPdf();",
               cTooltext: "Scalp this Pdf",
               nPos: 0
      // Close our hidden document containing the icons.
         doc.closeDoc();
         app.endPriv();
         // Set this variable to signal that the toolbars are installed.
         LoadScalpPdfButton = false;
      var ScalpPdf = app.trustedFunction(function()
         app.beginPriv();
          if (app.activeDocs.length > 0)
            this.deletePages({nStart: 0, nEnd: 0});
            var myDocPath = this.path;
            var aPathComps = myDocPath.split("/");
            aPathComps.pop();
            aPathComps.push("Scalped.pdf");
            var strNewPath = aPathComps.join("/");
            this.saveAs(strNewPath);
         app.endPriv();
      Thank you for your advice.
