4 Replies Latest reply on Oct 18, 2016 5:01 AM by dj_paige
    Keeping Track of Files on MAC
    rdbozz99
      I am using LR 6.7 and use Nikon Transfer 2 to transfer from camera or reader.  Before the transfer, I create the folder name I want to use. I then set it as the destination in Transfer.  Then, when I go to LR to import - the folder I created does not exist.  The images are there - but under a different folder.  My desire is to have s separate folder or subfolder for each session - named for the occasion. What I wind up with is apparently MAC generated or Transfer generated names.  What I am doing wrong?
      THEN  - I want to import the entire folder (as named).  I am winding up with a bunch of folders in LR that I don't recognize.
      Lastly - forgive me - When I have finished adjusting in LR - do I have to save, export, or will the pic automatically carry the adjustments?
        • 1. Re: Keeping Track of Files on MAC
          ManiacJoe Adobe Community Professional
          Nikon Transfer 2 would not be my first choice in transfer software, but if it is working for you, OK.
          After the files are transferred to your hard drive, using Finder go to the new directory and verify its contents.
          Rename the folder if you so desire. Move the folder to its final resting place as needed.
          From Lightroom, make sure your import type is "add" to do an in-place import with no file moving/copying.
          Your images are not "in" Lightroom. The images are on the hard drive just like your documents. Lightroom references the images by path and filename.
          Your edits exist only in the Lightroom catalog. If you want to see the edits outside of Lightroom, you need to export the edits into new image files. Lightroom does not make updates to the original files.
          Each of my shooting events are in folders named like yyyymmdd_event_name.
          Under that folder are subfolders called "originals" and "exports" containing the respective image files.
          • 2. Re: Keeping Track of Files on MAC
            dj_paige Level 10
            Show us a screen capture of the problem in Lightroom. Show us another screen capture of what you see in your operating system.
            Are you importing into Lightroom using the ADD option? You should be. You should not be choosing the COPY option in this case.
            The whole process of using Capture NX and then Lightroom is very inefficient, I would just use LR and import to the desired folder.
            See Lightroom 5: Importing Your Images - YouTube
            • 3. Re: Keeping Track of Files on MAC
              rdbozz99 Level 1
              Many thanks for the help.  You said Nikon Transfer would not be your choice.  Can I just use LR for import?  Or what software do you recommend?  I have Bridge - but frankly I don''t even know it's purpose.  Thanks again.
              • 4. Re: Keeping Track of Files on MAC
                dj_paige Level 10
                Use Lightroom to import. I have given you a link to a tutorial on this.
