3 Replies Latest reply on Oct 19, 2016 10:48 PM by George_Johnson
    How do I calculate this?
    jant45441726 Level 1
      Have field (Criteria) and a fillable field (Dim) and a result field.
      Some of fillable field should be in the range of Criteria +/- 2,5%
      and other in the range of +6/-2.
      Please help
        • 1. Re: How do I calculate this?
          Your question is not clear.
          Please restate yuor question.
          • 2. Re: How do I calculate this?
            I have a testsheet with some criteria and tolerances, what I can´t figure out is how to calculate that the result measured is within tolerances A (228mm +6mm -3mm)
            I have fields where the tolerances are within +/- 2,5%
            In the accepted field I have this calculated script:
            event.target.fillColor = color.transparent
            var dadiff = Math.abs(this.getField("Dim A").value - this.getField("Criteria A").value) ;
            if (dadiff <= 3) {
            event.value = "OK" ;event.target.fillColor = color.green ;
            } else {
            event.value = "Not OK" ;event.target.fillColor = color.red ;
            That works when the tolerances are with in the same area in + and -
            Could you please help me.
            • 3. Re: How do I calculate this?
              George_Johnson MVP & Adobe Community Professional
              For that first one, it seems like this should be correct:
              var mid = 228;
              var max = mid + 6;
              var min = mid - 3;
              var val = +getField("Dim A").value;
              if (val <= max && val >= min) {
                  event.value = "OK";
                  event.target.fillColor = color.green;
              } else {
                  event.value = "Not OK";
                  event.target.fillColor = color.red;
