0 Replies Latest reply on Feb 24, 2009 2:25 PM by SiHoop
    Passing data between swfs
    SiHoop Level 1
      I’ve been trying for the past 2 days to pass variables between two swf files. I can now use a LocalConnection to do this if I simply link the two swfs, but not when I try to embed one swf in the other. The code below works if I comment out the following line and place the localConnection.send method immediately below it (as long as the second swf is already running).
      //loader.load(request);
      conn.send("myConnection", "lcHandler", parameters.loginID);
      However, if I switch the comments,
      //conn.send("myConnection", "lcHandler", parameters.loginID);
      the second swf loads into the first swf, but I get errors as soon as I try to interact with any of the menus/ buttons in the embedded swf. Here’s the error message:
      TypeError: Error #1009: Cannot access a property or method of a null object reference.
      I think that the components have not loaded fully in the swf but don’t know how to test this or write an appropriate event handler. Below is my full code in the main file.
