4 Replies Latest reply on Oct 19, 2016 1:11 AM by EnsilZah_
    Open New Document Dialog
    EnsilZah_ Level 1
      How do I open the new document dialog?
      I've tried the script listener but it didn't seem to help.
      I assume it can be done using app.runMenuItem() but I don't know the menuid.
        • 1. Re: Open New Document Dialog
          Jarda Bereza Level 4
          var idOpn = charIDToTypeID( "Opn " );
          executeAction( idOpn, undefined, DialogModes.NO );
          Record action and then you see code in script listener
          http://sklad.bereza.cz/00-jarda/00_screenshot/2016-10-18_185756.jpg
          http://sklad.bereza.cz/00-jarda/00_screenshot/2016-10-18_185809.jpg
          • 2. Re: Open New Document Dialog
            mauricior6328708 Level 1
            #target photoshop
            cTID = function(s) { return app.charIDToTypeID(s); };
            sTID = function(s) { return app.stringIDToTypeID(s); };
              // New Doc
            function NewDoc() {
              // Make
              function step1(enabled, withDialog) {
                if (enabled != undefined && !enabled)
                  return;
                var dialogMode = (withDialog ? DialogModes.ALL : DialogModes.NO);
                var desc1 = new ActionDescriptor();
                var desc2 = new ActionDescriptor();
                desc2.putClass(cTID('Md  '), sTID("RGBColorMode"));
                desc2.putUnitDouble(cTID('Wdth'), cTID('#Rlt'), 570);
                desc2.putUnitDouble(cTID('Hght'), cTID('#Rlt'), 380.16);
                desc2.putUnitDouble(cTID('Rslt'), cTID('#Rsl'), 300);
                desc2.putDouble(sTID("pixelScaleFactor"), 1);
                desc2.putEnumerated(cTID('Fl  '), cTID('Fl  '), cTID('Wht '));
                desc2.putInteger(cTID('Dpth'), 8);
                desc2.putString(sTID("profile"), "none");
                desc1.putObject(cTID('Nw  '), cTID('Dcmn'), desc2);
                desc1.putInteger(cTID('DocI'), 850);
                executeAction(cTID('Mk  '), desc1, dialogMode);
              step1(true, true);      // Make
            NewDoc.main = function () {
              NewDoc();
            NewDoc.main();
            • 3. Re: Open New Document Dialog
              Chuck Uebele Adobe Community Professional & MVP
              Below is the scriptlistener code. You need to change the last line to turn on the dialog box if you wantto see it.
              var idMk = charIDToTypeID( "Mk  " );
                  var desc4 = new ActionDescriptor();
                  var idNw = charIDToTypeID( "Nw  " );
                      var desc5 = new ActionDescriptor();
                      var idMd = charIDToTypeID( "Md  " );
                      var idRGBM = charIDToTypeID( "RGBM" );
                      desc5.putClass( idMd, idRGBM );
                      var idWdth = charIDToTypeID( "Wdth" );
                      var idRlt = charIDToTypeID( "#Rlt" );
                      desc5.putUnitDouble( idWdth, idRlt, 2160.000000 );
                      var idHght = charIDToTypeID( "Hght" );
                      desc5.putUnitDouble( idHght, idRlt, 1440.000000 );
                      var idRslt = charIDToTypeID( "Rslt" );
                      var idRsl = charIDToTypeID( "#Rsl" );
                      desc5.putUnitDouble( idRslt, idRsl, 72.000000 );
                      var idpixelScaleFactor = stringIDToTypeID( "pixelScaleFactor" );
                      desc5.putDouble( idpixelScaleFactor, 1.000000 );
                      var idFl = charIDToTypeID( "Fl  " );
                      var idWht = charIDToTypeID( "Wht " );
                      desc5.putEnumerated( idFl, idFl, idWht );
                      var idDpth = charIDToTypeID( "Dpth" );
                      desc5.putInteger( idDpth, 8 );
                      var idprofile = stringIDToTypeID( "profile" );
                      desc5.putString( idprofile, """sRGB IEC61966-2.1""" );
                  var idDcmn = charIDToTypeID( "Dcmn" );
                  desc4.putObject( idNw, idDcmn, desc5 );
                  var idDocI = charIDToTypeID( "DocI" );
                  desc4.putInteger( idDocI, 195 );
              //executeAction( idMk, desc4, DialogModes.NO ); change this line to the following line
              executeAction( idMk, desc4, DialogModes.ALL );
              app.displayDialogs = DialogModes.NO; //make sure you turn the dialogs off again!!!!
              • 4. Re: Open New Document Dialog
                EnsilZah_ Level 1
                Thanks.
                I cut it down to the minimum I could since I just need it to trigger the dialog and not change the previous values inside it.
                desc1.putObject(cTID('Nw  '), cTID('Dcmn'), new ActionDescriptor());
                try{executeAction(cTID('Mk  '), desc1, DialogModes.ALL);}catch(e){}
