2 Replies Latest reply on Oct 18, 2016 9:46 AM by jmrowlands
    The variable WindowPosition is not defined. number -2753 from "WindowPosition"
    jmrowlands
      I am working to move a script to Adobe Illustrator 2015 (20.1.0) from 2014 (18.0). I am not the author of this script and struggling to learn scripting of this level. Error is in line 72. "The variable WindowPosition is not defined." number -2753 from "WindowPosition"
      tell application "Adobe Illustrator"
        set clicker to {23, 46}
        --set user interaction level to interact with all
        try
        if contents of selection is not "Client" then
        error number -128
        end if
        on error
        display dialog "Please select the word \"Client\"" giving up after 1.5
        error number -128
        end try
        activate
        set x to properties of selection
        delay 0.15
        tell application "System Events"
        keystroke "a" using command down
        end tell
        redraw
        set y to properties of selection
        set TheContent to contents of y
        set TheSize to size of x
        set TheSelection to item 1 of selection of y
        set TheContainer to container of y
        set selection to {}
        --set selection to page item 1 of document 1
        redraw
        tell document 1
        set TheFrame to every text frame whose contents is TheContent
        end tell
        --say "window"
        tell process "Adobe Illustrator"
        --beep
        set frontmost to true
        my do_submenu("Adobe Illustrator", "Window", "Tools", "Default")
        set Sizes1 to size of every window
        set Sizes2 to size of every window
        --beep
        if length of Sizes1 is not length of Sizes2 then
        if length of Sizes1 is greater than length of Sizes2 then
        set TheSize to item 1 of my RemoveComonList(Sizes1, Sizes2)
        else
        set TheSize to item 1 of my RemoveComonList(Sizes2, Sizes1)
        end if
        --beep
        set TOOLS to every window whose size is TheSize
        if TOOLS is {} then
        end if
        --beep
        tell item 1 of TOOLS
        set WindowPosition to position
        set item 1 of WindowPosition to (item 1 of WindowPosition) + (item 1 of clicker)
        set item 2 of WindowPosition to (item 2 of WindowPosition) + (item 2 of clicker)
        end tell
        end if
        end tell
        end tell
        --say "Click"
        my MouseClick(item 1 of WindowPosition, item 2 of WindowPosition, 1)
        delay 1
        set TheContent to contents of the selection
        --beep
        set TheContent to my stringtolist(TheContent, return)
        set TheResult to {}
        set eventDate to current date
        set dayInteger to day of eventDate as integer as string
        set monthInteger to month of eventDate as integer as string
        set yearInteger to year of eventDate as integer as string
        if (count of every character of dayInteger) is 1 then
        set dayInteger to "0" & dayInteger
        end if
        end if
        if (count of every character of monthInteger) is 1 then
        set monthInteger to "0" & monthInteger
        end if
        set yearInteger to (items 3 through 4 of every character of yearInteger) as string
        set dateString to monthInteger & "." & dayInteger & "." & yearInteger
        --beep
        ----PRINT SCALE
        set SlugContents to my stringtolist(TheContent, return)
        set SlugBlack to {cyan:0.0, magenta:0.0, yellow:0, black:100}
        set AutoSlugList to {"xscalex", "xdateLRx", "xfilex", "xjobdescx", "xjobx", "xdateAx", "xdiex", "xdiesizex"}
        set ArtboardDims to artboard rectangle of artboard 1 of document 1
        set theWidth to width of document 1
        set theHeight to height of document 1
        set ThePath to file path of document 1
        set Parentfolder to item 2 of my FolderPathtoList(ThePath, 0, 1)
        --set xjobx to items 1 thru 10 of every item of Parentfolder as string
        set xjobx to item 1 of my stringtolist(Parentfolder, " ")
        set xjobdescx to items ((count of every item of xjobx) + 2) thru (count of every item of Parentfolder) of every item of Parentfolder as string
        set xfilex to name of document 1
        if theWidth is greater than theHeight then
        set ScaleV to round (776 / theHeight * 100)
        set scaleH to round (1198 / theWidth * 100)
        if scaleH is greater than ScaleV then
        set PrintScale to ScaleV
        else
        set PrintScale to scaleH
        end if
        else
        set ScaleV to round (1198 / theHeight * 100)
        set scaleH to round (776 / theWidth * 100)
        else
        end if
        end if
        if PrintScale > 99 then
        set PrintScale to 100
        end if
        set xscalex to PrintScale & "%"
        --beep
        set this_text to name of document 1
        set THE_TEXT to this_text as string
        -----------------------------Name Switch
        set userName to long user name of (system info)
        set userName to my name_switch(userName, "afelch", "AF")
        set userName to my name_switch(userName, "jrowlands", "JR")
        set userName to my name_switch(userName, "bpope", "BP")
        set userName to my name_switch(userName, "rbaer", "RB")
        set userName to my name_switch(userName, "bkoski", "BK")
        set userName to my name_switch(userName, "jelkins", "JE")
        set xdateLRx to dateString & " " & userName as string
      set thedisplay to {"Job: ", xjobx as string, return, "Description: ", xjobdescx, return, "File: ", xfilex, return, "Artist: ", xdateAx, return, "Last Rev: ", xdateLRx, return, "Print Out Date: ", xdatePOx, return, "Proof Scale: ", xscalex}
        display dialog (thedisplay as string) buttons {"Cancel", "Continue"} default button 2
        repeat with fr from 1 to count of AutoSlugList
        try
        set fill color of every character of every word of text frame (item fr of AutoSlugList) of current document to SlugBlack
        on error
        set xfilex to false
        end try
        end repeat
        --beep
        set prejob to "Job#: "
        set prefile to "File Name: "
        set predatelr to "Last Revision: "
        set prescale to "ART IS: 100%  PROOF IS: "
        set end of TheResult to item 1 of TheContent
        set end of TheResult to return
        set end of TheResult to prejob & xjobx
        set end of TheResult to xjobdescx
        set end of TheResult to "File Name: " & xfilex
        set end of TheResult to item 5 of TheContent
        set end of TheResult to "Last Revision: " & xdateLRx
        set end of TheResult to item 7 of TheContent
        set end of TheResult to item 8 of TheContent
        set end of TheResult to item 9 of TheContent
        set end of TheResult to item 10 of TheContent
        set end of TheResult to item 11 of TheContent
        set end of TheResult to prescale & xscalex
        set TheResult to TheResult as string
        display alert TheResult
        set contents of item 1 of TheFrame to TheResult
        my ChangeFont(1, length of TheResult, "HelveticaNeueLTStd-Cn", index of TheContainer)
        set theStart to 1
        set theEnd to 7
        my ChangeFont(theStart, theEnd, "HelveticaNeueLTStd-HvCn", index of TheContainer)
        set theStart to (length of item 1 of TheContent) + 1
        set theEnd to theStart + (length of prejob)
        set theStart to theEnd + (length of xjobdescx) + (length of xjobx) + 2
        set theEnd to theStart + (length of prefile)
        set theStart to theEnd + (length of xfilex) + 2
        set theEnd to theStart + 13
        set theStart to theEnd + (length of item 5 of TheContent) - 13
        set theEnd to theStart + (length of predatelr)
        set theStart to theEnd + (length of xdateLRx) + 1
        set theEnd to theStart + (15)
        set theStart to theEnd + (length of item 7 of TheContent) - 14
        set theEnd to theStart + 6
        set theStart to theEnd + (length of item 8 of TheContent) - 5
        set theStart to theEnd + (length of item 9 of TheContent) - 5
        set theEnd to theStart + (length of item 10 of TheContent) + 13
        set theStart to theEnd + (length of item 11 of TheContent) - 11
        set theEnd to theStart + 8
        set theStart to theEnd + 5
        set theEnd to theStart + 10
        --display dialog "Please select the word \"Client\"" giving up after 0.5
      end tell
      on RemoveComonList(list1, list2)
        set list3 to {}
        set templist1 to {}
        set templist2 to {}
        repeat with fr from 1 to count of list1
        set end of templist1 to item fr of list1 as string
        end repeat
        --set templist1 to reverse of templist1
        repeat with fr from 1 to count of list2
        set end of templist2 to item fr of list2 as string
        end repeat
        --set templist2 to reverse of templist2
        repeat with x from 1 to count of items of list1
        repeat with y from 1 to count of list1
        set n to item y of templist1
        if n is not in templist2 then set end of list3 to item y of list1
        end repeat
        end repeat
        return list3
      end RemoveComonList
      on do_submenu(app_name, menu_name, menu_item, submenu_item)
        try
        -- bring the target application to the front
        tell process app_name
        tell menu bar 1
        tell menu bar item menu_name
        tell menu menu_name
        tell menu item menu_item
        tell menu menu_item
        click menu item submenu_item
        end tell
        end tell
        end tell
        end tell
        end tell
        end tell
        end tell
        return true
        on error error_message
        return false
        end try
      end do_submenu
      on FolderPathtoList(myPath, TrimFront, TrimBack)
        set FolderPath to {}
        ----beep
        set oldDelimiters to AppleScript's text item delimiters -- always preserve original delimiters
        ----beep
        set AppleScript's text item delimiters to {":"}
        set pathItems to text items of (myPath as text)
        ----beep
        set TF to (TrimFront as number) + 1
        set TB to ((count of pathItems) - TrimBack as integer) as integer
        set AppleScript's text item delimiters to oldDelimiters
        return items TF thru TB of pathItems as list
      end FolderPathtoList
      on name_switch(theVariable, Old, new)
        if theVariable is Old then
        set theVariable to new
        else
        set theVariable to theVariable
        end if
      end name_switch
      on stringtolist(TheString, TheDelimiter)
        set theList to {}
        set AppleScript's text item delimiters to TheDelimiter as list
        set theList to text items of (TheString as text)
        return theList
      end stringtolist
      on ChangeFont(CharStart, CharEnd, TheFont, TheStory)
        set text font of text from character CharStart to character CharEnd of story TheStory of document 1 to text font TheFont
        end tell
      end ChangeFont
      on MouseClick(x, y, MouseButton)
        do shell script "
      /usr/bin/python <<END
      import sys
      import time
      from Quartz.CoreGraphics import *
      def mouseEvent(type, posx, posy):
                theEvent = CGEventCreateMouseEvent(None, type, (posx,posy), kCGMouseButtonLeft)
                CGEventPost(kCGHIDEventTap, theEvent)
      def mousemove(posx,posy):
                mouseEvent(kCGEventMouseMoved, posx,posy);
      def mouseclick(posx,posy):
                mouseEvent(kCGEventLeftMouseDown, posx,posy);
                mouseEvent(kCGEventLeftMouseUp, posx,posy);
      ourEvent = CGEventCreate(None);
      currentpos=CGEventGetLocation(ourEvent);             # Save current mouse position
      mouseclick(" & x & "," & y & ");
      mousemove(int(currentpos.x),int(currentpos.y));      # Restore mouse position
      END"
      end MouseClick
