I'm sorry to dredge up an old question line, but I'm hoping some factors have changed. Here's the issue:
Has anyone played with the combo of Captivate 9 and SharePoint?
Sharepoint often causes issues with Captivate output. Your HTML5 JSON files need to be added as a mimetype that is allowed by the server. But Sharepoint doesn't really behave like a web server and HTML5 files DO really need to be delivered from a web server environment.
If you only need a fairly short-term solution for delivering content, even if you don't need reporting, I recommend you just use SCORM Cloud in the interim. It's economical and it works very well.
Thanks for the quick and always-helpful answer, Rod. Having to use a non-LMS environment for training materials is definitely not my preferred method. SCORM Cloud is a great suggestion, but I can't take these sensitive materials outside our "walls". I'm going to play with some other options to see what might work.
Thanks, again. I can always count on you for the voice of reason.
Mary
Just as a followup, my projects published as SWF (with no reporting) work in the SharePoint environment. Only the HTML5 versions are an issue.
That figures. As I said above, HTML5 always needs a web server, and Sharepoint isn't.
