5 Replies Latest reply on Oct 20, 2016 12:25 AM by ssprengel
    Need help with Fuji RAW Editing in Lightroom/Camera RAW
    CodySaunders
      I cant seem to find a helpful forum post on this subject. I shoot with a Fuji X-T2 and when I import my RAF files into either Camera RAW or Lightroom it auto tones them and makes them super underexposed. I get a glimpse of the correct look and then a second later it tones the picture. I have tried to change the develop import settings with no luck. Ive seen someone mention that having Dynamic Range set to Auto in camera is to blame for this since Adobe doesn't seem to import the info built into the RAW File. Does anyone have any idea on how to import these X-T2 files without the program screwing it up? Or do I have to just edit every photo to the right exposure? Considering trying Capture One Pro or something.
      Here is an example of the out of camera JPG (shot RAW+JPG) and the same photo after being imported.
        • 1. Re: Need help with Fuji RAW Editing in Lightroom/Camera RAW
          ssprengel Adobe Community Professional & MVP
          I believe your issue is that you shot using AutoDR (auto-dynamic-range) mode were the camera shoots a little darker or a lot darker to preserve highlights and then digitally brightens just the shadows by the same but variable amount it underexposed by when it produces its own JPGs.  LR is showing you the actual underexposure the camera did without trying to compensate.
          I think LR will artificially brighten DR shots that are done using one of the constant DR modes, like DR200 or DR400, but won’t try to compensate when each shot can be underexposed by a varying amount.
          If you want to use Adobe products to process your Fuji photos, either turn off any DR modes or at least don’t use AutoDR.
          Interestingly in your example side-by-side, I actually like the LR one better but I am assuming the suit was black but if it was gray then the LR one is darker than the subject looked in real life, but that is because the camera actually underexposed the shot.
          If you didn’t have AutoDR set then something else might be going on, and it would be useful to have both the raw and the jpg originals to test with, which you can provide by uploading to somewhere like dropbox.com and posting a public share link to each in a message, here.
          • 2. Re: Need help with Fuji RAW Editing in Lightroom/Camera RAW
            CodySaunders Level 1
            I think I did have the DR on Auto which would make sense, but it should be carried over to Lightroom/RAW which is annoying. This comparison wasn't a very good one to pick since it was outside but all the ones indoors were way underexposed after the import and I have to correct everyone by upping the exposure and shadows. Not a huge deal since I can just do them in batches but a pain.
            Here a good example, taken with low lighting at F1.4 the top one is the RAW file with DR Auto. Second photo is after its been imported. Its a shame that the in camera processes dont get carried over to Adobes editing programs. I guess Ill try some other ones such as Capture One and see if it does the same thing. Ill keep DR Auto off next time around. It also seems like the photos are a lot softer as well, hopefully Adobe makes Lightroom more friendly to Fujis RAF files.
            • 3. Re: Need help with Fuji RAW Editing in Lightroom/Camera RAW
              Adobe usually ignores all camera settings other than WB and crop-factor so they are doing extra just to get DR200 and DR400 to work.  On my Canon DSLR if I have highlight-tone-priority turned on, which is similar to Auto-DR on the Fuji, I get dark images.
              I will never get a Fuji with the X-trans sensor, because Adobe’s processing isn’t optimized for it.
              • 4. Re: Need help with Fuji RAW Editing in Lightroom/Camera RAW
                With how popular the Fuji cameras are becoming they should probably work on allowing Lightroom and RAW to use those settings. I think for this shoot ill edit in a different program and then turn off Auto DR for future shoots until they fix it. Thanks for the help in figuring out what it was doing.
                • 5. Re: Need help with Fuji RAW Editing in Lightroom/Camera RAW
                  From Adobe's point-of-view there's nothing to fix, I don't think.
