14 Replies Latest reply on Oct 24, 2016 10:23 AM by charur94718007
    Create groups in Indesign
    charur94718007 Level 2
      Screen Shot 2016-10-20 at 2.18.45 PM.pngHello All, Is there any script to create n number of  groups in a document with a gap of 20 pts. First group must start with top corner of the page and second will align next to first with gap of 20 pts. And so on.. But when it touches the right corner of the documents then next group must be in another row. I have attached the sample image what is the requirement. I want to calculate number of rows and columns required to place n number of groups with a gap of 20 pts.
        • 1. Re: Create groups in Indesign
          tpk1982 Level 4
          We can do by script.. but did you tried with step and repeat method?
          • 2. Re: Create groups in Indesign
            Obi-wan Kenobi Level 5
            Hi Kartik,
            Not with this feature because it can't calculate the width/height of the frame!
            see: Create rectangles in Indesign
            • 3. Re: Create groups in Indesign
              tpk1982 Level 4
              Thanks Obi.. I thought OP will create rectangle with his desired values..
              • 4. Re: Create groups in Indesign
                If, you're right! If not, not!  Aha!
                See another cool way on other topic!
                • 5. Re: Create groups in Indesign
                  No, I have not tried. I need a script. This is small part of my Indesign plugin. So definitely need to do by script
                  • 6. Re: Create groups in Indesign
                    tpk1982 Level 4
                    Please get the Obi mentioned script from the below path
                    Novelty/Frame_Divider.jsx at master · GitBruno/Novelty · GitHub
                    • 7. Re: Create groups in Indesign
                      Is this necessary to give number of rows and columns in adavance???
                      • 8. Re: Create groups in Indesign
                        S Hopkins Adobe Community Professional
                        Yep,
                        You either need to know the size of each element (width and height) or number of rows and columns.
                        Shirley Hopkins
                        • 9. Re: Create groups in Indesign
                          Yes I know width and height of the element. But not know in advance number of rows and columns. I want a formula to calculate number of rows and columns required based on width and height of the element and considering each element should be 20pts. apart.
                          • 10. Re: Create groups in Indesign
                            See the DOM documentation for Page:
                            Adobe InDesign CS6 (8.0) Object Model JS: Page
                            Property bounds
                            is giving you the size of the page
                            If the page is not resized with the Page Tool maybe its easier to check for:
                            Adobe InDesign CS6 (8.0) Object Model JS: DocumentPreference
                            Properties:
                            pageHeight
                            pageOrientation
                            pageWidth
                            And  corresponding:
                            Adobe InDesign CS6 (8.0) Object Model JS: MarginPreference
                            The properties of
                            page.marginPreferences
                            bottom
                            right
                            left
                            top
                            That will give you the base for your calculations of the width and the height of the available area.
                            Regards,
                            Uwe
                            • 11. Re: Create groups in Indesign
                              Think of it this way: you will have one more element (page item) than you will have gutters (space between horizontally). This also applies for elements vertically (one more element than gaps (space between vertically). Thus you can subtract the width of 1 element from the width of the page and then divide that by the width of the element plus that of the space between).
                              Here is the calculation written in AppleScript and JavaScript (have your script calculate the values for the arbitrary values below and you have it):
                              AppleScript
                              set pwid to 400 --page width
                              set phgt to 800 --page height
                              set iwid to 30 -- item width
                              set ihgt to 40 -- item height
                              set gutter to 20 -- space between horizontally
                              set gap to 20 -- space between vertically
                              set numColumns to round ((pwid - iwid) / (iwid + gutter)) rounding down
                              set numRows to round ((phgt - ihgt) / (ihgt + gap)) rounding down
                              {numColumns, numRows}
                              JavaScript
                              var pwid = 400; //page width
                              var phgt = 800; //page height
                              var iwid = 30; //item width
                              var ihgt = 40; //item height
                              var gutter = 20; //space between horizontally
                              var gap = 20; //space between vertically
                              var numColumns = Math.floor((pwid - iwid)/(iwid + gutter));
                              var numRows = Math.floor((phgt - ihgt)/(ihgt + gap));
                              [numColumns, numRows];
                              • 12. Re: Create groups in Indesign
                                Thanks SHopkins.. This is right and thanks a lot for helping me to calculate rows and columns. One also written one script for the same. I am sharing with you. I need to handle the case if page is finished. Here is the script. You can see and let me know your suggestions as well about this. Before running the script please ensure that you one selected item.
                                var firstPage = app.documents[0].pages;
                                var margin = firstPage[0].marginPreferences.top;
                                var pgWidth = firstPage[0].bounds[3] - firstPage[0].bounds[1] - (margin * 2);
                                var pgheight = firstPage[0].bounds[2] - firstPage[0].bounds[0] - (margin * 2);
                                var pgX1 = firstPage[0].bounds[1] + margin;
                                var pgY1 = firstPage[0].bounds[0] + margin;
                                var objectWidth = app.selection[0].geometricBounds[3] - app.selection[0].geometricBounds[1];
                                var objectHeight = app.selection[0].geometricBounds[2] - app.selection[0].geometricBounds[0];
                                app.selection[0].move([pgX1, pgX1]);
                                var gutter = 20;
                                var gap = 20;
                                var row = 1;
                                var col = 1;
                                for (var i = 1; i < 40; i++) {
                                  var lastObject = app.selection[0];
                                  var mY1 = lastObject.geometricBounds[0];
                                  var mX1 = lastObject.geometricBounds[3] + gutter;
                                  var newObject = app.selection[0].duplicate();
                                  app.selection[0] = null;
                                  app.selection = newObject;
                                  newObject.move([mX1, mY1]);
                                  if (newObject.geometricBounds[3] > (firstPage[0].bounds[3] - margin)) {
                                    newObject.move([pgX1, (objectHeight * row) + (gap * row) + margin]);
                                    row++;
                                  if (newObject.geometricBounds[0] + objectHeight > pgheight) {
                                    var newPage = app.documents[0].pages.add(LocationOptions.AT_END);
                                    var margin = newPage.marginPreferences.top;
                                    pgWidth = newPage.bounds[3] - newPage.bounds[1] - (margin * 2);
                                    pgheight = newPage.bounds[2] - newPage.bounds[0] - (margin * 2);
                                    pgX1 = newPage.bounds[1] + margin;
                                    pgY1 = newPage.bounds[0] + margin;
                                    newObject.move(newPage);
                                    newObject.move([pgX1, pgY1]);
                                    row = 1;
                                • 13. Re: Create groups in Indesign
                                  I see a number of potential problems with the code above: you are assuming that margins are the same hich may not be the case. Also, necessity for lots of if/then tests. The code below uses the calculation for number rows and columns to handle the duplication. Also, it's a good example of nested for loops. It does not add pages, but you can do that.  Try it.
                                  var sel = app.selection;
                                  if (sel.length == 0) {
                                  alert ("Requires page item selection");
                                  var gutter = 20;
                                  var gap = 20;
                                  app.scriptPreferences.measurementUnit = MeasurementUnits.POINTS;
                                  var selObj = sel[0];
                                  var pageRef = selObj.parentPage;
                                  var pageBounds = pageRef.bounds;
                                  var mPref = pageRef.marginPreferences;
                                  var pMargins = [mPref.top, mPref.left, mPref.bottom, mPref.right];
                                  pWid = (pageBounds[3]-pageBounds[1]) - (pMargins[1] + pMargins[3]);
                                  pHgt = (pageBounds[2]-pageBounds[0]) - (pMargins[0] + pMargins[2]);
                                  var objBounds = selObj.geometricBounds;
                                  var objWid = objBounds[3] - objBounds[1];
                                  var objHgt = objBounds[2] - objBounds[0];
                                  var numColumns = Math.floor((pWid - objWid) / (objWid + gutter));
                                  var numRows = Math.floor((pHgt - objHgt) / (objHgt + gap));
                                  var moveX = (objWid + gutter);
                                  var moveY = (objHgt + gap);
                                  var y0 = pMargins[0];
                                  var x0 = pMargins[1];
                                  for (var j = 0; j <= numRows; j++) {
                                     for (var i = 0; i <= numColumns; i++) {
                                         var dupObj = selObj.duplicate();
                                         dupObj.move([x0, y0]);
                                         x0 = x0 + moveX;
                                  x0 = pMargins[1];
                                  y0 = y0 + moveY;
                                  selObj.remove();
                                  • 14. Re: Create groups in Indesign
                                    Thanks S Hopkins, for adding more check. I am glad that you correct my script. Thanks a alot.. :) :)
