6 Replies Latest reply on Oct 21, 2016 9:42 AM by Peter Spier
    Regex for Logical AND
    ariva38817767 Level 1
      In regex same like logical OR(|), I wanted to perform logical AND operation.  For example
      asdfdf book asdfasdf pen asdfdsf
      dsffds book sdfasdfdsaf asdfds
      sdfdf pen dsfdaf sdafdsf
      dsfdsf pen adsfdsf book
      if book & pen or pen & book matched only I wanted to process further.
      if in any line only book or only pen is there nothing I want.
      Can any one help on this.
      Ariv
        • 1. Re: Regex for Logical AND
          Obi-wan Kenobi Level 5
          Hi Ariv,
          This first regex will only find paras with the 2 words "book" and "pen"!
          it doesnt if not or only if one of them!
          (?=.*?\bbook\b).*?\bpen\b.*
          This second one will only find paras with the 2 words "book" and "pen" and the words group "cup of coffee"!
          (?=.*?\bbook\b)(?=.*?\bpen\b).*?cup of coffee.*
          • 2. Re: Regex for Logical AND
            I believe this one will find either:
            book[^\r]+?pen|pen[^\r]+?book
            • 3. Re: Regex for Logical AND
              Though it might be a good idea to add word boundaries to avoid finding "open your notebooks."
              So \bbook\b[^\r]+?\bpen\b|\bpen\b[^\r]+?\bbook\b
              Not as elegant as Obi-wan's but easier to understand, I think.
              • 4. Re: Regex for Logical AND
                Peter,
                Really less cool and doable with this list:
                fairy / demon(s) / witch / fire / hell / night / ghost / Halloween
                Code:
                (?=.*?\bfairy\b)(?=.*?\bdemons?\b)(?=.*?\bwitch\b)(?=.*?\bfire\b)(?=.*?\bhell\b)(?=.*?\bnight\b)(?=.*?\bghost\b).*?Halloween\b.*
                • 5. Re: Regex for Logical AND
                  Skemicle Level 3
                  Peter, your codes will only select anything between the two words not the full paragraph. you would need to add '.*?' to the beginning and end of both strings for the full paragraph.. quite a bit more coding than Obi-wans solution, but until I saw Obi-wan's expression that is how I would have done it as well . Also when i first saw Obi-wan's expression my first thought was "Yeah but that only finds the paragraph if the word 'book' comes before 'pen'. Though upon investigating the order doesn't matter seeing as how the search for each word starts at the beginning of the paragraph and not from the last word found.
                  • 6. Re: Regex for Logical AND
                    My presumption is that you would apply a paragraph style, and for that you don't need to select the entire paragraph.
