• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Extra text flows around tables in document imported from Word
Explorer ,
Oct 20, 2016 Oct 20, 2016
Hi Folks,
I'm trying to set up a reproducible process for importing all our Word files into FrameMaker. I've got it mostly done (thanks largely to tips found here!) but am still struggling with getting the tables to come over well.
My problem is that the table seems to show up in its own flow, which results in more space than I want between the the table and the paragraph above it.  Is there a way to either import it in the same flow as the main text or to move all the content into a single flow after the import? Screenshot attached.
Views
148
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer , Oct 20, 2016 Oct 20, 2016
OK, that^ wasn't the answer. The problem was not a text flow but a text /frame/, which FM was putting in for a table title. To get rid of it, I just edited the table format definition (Table>Format>Table Designer) and changed the Title dropdown from Above Table to No Title.
Votes
Translate
Translate
Explorer ,
I just found a solution. Posting it here in case it helps someone else!
The trick--have the FrameMaker converter remove extra paragraph breaks. (Click the Advanced button on the Word Import dialog, check Empty Paragraphs.)
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
Votes
Translate
Translate
Report
Report
