4 Replies Latest reply on Oct 22, 2016 6:28 PM by Rick Gerard
    Path weird behaviour
    Tony91
      Hello!
      Have some issues with morphing a path. What I want to do is to morph a circle to a rounded rectangle. So I went in the reversed order - created a rounded rectangle, converted the path to bezier path, created a keyframe for this state, and moved the points together with some handles adjustments to form a circle and created a keyframe for this state. So I expected this circle to expand back to a rounded rectangle but the path suddenly started to scale down and then jumped back in size. I even created a duplicate keyframe with no morphing, so the path should stay in the same place, but get the same situation - shrink down and jump back. Also I'd like to add that I get this type of jumping with repositioning masks - it starts to move in some random direction and jumps to the final position. I think it has to do with some settings.
      Thanks in advance!
        • 1. Re: Path weird behaviour
          Roei Tzoref Adobe Community Professional
          this is a known issue with convert to bezier path.
          workaround:
          After you convert the rectangle to a bezier path select the pen tool, hold down the Ctrl/Cmnd tool to change from the add point to the direct selection tool, drag the selection over the upper left bezier point, right click and choose Mask and Shape Path > Set First Vertex.
          next time when you create a shape and you know you want the bezier vertices, just click Alt as you drag if from the rectangle tool and you will get vertices instead of parametric shape
          • 2. Re: Path weird behaviour
            Tony91 Level 1
            Didn't work
            • 3. Re: Path weird behaviour
              Tony91 Level 1
              Sorry, everything is just fine. First time I changed it only on one keyframe, now made new keyframes after setting first vertex. Thank you very much!
              • 4. Re: Path weird behaviour
                this should work if you follow the exact steps. you do this before you create your animation otherwise you would have to set first vertex for each kayframe. but instead of messing around with converting to bezier path and doing the first vertex workflow when you already know you want the path vertices and not the parametric properties, just start over by using a parametric shape with the Alt key and be done with it:
                1. create your parametric shape using the alt key as you drag it.
                2. create your path keyframes.
                • 5. Re: Path weird behaviour
                  You need the same number of points in both states. Your points are going to move in a straight line to matching points.
                  I would do this kind of thing in Illustrator using the blend tool, then expand the blend and release to layers. Then import as an AE comp and you will have exactly what you want. Take a look at this quick tutorial.
                  If fixing your path by having the same number of vertices and appropriately marking the first vertex does't do the trick then try the morph in Illustrator technique. I use it all the time for morphs that last up to 250 or so frames.
