5 Replies Latest reply on Oct 24, 2016 1:04 AM by Philippe Infographiste
    jsfl - How do I change template publishing html of CANVAS file
      Bonjour ,
      How can i change / import new HTML template by JSFL ?
      It isn't in the xml profile and i dont now how can i do, where can i search...
        • 2. Re: jsfl - How do I change template publishing html of CANVAS file
          Philippe Infographiste Level 1
          Thanks, but in this guide, i can't find how edit or import a new html template for CANVAS.
          I work with CC 2015.2 (Animate can have a html template)
          For example i can edit the profil by jsfl like that
          var doc = fl.getDocumentDOM();
          var folderPath=JSFLfolderPath(doc);
          var pPath = folderPath + "_Profile_.xml";
          doc.exportPublishProfile(pPath);
          xml = FLfile.read(pPath);
          // do something in the var xml
          FLfile.write(pPath, xml);
          doc.importPublishProfile(pPath);
          I have a lot of fla to convert in CANVAS, and all fla must have a custom html template.
          • 4. Re: jsfl - How do I change template publishing html of CANVAS file
            Nipun Asthana Adobe Employee
            There are a couple of new JSAPIs to import/export HMTL5 canvas publish template being used for a file.
            Here you go - Create HTML5 Canvas documents in Animate CC
                 bool document::exportCanvasPublishTemplate(pathURI)
                 bool document::importCanvasPublishTemplate(pathURI)
            • 5. Re: jsfl - How do I change template publishing html of CANVAS file
              Great ! I could not find ...
              Really, thank you Nipun
              the answer is fl.getDocumentDOM().importCanvasPublishTemplate(pathURI);
              Here is a command that imports a template named "template.html" placed in the same directory as the FLA for all files folder filled.
              var fileMask = "*.fla";
              var fileList =new Array()
              var paths="";
              var ERROR=0;
              refDoc = "";
              var folderURI = fl.browseForFolderURL("Selectionnez le dossier contenant les FLA et le fichier template.html");
              var subFolder = confirm('Voulez-vous traiter aussi les sous-dossiers ?');
              if (folderURI){
                  listFile(folderURI+"/");
                  if (fileList.length) {
                      var files = ""
                      for (var f=0;f<fileList.length;f++)        {
                          files += fileList[f].split("/").pop()+"\n";
                      if (confirm ("Executer la commande sur les fichiers suivants ?\n" + files))        {
                          for (var i=0;i<fileList.length;i++)            {
                              var doc = fl.openDocument(fileList[i]);
                              var pathURI= folderURI+"/"+"template.html";
                              var exportFlag =fl.getDocumentDOM().importCanvasPublishTemplate(pathURI);
                              if(!exportFlag){
                                  fl.trace("Template could not be imported for "+fileList[f]);
                              doc.save(false);
                              doc.close(false);
                      } else ERROR=1;
              switch(ERROR){
                  case 0: alert ("Operation réussie.");
                  break;
                  case 1: alert ("Operation annulée.");
                  break;
                  case 2: alert ("Aucun fichier Flash trouve dans ce répertoire");
                  break;
              function listFile(paths){
                  var files=[]
                  var folds=[]
                  var files=FLfile.listFolder(paths +"/"+ fileMask,"files");
                  for(i=0;i<files.length;i++)    {
                      fileList.push(paths+files[i]);
                  var folds=FLfile.listFolder(paths,"directories");
                  if(subFolder){
                  for(var j=0;j<folds.length;j++)        {
                          listFile(paths+folds[j]+"/");
