3 Replies Latest reply on Oct 26, 2016 1:19 AM by VectorP
    Android Multiple Screen Display and Dimensions
    VonnieGlz
      Hello,
      I am new to app development and I have been learning as I go. I have an issue with the Android build. The visual output of our Android app is not consistent across our test devices.  For example on a Galaxy Note 3 and Samsung Note Edge the app displays 1/3 smaller than the screen. On an LG Stylus the app fills the screen and is about 20 pixels too tall and too wide. After doing research I could not figure out what would cause this other than, perhaps, screen density settings.  Below is a list of the different settings that we have implemented. I am wondering if we are missing something obvious or have approached this wrong. Do we have the right config settings or our images not properly sized?
      A little history... we created an earlier version of this app and we had a sizing/ scaling issue but it was resolved by adding the metatag for the viewport and adjusting the parameters. We also changed viewport settings in our CSS to use device-width (see CSS snippet below.) However, those settings are not fixing the issue we are experiencing now.
      Any help is appreciated!
      Thank you.
      Current Viewport CSS:
      @-ms-viewport
      width: device-width;
      @-webkit-viewport
      @-o-viewport
      @-moz-viewport
      @viewport
      .html
      background-color: #FFFFFF;
      #page
      z-index: 1;
      height: devide-height;
      background-image: none;
      border-style: none;
      border-color: #000000;
      background-color: transparent;
      Originally we made a reference to the target-densitydpi parameter but we learned that it was deprecated.
      Original Viewport Meta tag in Header with target-densitydpi:
      <meta name="viewport" content="initial-scale=1.0,minimum-scale=1.0,maximum-scale=1.0,width=device-width,height= device-height,target-densitydpi=medium-dpi,user-scalable=no"/>
      New HTML Viewport Meta tag in Header with JQuery code to set the density in the viewport:
      <meta name="viewport" content="initial-scale=1.0, minimum-scale=1.0, maximum-scale=1.0,width=device-width,height=device-height,user-scalable=no" />
      JQuery code
      to set density
      function setDPI()
           var viewportScale = 1 / window.devicePixelRatio;
      $("#viewport").attr("content","user-scalable=no, nitial-scale="+viewportScale+", minimum-scale=0.2, maximum-scale=1, width=device-width");
      DPI Image Information Table:
      Image Resource
      Width
      Height
      Resolution
      src="androidl.png"   density="ldpi"
      320
      480
      120
      src="androidm.png"   density="mdpi"
      480
      800
      160
      src="anroidh.png"   density="hdpi"
      480
      854
      240
      src="androidx.png"    density="xhdpi"
      540
      960
      320
      src="androidxx.png"  density="xxhdpi"
      1280
      720
      480
      src="androidxxx.png"   density="xxxhdpi"
      1920
      1080
      640
      Current Config:
      <?xml version="1.0" encoding="UTF-8"?>
      <widget xmlns     = "http://www.w3.org/ns/widgets"
              xmlns:gap = "http://phonegap.com/ns/1.0"
              id        = "com.americanexpress.amex4you"
              version   = "2.0.0">
          <name>Our App</name>
          <description>
             Our App is a mobile application for Our Company New Hires.
          </description>
          <author href="http://ourcompanycom" email="ouremail@ourcompany.com">
              AmericanExpress
          </author>
          <preference name="orientation"                value="portrait" />
          <preference name="target-device"              value="universal" />
          <preference name="fullscreen"                 value="true" />
            <preference name="EnableViewportScale"        value="true" />
          <preference name="android-minSdkVersion"      value="15" />
          <preference name="android-targetSdkVersion"   value="16" />
          <preference name="android-maxSdkVersion"      value="24" />
          <preference name="android-installLocation"    value="auto" />
            <preference name="phonegap-version"           value="cli-6.3.0" />
          <!-- Core plugins -->
          <plugin name="cordova-plugin-battery-status" />
          <plugin name="cordova-plugin-camera" />
          <plugin name="cordova-plugin-media-capture" />
          <plugin name="cordova-plugin-console" />
          <plugin name="cordova-plugin-device" />
          <plugin name="cordova-plugin-geolocation" />
          <plugin name="cordova-plugin-globalization" />
          <plugin name="cordova-plugin-inappbrowser" />
          <plugin name="cordova-plugin-media" />
          <plugin name="cordova-plugin-network-information" />
          <plugin name="cordova-plugin-whitelist" />
          <!-- Define app icon for each platform. -->
          <icon src="icon.png" />
          <!-- Define app splash screen for each platform. -->
         <platform name="android">
               <splash src="androidl.png"    density="ldpi" />
              <splash src="androidm.png"    density="mdpi" />
              <splash src="anroidh.png"    density="hdpi" />
               <splash src="androidx.png"   density="xhdpi" />
               <splash src="androidxx.png"   density="xxhdpi" />
               <splash src="androidxxx.png"   density="xxxhdpi" />
         </platform>
        <access origin="*" />
           <allow-intent href="http://*/*" />
           <allow-intent href="https://*/*" />
           <allow-intent href="tel:*" />
           <allow-intent href="sms:*" />
           <allow-intent href="mailto:*" />
           <allow-intent href="geo:*" />
              <allow-intent href="market:*" />
          </platform>
      </widget>
        • 1. Re: Android Multiple Screen Display and Dimensions
          VonnieGlz Level 1
          Images that demonstrate the output. The app should be scaled to fill the entire screen where the bottom edge of the image touches the bottom of the phone screen.  Also, I have included the CSS for the location page displayed below (in case that helps)
          .version.location /* version checker */
            color: #0000E0;
            background-color: #A72974;
          @-ms-viewport
          @-webkit-viewport
          @-o-viewport
          @-moz-viewport
          @viewport
          .html
            background-color: #F7F8FA;
          #page
            z-index: 1;
            height: device-height;
            border-style: none;
            padding-top: 391px;
            padding-bottom: 0px;
          #u3032
            z-index: 5;
            width: 643px;
            position: relative;
          #u14613
            z-index: 11;
            width: 693px;
            height: 82px;
            border-style: none;
            border-color: transparent;
            border-radius: 15px;
            margin-left: 30px;
            margin-top: 9px;
            position: relative;
          #u6565
            z-index: 7;
            width: 716px;
            margin-left: 17px;
            margin-top: 46px;
            position: relative;
          #u8390
            z-index: 9;
            width: 261px;
            margin-left: 245px;
            margin-top: 140px;
            position: relative;
          #u2989
            z-index: 2;
            min-height: 313px;
            padding-bottom: 24px;
            background: transparent url("../images/pattern.png") no-repeat center top;
            background-size: cover;
          #u2992
            z-index: 3;
            width: 528px;
            position: relative;
            margin-right: -10000px;
            margin-top: 281px;
            left: 111px;
          #u2989-bw
            z-index: 2;
            min-height: 313px;
            margin-top: 48px;
          body
            position: relative;
            min-width: device-width;
          #page .verticalspacer
            clear: both;
          • 3. Re: Android Multiple Screen Display and Dimensions
            VectorP Level 4
            I have no idea why you are trying to set all those widths  and heights.
            It should be sufficient to set:
            <meta name="viewport" content="width=device-width, initial-scale=1">
            May I suggest you remove all those other settings (like #page {width: device-width; height: device-height;} and @-webkit-viewport{width: device-width;} ) and don't use any exact width values in pixels. Instead, create a liquid design, which makes use of percentages and units like 'vw'. Let the viewport do the scaling...it will do a nice job.
