4 Replies Latest reply on Oct 22, 2016 7:13 AM by Obi-wan Kenobi
    Code to be evaluated! [002]
    Obi-wan Kenobi Level 5
      Hi Scripters!
      I want to move the 3rd para at the end of each frame! … but only if the "Blue_Para" para style is applied to its 1rst para!
      [ … to avoid a true mess in the doc!  ]
      The code below works fine! … but the script triggers a weird alert:
      The problem seems to be limited to the "if" statement! … but I don't understand why!
      If I click on "OK", the script goes on and the result is fine!
      [ … Just a few centuries and, with the help of The Force, I'll become a Script Master! ]
      var myTFrames = app.activeDocument.textFrames;
      for ( t = 0 ; t < myTFrames.length; t++ )
              var myTFrame = myTFrames[t];
              if  (  myTFrame.paragraphs[0].appliedParagraphStyle.name == "Blue_Para"  )
                      myTFrame.characters[-1].contents = "\r";
                      myTFrame.paragraphs[2].move(LocationOptions.AT_END);
                      myTFrame.characters[-1].contents = "";
      [ Lines 10-12, courtesy of Skemicle // Sort paragraphs in a certain way  ]
      Thanks in advance!
        • 1. Re: Code to be evaluated! [002]
          tpk1982 Level 4
          Hi Obi,
          I tried the coding and working fine. I don't get any error message. If it comes for you then please use try catch method
          Regards,
          K
          • 2. Re: Code to be evaluated! [002]
            Thanks Kartik!
            I did it before posting:
                    try
                            if  (  myTFrame.characters[0].appliedParagraphStyle.name == "Blue_Para"  )
                    catch (myError) { }
            This way only hides the problem under the carpet!
            … I don't want to be boring [ ] but this's not very satisfactory and it doesn't explain me why I encounter myself such a mistake and you not!!
            • 3. Re: Code to be evaluated! [002]
              After running your code, the last character of my test strings disappeared Change the add-a-return line to
              myTFrame.insertionPoints[-1].contents = "\r";
              to avoid that.
              I am able to trigger the exact same error if there is an empty text frame anywhere in your document. To prevent that, change the 'if' test to
              if  (myTFrame.paragraphs.length > 0 && myTFrame.paragraphs[0].appliedParagraphStyle.name == "Blue_Para" )
              If that does not work, add this to the 'catch' code:
              myTFrame.select();
              so you can see which frame causes the problem.
              • 4. Re: Code to be evaluated! [002]
                Thanks Jongware!  Empty text frames on Master Pages!!
                Final script version saved in my Scripts Panel:
                    See: "Code to be evaluated! [002]" [2016/10/22] [https://forums.adobe.com/thread/2225693]
                    Script written by Michel Allio
                    Lines 23-24-25, courtesy of Skemicle | See: "Sort paragraphs in a certain way" [https://forums.adobe.com/thread/2225033]
                    Line 21-23, corrected by Jongware
                app.doScript("main()", ScriptLanguage.javascript, undefined, UndoModes.FAST_ENTIRE_SCRIPT, 'Move Paras! …');
                function main()
                        if  (  myTFrame.paragraphs.length > 0 && myTFrame.paragraphs[0].appliedParagraphStyle.name == "Blue_Para"  )
                No real actual use but very good for my [JS] learning!
                Thanks all!
