4 Replies Latest reply on Oct 30, 2016 5:55 AM by G.Hoffmann
    Need to find RGB-color that matches specific CMYK-color (via DeviceLink-profile)
    ulrikt8202587
      I have a, judging from extensive googling, rather unusual task at hand: I have a CMYK-color, and a DeviceLink-file (RGB->CMYK, taking care of black-text-staying-black), and need to figure out what RGB-color corresponds (best) to the CMYK-color.
      I am operating on PDF's, that are generated from scraping webpages (RGB) and the resulting PDF will be sent to a print shop, thus the requirement of ending up with CMYK-color codes.
      I am using GhostScript and Adobe Photoshop, but can't see a way to let the computer solve the riddle, and trying the manual approach has not proven successful so far.
      BR,
      Ulrik
        • 1. Re: Need to find RGB-color that matches specific CMYK-color (via DeviceLink-profile)
          Can't you just use the profile with a CMM like Microsoft ICM2? Or is your profile one-way?
          • 2. Re: Need to find RGB-color that matches specific CMYK-color (via DeviceLink-profile)
            Also, it may go without saying but any modern print shop (that is, one which has moved with the times, many haven't) will accept and may prefer properly tagged RGB PDF files.
            • 3. Re: Need to find RGB-color that matches specific CMYK-color (via DeviceLink-profile)
              D Fosse Adobe Community Professional & MVP
              First, the obvious: numbers refer to specific color spaces. For the same color, numbers in sRGB and Adobe RGB are different, as they are different in US Web Coated SWOP and Coated FOGRA39. Just to name arbitrary examples.
              So which RGB specifically, and which CMYK specifically? There is no such thing as "generic" RGB or CMYK.
              With that established, it's a simple matter of using the eyedropper in Photoshop. Convert to the target profile, and use the eydropper again.
              Any print shop that accepts undefined "CMYK" should be avoided, because they don't know what they're doing and cannot be relied upon for accurate or consistent results.
              • 4. Re: Need to find RGB-color that matches specific CMYK-color (via DeviceLink-profile)
                G.Hoffmann Level 4
                A device link profile works only in one direction:
                RGB ––> CMYK
                CMYK1 ––> CMYK2
                Of course D Fosse is right - for any application of a device link profile except printing one has to
                know the source profile and the target profile (for printing these informations were used implicitly,
                making the device link profile.)
                Now let's assume AdobeRGB (aRGB) as source and ISOcoated-v2-eci as destination profile.
                An image in aRGB can be converted to ISO eventually faster and more accurate than
                by using the standard workflow aRGB ––> LAB ––> ISO.
                In fact the creation of such a profile, as explained for the RIP Colorgate Productionserver
                requires an optimization:
                  DEVICELINK PROFILER Modul DLPFM
                  Voraussetzung: Sie haben das Devicelink Profiler Modul (DLPFM) erworben,
                  den Proof Workflow gewählt und ein Referenzprofil des zu simulierenden
                  Drucksystems erzeugt.
                  Der DEVICELINK PROFILER ist ein eigenständiges und optional erhältliches Modul.
                  DeviceLink Profile enthalten eine Farbraumtransformation von einem Gerätefarbraum
                  (Simulation) in einen zweiten Gerätefarbraum.
                  Der DEVICELINK Profiler Assistent optimiert DeviceLink Profile für den Proof Workflow
                  in iterativen Schritten, wobei das Messergebnis über einen weiteren iterativen Schritt entscheidet.
                  Erst durch eine Optimierung des DeviceLink Profils erreichen Sie eine optimale Farbsimulation
                  im Proofergebnis. Der DeviceLink Profiler kann auch Multi-Color-Profile optimieren.
                  Hier sehen Sie eine Übersicht der Schritte im Assistenten: ...
                The creation requires as well Rendering Intents, in the mentionened RIP either equal or different
                for raster graphics and vector graphics. Furtheron some rules how to Preserve (or not) pure
                colors, especially the reproduction of RGB-black by K-only, as mentioned in the original post.
                Now let's assume, we have told Photoshop the RGB space (aRGB), the CMYK space (ISO) and
                the Rendering Intent (only one, for raster and vector).
                Then we can read, using the color picker, aRGB-values and ISO-values without any application
                of "convert to profile". The problem seems to be solved: get aRGB numbers from CMYK numbers.
                Unfortunately this task doesn't have a general solution. Some RGB colors might have been
                reproduced in CMYK affected by gamut clipping, especially if the source data were delivered
                by usually highly saturated web sites.
                Even if we knew that gamut clipping happened for a certain color, the source color could not be
                reconstructed.
                So far about a strict solution of the problem.
                If the conversion from aRGB to ISO had been executed professionally, e.g. for book printing, then
                images in RGB were prepared by Soft Proofing so, that no loss due to gamut clipping happened
                (RGB colors were somewhat desaturated, blues shifted towards cyan, for instance), and Rendering
                Intent is always Relative Colorimetric, then the method as mentioned above should work satisfying.
                The interpretation of vector graphics (lines, rectangles, text), which exist in PDFs as independent
                elements besides raster graphics, will still be doubtful.
                Best regards --Gernot Hoffmann
