6 Replies Latest reply on Oct 29, 2016 12:38 PM by J Isner
    "The disk copy of <file> was changed since you last opened or saved it"
    J Isner Level 1
      This could be either a LR or PS question because it involves the interface between the two programs.
      I created a new document in PS.  I saved a file from PS named foo.psd and imported it into LR.  I did not make any adjustments in LR.  From LR, I did Edit in -> Photoshop with the option "Edit a copy."  This causes LR to create a file foo-2.psd which is then opened in PS.  While working on the file in PS, I periodically do File -> Save.  But when I save I get a warning dialog:
      "The disk copy of foo-2.psd was changed since you last opened or saved it.  Do you want to save anyway?"
      But I have not made any changes to the file outside PS.  I can see that from the file timestamp.
      What could be causing this?
      LR CC 2015.7
      PS CC 2015.5.1
      Windows 7 64-bit
