2 Replies Latest reply on Oct 24, 2016 9:37 PM by tpk1982
    Add pages until multiple of 4
    jakec88782761 Level 2
      Hello everyone,
      I'm trying to add the code to my script which first deletes all empty pages and then adds empty pages until the total number of pages is a multiple of 4.
      function pageInsert () {
      var pages = app.activeDocument.pages.everyItem().getElements();
              for ( i = 0; i<pages.length; i++ ) {
                      if (pages[i].pageItems.length==0) {
                          pages[i].remove();
          } //delete empty pages
      var newPages = app.activeDocument.pages.everyItem().getElements();
      if ( pages.length % 4 != 0) {  //  Add a page if the pages aren't divisible by 4.
          app.activeDocument.pages.add( LocationOptions.BEFORE, app.activeDocument.spreads[-1] );
          } //insert an empty page to make the document pages a multiple of 4 (for booklets)
      This is the script and it delete the empty pages fine, it just doesn't execute the last bit of code which adds a page if it's not divisible by 4.
      Any ideas?
        • 1. Re: Add pages until multiple of 4
          S Hopkins Adobe Community Professional
          A couple of suggestions: Once you get a reference to an object, place it into a variable and use the variable reference. (e.g.: app.activeDocument). You would probably have that reference in the main section of your script, so pass it to the function.
          Here is how I might write the function:
          var docRef = app.activeDocument;
          pageInsert(docRef);
          function pageInsert (docRef) {
          var pages = docRef.pages.everyItem().getElements();
                              pages[i].remove();
          var newPages = docRef.pages.everyItem().getElements();
              while (docRef.pages.count() % 4 != 0)  {
              docRef.pages.add( LocationOptions.BEFORE, docRef.spreads[-1] );
          Hope this helps.
          S.Hopkins
          • 2. Re: Add pages until multiple of 4
            tpk1982 Level 4
            This is script from my end... for adding pages
            var myDoc=app.activeDocument
            var mylength=(myDoc.pages.length);
            var err=0
            var mydiv=(mylength%4)
            var myadd=(4-mydiv)
            if(mydiv==0){
            alert("No issue with Page count. Press OK to go next step.")}
            if(myadd!=4){
            var myconfirmation=confirm("Need to add "+myadd+" pages to make pagecount. Shall it add? ")
            if(myconfirmation){
            if(mydiv !=0){
                for (i=0;i<myadd;i++){
                var f=myDoc.pages.add(LocationOptions.AT_END)
                f.appliedMaster=null
            HTH
