7 Replies Latest reply on Oct 27, 2016 11:52 AM by Priyank Shrivastava.
    Why is Cold Fusion 2016 taking so long to start
    nellie8912
      After server reboot sometimes cold fusion application services takes up to 24 hours to start.  I check with netstat -a -n -o and neither port 8500 or 8016 are listening.  inside the command prompt,  I run the cfstop and cfstart bat and the application starts but the services still say they are stopped or starting.
      When I try to manually start the cold fusion application in "services", I get an error message
        • 1. Re: Why is Cold Fusion 2016 taking so long to start
          carl type3 Level 4
          Perhaps there are some details about the CF start up in logs. Check ColdFusion2016\cfusion\logs coldfusion-error.log coldfusion-out.log for errors, warnings or maybe something timing out.
          I guess that is Windows, so perhaps add some details about what version and 32 64 bit. If not indicate OS details.
          HTH, Carl.
          • 2. Re: Why is Cold Fusion 2016 taking so long to start
            Priyank Shrivastava. Adobe Employee
            Can you please launch command prompt as Run as Admin and start ColdFusion service with this command.
            >> cfstart > start.log, once ColdFusion starts properly, please share the logs here. let's see what is wrong in it.
            Log location: \ColdFusion2016\cfusion\bin
            Priyank
            • 3. Re: Why is Cold Fusion 2016 taking so long to start
              nellie8912 Level 1
              Information from coldfusion-error log of last slow startup.  I am not sure what all of this means.  Beside that there look like there could be a memory leak with Tomcat.
              Oct 21, 2016 5:11:06 PM org.apache.catalina.core.StandardServer await
              INFO: A valid shutdown command was received via the shutdown port. Stopping the Server instance.
              Oct 21, 2016 5:11:06 PM org.apache.coyote.AbstractProtocol pause
              INFO: Pausing ProtocolHandler ["http-nio-8500"]
              INFO: Pausing ProtocolHandler ["ajp-nio-8016"]
              Oct 21, 2016 5:11:06 PM org.apache.catalina.core.StandardService stopInternal
              INFO: Stopping service Catalina
              Oct 21, 2016 5:11:14 PM org.eclipse.jetty.server.AbstractConnector doStop
              INFO: Stopped ServerConnector@4db3d0ce{HTTP/1.1,[http/1.1]}{0.0.0.0:5500}
              Oct 21, 2016 5:11:14 PM org.eclipse.jetty.server.handler.ContextHandler doStop
              INFO: Stopped o.e.j.s.ServletContextHandler@3ad7eb4a{/,null,UNAVAILABLE}
              Oct 21, 2016 5:11:14 PM org.apache.catalina.loader.WebappClassLoaderBase checkThreadLocalMapForLeaks
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@23f5513b]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477081542123,areFieldsSet=true,areAllFieldsSet=true,le nient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavi ngs=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/ New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,star tMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth= 10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInF irstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=21,DAY_OF_ YEAR=295,DAY_OF_WEEK=6,DAY_OF_WEEK_IN_MONTH=3,AM_PM=1,HOUR=4,HOUR_OF_DAY=16,MINUTE=25,SECO ND=42,MILLISECOND=123,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.runtime.Cast$1] (value [coldfusion.runtime.Cast$1@32bdb86e]) and a value of type [java.lang.Boolean] (value [true]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@23f5513b]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477084100801,areFieldsSet=true,areAllFieldsSet=true,le nient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavi ngs=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/ New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,star tMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth= 10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInF irstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=21,DAY_OF_ YEAR=295,DAY_OF_WEEK=6,DAY_OF_WEEK_IN_MONTH=3,AM_PM=1,HOUR=5,HOUR_OF_DAY=17,MINUTE=8,SECON D=20,MILLISECOND=801,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@23f5513b]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477083120311,areFieldsSet=true,areAllFieldsSet=true,le nient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavi ngs=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/ New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,star tMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth= 10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInF irstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=21,DAY_OF_ YEAR=295,DAY_OF_WEEK=6,DAY_OF_WEEK_IN_MONTH=3,AM_PM=1,HOUR=4,HOUR_OF_DAY=16,MINUTE=52,SECO ND=0,MILLISECOND=311,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@23f5513b]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477081713402,areFieldsSet=true,areAllFieldsSet=true,le nient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavi ngs=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/ New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,star tMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth= 10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInF irstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=21,DAY_OF_ YEAR=295,DAY_OF_WEEK=6,DAY_OF_WEEK_IN_MONTH=3,AM_PM=1,HOUR=4,HOUR_OF_DAY=16,MINUTE=28,SECO ND=33,MILLISECOND=402,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              Oct 21, 2016 5:11:15 PM org.apache.catalina.loader.WebappClassLoaderBase checkThreadLocalMapForLeaks
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@23f5513b]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477083133181,areFieldsSet=true,areAllFieldsSet=true,le nient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavi ngs=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/ New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,star tMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth= 10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInF irstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=21,DAY_OF_ YEAR=295,DAY_OF_WEEK=6,DAY_OF_WEEK_IN_MONTH=3,AM_PM=1,HOUR=4,HOUR_OF_DAY=16,MINUTE=52,SECO ND=13,MILLISECOND=181,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@23f5513b]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477079206604,areFieldsSet=true,areAllFieldsSet=true,le nient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavi ngs=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/ New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,star tMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth= 10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInF irstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=21,DAY_OF_ YEAR=295,DAY_OF_WEEK=6,DAY_OF_WEEK_IN_MONTH=3,AM_PM=1,HOUR=3,HOUR_OF_DAY=15,MINUTE=46,SECO ND=46,MILLISECOND=604,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@23f5513b]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1423976400000,areFieldsSet=true,areAllFieldsSet=false,l enient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSav ings=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America /New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,sta rtMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth =10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysIn FirstWeek=1,ERA=?,YEAR=2015,MONTH=1,WEEK_OF_YEAR=?,WEEK_OF_MONTH=?,DAY_OF_MONTH=15,DAY_OF_ YEAR=?,DAY_OF_WEEK=?,DAY_OF_WEEK_IN_MONTH=?,AM_PM=?,HOUR=?,HOUR_OF_DAY=?,MINUTE=?,SECOND=? ,MILLISECOND=?,ZONE_OFFSET=?,DST_OFFSET=?]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@23f5513b]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477079240005,areFieldsSet=true,areAllFieldsSet=true,le nient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavi ngs=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/ New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,star tMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth= 10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInF irstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=21,DAY_OF_ YEAR=295,DAY_OF_WEEK=6,DAY_OF_WEEK_IN_MONTH=3,AM_PM=1,HOUR=3,HOUR_OF_DAY=15,MINUTE=47,SECO ND=20,MILLISECOND=5,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@23f5513b]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477081568223,areFieldsSet=true,areAllFieldsSet=true,le nient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavi ngs=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/ New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,star tMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth= 10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInF irstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=21,DAY_OF_ YEAR=295,DAY_OF_WEEK=6,DAY_OF_WEEK_IN_MONTH=3,AM_PM=1,HOUR=4,HOUR_OF_DAY=16,MINUTE=26,SECO ND=8,MILLISECOND=223,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              Oct 21, 2016 5:11:15 PM org.apache.coyote.AbstractProtocol stop
              INFO: Stopping ProtocolHandler ["http-nio-8500"]
              INFO: Stopping ProtocolHandler ["ajp-nio-8016"]
              Exception in thread "Thread-27" java.lang.NoClassDefFoundError: java/lang/Thread$State
              at org.apache.axis2.engine.ListenerManager.stop(ListenerManager.java:195)
              at org.apache.axis2.engine.ListenerManager$ListenerManagerShutdownThread.run(ListenerManager .java:315)
              Caused by: java.lang.ClassNotFoundException: java.lang.Thread$State
              at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
              at coldfusion.bootstrap.BootstrapClassLoader.loadClass(BootstrapClassLoader.java:226)
              at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
              ... 2 more
              Oct 21, 2016 5:33:58 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
              INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\ColdFusion2016\cfusion\lib;C:\ColdFusion2016\cfusion\jintegra\bin;C:\ColdFusion2016\cf usion\jintegra\bin\international;C:\ColdFusion2016\cfusion\lib\oosdk\classes\win
              Oct 21, 2016 5:34:01 PM org.apache.coyote.AbstractProtocol init
              INFO: Initializing ProtocolHandler ["http-nio-8500"]
              Oct 21, 2016 5:34:02 PM org.apache.tomcat.util.net.NioSelectorPool getSharedSelector
              INFO: Using a shared selector for servlet write/read
              Oct 21, 2016 5:34:02 PM org.apache.coyote.AbstractProtocol init
              INFO: Initializing ProtocolHandler ["ajp-nio-8016"]
              Oct 21, 2016 5:34:02 PM org.apache.catalina.core.StandardService startInternal
              INFO: Starting service Catalina
              Oct 21, 2016 5:34:02 PM org.apache.catalina.core.StandardEngine startInternal
              INFO: Starting Servlet Engine: Apache Tomcat/8.0.32
              Oct 21, 2016 5:34:13 PM org.apache.jasper.servlet.TldScanner scanJars
              INFO: At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
              Oct 21, 2016 5:43:19 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
              Oct 21, 2016 5:43:20 PM org.apache.coyote.AbstractProtocol init
              Oct 21, 2016 5:43:21 PM org.apache.tomcat.util.net.NioSelectorPool getSharedSelector
              Oct 21, 2016 5:43:21 PM org.apache.coyote.AbstractProtocol init
              Oct 21, 2016 5:43:21 PM org.apache.catalina.core.StandardService startInternal
              Oct 21, 2016 5:43:21 PM org.apache.catalina.core.StandardEngine startInternal
              Oct 21, 2016 5:43:29 PM org.apache.jasper.servlet.TldScanner scanJars
              Oct 21, 2016 5:43:32 PM org.apache.catalina.util.SessionIdGeneratorBase createSecureRandom
              INFO: Creation of SecureRandom instance for session ID generation using [SHA1PRNG] took [3,120] milliseconds.
              Oct 21, 2016 5:43:40 PM org.apache.catalina.core.ApplicationContext log
              INFO: ColdFusionStartUpServlet: ColdFusion: Starting application services
              INFO: ColdFusionStartUpServlet: ColdFusion: VM version = 25.72-b15
              Oct 21, 2016 5:57:13 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
              Oct 21, 2016 5:57:15 PM org.apache.coyote.AbstractProtocol init
              Oct 21, 2016 5:57:16 PM org.apache.tomcat.util.net.NioSelectorPool getSharedSelector
              Oct 21, 2016 5:57:16 PM org.apache.coyote.AbstractProtocol init
              Oct 21, 2016 5:57:16 PM org.apache.catalina.core.StandardService startInternal
              Oct 21, 2016 5:57:16 PM org.apache.catalina.core.StandardEngine startInternal
              Oct 21, 2016 5:57:25 PM org.apache.jasper.servlet.TldScanner scanJars
              Oct 21, 2016 5:57:27 PM org.apache.catalina.util.SessionIdGeneratorBase createSecureRandom
              INFO: Creation of SecureRandom instance for session ID generation using [SHA1PRNG] took [1,263] milliseconds.
              Oct 21, 2016 5:57:28 PM org.apache.catalina.core.ApplicationContext log
              Oct 21, 2016 7:40:17 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
              Oct 21, 2016 7:40:19 PM org.apache.coyote.AbstractProtocol init
              Oct 21, 2016 7:40:20 PM org.apache.tomcat.util.net.NioSelectorPool getSharedSelector
              Oct 21, 2016 7:40:20 PM org.apache.coyote.AbstractProtocol init
              Oct 21, 2016 7:40:20 PM org.apache.catalina.core.StandardService startInternal
              Oct 21, 2016 7:40:20 PM org.apache.catalina.core.StandardEngine startInternal
              Oct 21, 2016 7:40:27 PM org.apache.jasper.servlet.TldScanner scanJars
              Oct 21, 2016 7:40:56 PM org.apache.catalina.util.SessionIdGeneratorBase createSecureRandom
              INFO: Creation of SecureRandom instance for session ID generation using [SHA1PRNG] took [29,033] milliseconds.
              Oct 21, 2016 7:40:57 PM org.apache.catalina.core.ApplicationContext log
              Oct 21, 2016 7:41:29 PM org.eclipse.jetty.util.log.Log initialized
              INFO: Logging initialized @79830ms
              Oct 21, 2016 7:41:31 PM org.eclipse.jetty.server.Server doStart
              INFO: jetty-9.3.6.v20151106
              Oct 21, 2016 7:41:31 PM org.eclipse.jetty.server.handler.ContextHandler doStart
              INFO: Started o.e.j.s.ServletContextHandler@7694e93d{/,null,AVAILABLE}
              Oct 21, 2016 7:41:31 PM org.eclipse.jetty.server.AbstractConnector doStart
              INFO: Started ServerConnector@3d5bfe2c{HTTP/1.1,[http/1.1]}{0.0.0.0:5500}
              INFO: Started @82026ms
              Oct 21, 2016 7:41:34 PM org.apache.catalina.core.ApplicationContext log
              INFO: CFMxmlServlet: Macromedia Flex Build: 87315.134646
              Oct 21, 2016 7:41:44 PM org.apache.coyote.AbstractProtocol start
              INFO: Starting ProtocolHandler ["http-nio-8500"]
              INFO: Starting ProtocolHandler ["ajp-nio-8016"]
              Oct 21, 2016 7:41:44 PM com.adobe.coldfusion.launcher.Launcher run
              INFO: Server startup in 89883 ms
              Oct 22, 2016 11:46:11 PM org.apache.catalina.core.StandardServer await
              Oct 22, 2016 11:46:11 PM org.apache.coyote.AbstractProtocol pause
              Oct 22, 2016 11:46:11 PM org.apache.catalina.core.StandardService stopInternal
              Oct 22, 2016 11:46:18 PM org.eclipse.jetty.server.AbstractConnector doStop
              INFO: Stopped ServerConnector@3d5bfe2c{HTTP/1.1,[http/1.1]}{0.0.0.0:5500}
              Oct 22, 2016 11:46:18 PM org.eclipse.jetty.server.handler.ContextHandler doStop
              INFO: Stopped o.e.j.s.ServletContextHandler@7694e93d{/,null,UNAVAILABLE}
              Oct 22, 2016 11:46:18 PM org.apache.catalina.loader.WebappClassLoaderBase checkThreadLocalMapForLeaks
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.runtime.Cast$1] (value [coldfusion.runtime.Cast$1@6c32fe09]) and a value of type [java.lang.Boolean] (value [true]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@507821d9]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477189507017,areFieldsSet=true,areAllFieldsSet=true,le nient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavi ngs=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/ New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,star tMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth= 10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInF irstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=22,DAY_OF_ YEAR=296,DAY_OF_WEEK=7,DAY_OF_WEEK_IN_MONTH=4,AM_PM=1,HOUR=10,HOUR_OF_DAY=22,MINUTE=25,SEC OND=7,MILLISECOND=17,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@507821d9]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477189885347,areFieldsSet=true,areAllFieldsSet=true,le nient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavi ngs=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/ New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,star tMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth= 10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInF irstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=22,DAY_OF_ YEAR=296,DAY_OF_WEEK=7,DAY_OF_WEEK_IN_MONTH=4,AM_PM=1,HOUR=10,HOUR_OF_DAY=22,MINUTE=31,SEC OND=25,MILLISECOND=347,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@507821d9]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477183874888,areFieldsSet=true,areAllFieldsSet=true,le nient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavi ngs=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/ New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,star tMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth= 10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInF irstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=22,DAY_OF_ YEAR=296,DAY_OF_WEEK=7,DAY_OF_WEEK_IN_MONTH=4,AM_PM=1,HOUR=8,HOUR_OF_DAY=20,MINUTE=51,SECO ND=14,MILLISECOND=888,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@507821d9]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477191360946,areFieldsSet=true,areAllFieldsSet=true,le nient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavi ngs=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/ New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,star tMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth= 10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInF irstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=22,DAY_OF_ YEAR=296,DAY_OF_WEEK=7,DAY_OF_WEEK_IN_MONTH=4,AM_PM=1,HOUR=10,HOUR_OF_DAY=22,MINUTE=56,SEC OND=0,MILLISECOND=946,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              Oct 22, 2016 11:46:19 PM org.apache.catalina.loader.WebappClassLoaderBase checkThreadLocalMapForLeaks
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@507821d9]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477190161587,areFieldsSet=true,areAllFieldsSet=true,le nient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavi ngs=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/ New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,star tMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth= 10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInF irstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=22,DAY_OF_ YEAR=296,DAY_OF_WEEK=7,DAY_OF_WEEK_IN_MONTH=4,AM_PM=1,HOUR=10,HOUR_OF_DAY=22,MINUTE=36,SEC OND=1,MILLISECOND=587,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@507821d9]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477186631156,areFieldsSet=true,areAllFieldsSet=true,le nient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavi ngs=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/ New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,star tMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth= 10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInF irstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=22,DAY_OF_ YEAR=296,DAY_OF_WEEK=7,DAY_OF_WEEK_IN_MONTH=4,AM_PM=1,HOUR=9,HOUR_OF_DAY=21,MINUTE=37,SECO ND=11,MILLISECOND=156,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@507821d9]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477186687209,areFieldsSet=true,areAllFieldsSet=true,le nient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavi ngs=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/ New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,star tMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth= 10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInF irstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=22,DAY_OF_ YEAR=296,DAY_OF_WEEK=7,DAY_OF_WEEK_IN_MONTH=4,AM_PM=1,HOUR=9,HOUR_OF_DAY=21,MINUTE=38,SECO ND=7,MILLISECOND=209,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@507821d9]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477190420775,areFieldsSet=true,areAllFieldsSet=true,le nient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavi ngs=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/ New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,star tMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth= 10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInF irstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=22,DAY_OF_ YEAR=296,DAY_OF_WEEK=7,DAY_OF_WEEK_IN_MONTH=4,AM_PM=1,HOUR=10,HOUR_OF_DAY=22,MINUTE=40,SEC OND=20,MILLISECOND=775,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@507821d9]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477194259022,areFieldsSet=true,areAllFieldsSet=true,le nient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavi ngs=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/ New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,star tMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth= 10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInF irstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=22,DAY_OF_ YEAR=296,DAY_OF_WEEK=7,DAY_OF_WEEK_IN_MONTH=4,AM_PM=1,HOUR=11,HOUR_OF_DAY=23,MINUTE=44,SEC OND=19,MILLISECOND=22,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@507821d9]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477190472647,areFieldsSet=true,areAllFieldsSet=true,le nient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavi ngs=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/ New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,star tMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth= 10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInF irstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=22,DAY_OF_ YEAR=296,DAY_OF_WEEK=7,DAY_OF_WEEK_IN_MONTH=4,AM_PM=1,HOUR=10,HOUR_OF_DAY=22,MINUTE=41,SEC OND=12,MILLISECOND=647,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@507821d9]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477161431358,areFieldsSet=true,areAllFieldsSet=true,le nient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavi ngs=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/ New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,star tMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth= 10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInF irstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=22,DAY_OF_ YEAR=296,DAY_OF_WEEK=7,DAY_OF_WEEK_IN_MONTH=4,AM_PM=1,HOUR=2,HOUR_OF_DAY=14,MINUTE=37,SECO ND=11,MILLISECOND=358,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.util.DateUtils$1] (value [coldfusion.util.DateUtils$1@507821d9]) and a value of type [java.util.GregorianCalendar] (value [java.util.GregorianCalendar[time=1477161432575,areFieldsSet=true,areAllFieldsSet=true,le nient=false,zone=sun.util.calendar.ZoneInfo[id="America/New_York",offset=-18000000,dstSavi ngs=3600000,useDaylight=true,transitions=235,lastRule=java.util.SimpleTimeZone[id=America/ New_York,offset=-18000000,dstSavings=3600000,useDaylight=true,startYear=0,startMode=3,star tMonth=2,startDay=8,startDayOfWeek=1,startTime=7200000,startTimeMode=0,endMode=3,endMonth= 10,endDay=1,endDayOfWeek=1,endTime=7200000,endTimeMode=0]],firstDayOfWeek=1,minimalDaysInF irstWeek=1,ERA=1,YEAR=2016,MONTH=9,WEEK_OF_YEAR=43,WEEK_OF_MONTH=4,DAY_OF_MONTH=22,DAY_OF_ YEAR=296,DAY_OF_WEEK=7,DAY_OF_WEEK_IN_MONTH=4,AM_PM=1,HOUR=2,HOUR_OF_DAY=14,MINUTE=37,SECO ND=12,MILLISECOND=575,ZONE_OFFSET=-18000000,DST_OFFSET=3600000]]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              Oct 22, 2016 11:46:19 PM org.apache.coyote.AbstractProtocol stop
              ... 2 more
              Oct 22, 2016 11:46:34 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
              Oct 22, 2016 11:46:35 PM org.apache.coyote.AbstractProtocol init
              Oct 22, 2016 11:47:16 PM org.apache.tomcat.util.net.NioSelectorPool getSharedSelector
              Oct 22, 2016 11:47:16 PM org.apache.coyote.AbstractProtocol init
              SEVERE: Failed to initialize end point associated with ProtocolHandler ["ajp-nio-8016"]
              java.net.BindException: Address already in use: bind
              at sun.nio.ch.Net.bind0(Native Method)
              at sun.nio.ch.Net.bind(Unknown Source)
              at sun.nio.ch.ServerSocketChannelImpl.bind(Unknown Source)
              at sun.nio.ch.ServerSocketAdaptor.bind(Unknown Source)
              at org.apache.tomcat.util.net.NioEndpoint.bind(NioEndpoint.java:340)
              at org.apache.tomcat.util.net.AbstractEndpoint.init(AbstractEndpoint.java:742)
              at org.apache.coyote.AbstractProtocol.init(AbstractProtocol.java:458)
              at org.apache.catalina.connector.Connector.initInternal(Connector.java:960)
              at org.apache.catalina.util.LifecycleBase.init(LifecycleBase.java:102)
              at org.apache.catalina.core.StandardService.initInternal(StandardService.java:568)
              at org.apache.catalina.core.StandardServer.initInternal(StandardServer.java:851)
              at com.adobe.coldfusion.launcher.Launcher.run(Launcher.java:1005)
              at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
              at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
              at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
              at java.lang.reflect.Method.invoke(Unknown Source)
              at com.adobe.coldfusion.bootstrap.Bootstrap.init(Bootstrap.java:100)
              at com.adobe.coldfusion.bootstrap.Bootstrap.main(Bootstrap.java:185)
              Oct 22, 2016 11:47:16 PM org.apache.catalina.core.StandardService initInternal
              SEVERE: Failed to initialize connector [Connector[AJP/1.3-8016]]
              org.apache.catalina.LifecycleException: Failed to initialize component [Connector[AJP/1.3-8016]]
              at org.apache.catalina.util.LifecycleBase.init(LifecycleBase.java:107)
              Caused by: org.apache.catalina.LifecycleException: Protocol handler initialization failed
              at org.apache.catalina.connector.Connector.initInternal(Connector.java:964)
              ... 11 more
              Caused by: java.net.BindException: Address already in use: bind
              ... 12 more
              Oct 22, 2016 11:47:16 PM org.apache.catalina.core.StandardService startInternal
              Oct 22, 2016 11:47:16 PM org.apache.catalina.core.StandardEngine startInternal
              Oct 22, 2016 11:47:20 PM org.apache.jasper.servlet.TldScanner scanJars
              Oct 22, 2016 11:47:21 PM org.apache.catalina.core.ApplicationContext log
              INFO: ColdFusionStartUpServlet: ColdFusion: VM version = 25.112-b15
              Oct 22, 2016 11:47:33 PM org.eclipse.jetty.util.log.Log initialized
              INFO: Logging initialized @68753ms
              Oct 22, 2016 11:47:35 PM org.eclipse.jetty.server.Server doStart
              Oct 22, 2016 11:47:36 PM org.eclipse.jetty.server.handler.ContextHandler doStart
              INFO: Started o.e.j.s.ServletContextHandler@30656e1c{/,null,AVAILABLE}
              Oct 22, 2016 11:47:36 PM org.eclipse.jetty.server.AbstractConnector doStart
              INFO: Started ServerConnector@884e63{HTTP/1.1,[http/1.1]}{0.0.0.0:51960}
              Oct 22, 2016 11:47:36 PM org.eclipse.jetty.server.Server doStart
              INFO: Started @71650ms
              Oct 22, 2016 11:47:39 PM org.apache.catalina.core.ApplicationContext log
              Oct 22, 2016 11:47:45 PM org.apache.coyote.AbstractProtocol start
              Oct 22, 2016 11:47:45 PM com.adobe.coldfusion.launcher.Launcher run
              INFO: Server startup in 75022 ms
              Oct 22, 2016 11:47:45 PM org.apache.catalina.core.StandardServer await
              SEVERE: StandardServer.await: create[localhost:8011]:
              java.net.BindException: Address already in use: JVM_Bind
              at java.net.DualStackPlainSocketImpl.bind0(Native Method)
              at java.net.DualStackPlainSocketImpl.socketBind(Unknown Source)
              at java.net.AbstractPlainSocketImpl.bind(Unknown Source)
              at java.net.PlainSocketImpl.bind(Unknown Source)
              at java.net.ServerSocket.bind(Unknown Source)
              at java.net.ServerSocket.<init>(Unknown Source)
              at org.apache.catalina.core.StandardServer.await(StandardServer.java:421)
              at com.adobe.coldfusion.launcher.Launcher.await(Launcher.java:1419)
              at com.adobe.coldfusion.launcher.Launcher.access$000(Launcher.java:135)
              at com.adobe.coldfusion.launcher.Launcher$1.run(Launcher.java:1103)
              at java.lang.Thread.run(Unknown Source)
              Oct 22, 2016 11:47:45 PM org.apache.coyote.AbstractProtocol pause
              Oct 22, 2016 11:47:45 PM org.apache.catalina.core.StandardService stopInternal
              Oct 22, 2016 11:47:52 PM org.eclipse.jetty.server.AbstractConnector doStop
              INFO: Stopped ServerConnector@884e63{HTTP/1.1,[http/1.1]}{0.0.0.0:51960}
              Oct 22, 2016 11:47:52 PM org.eclipse.jetty.server.handler.ContextHandler doStop
              INFO: Stopped o.e.j.s.ServletContextHandler@30656e1c{/,null,UNAVAILABLE}
              Oct 22, 2016 11:47:53 PM org.apache.catalina.loader.WebappClassLoaderBase checkThreadLocalMapForLeaks
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [coldfusion.runtime.Cast$1] (value [coldfusion.runtime.Cast$1@173650b2]) and a value of type [java.lang.Boolean] (value [true]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [org.apache.axis.utils.XMLUtils.ThreadLocalDocumentBuilder] (value [org.apache.axis.utils.XMLUtils$ThreadLocalDocumentBuilder@78014c7f]) and a value of type [org.apache.xerces.jaxp.DocumentBuilderImpl] (value [org.apache.xerces.jaxp.DocumentBuilderImpl@5d17300d]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@1b412d49]) and a value of type [flex.compiler.ConsoleOutputHandler] (value [flex.compiler.ConsoleOutputHandler@365e38fb]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@444ee8fb]) and a value of type [flex.util.ServletPathResolver] (value [flex.util.ServletPathResolver@20bd2f27]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              SEVERE: The web application [ROOT] created a ThreadLocal with key of type [com.sun.xml.bind.v2.ClassFactory$1] (value [com.sun.xml.bind.v2.ClassFactory$1@3284651c]) and a value of type [java.util.WeakHashMap] (value [{class javax.xml.bind.annotation.W3CDomHandler=public javax.xml.bind.annotation.W3CDomHandler()}]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
              Oct 22, 2016 11:47:53 PM org.apache.coyote.AbstractProtocol stop
              Exception in thread "Thread-26" java.lang.NoClassDefFoundError: java/lang/Thread$State
              at java.net.URLClassLoader.findClass(Unknown Source)
              at java.lang.ClassLoader.loadClass(Unknown Source)
              ... 2 more
              Oct 23, 2016 9:20:27 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
              Oct 23, 2016 9:20:28 PM org.apache.coyote.AbstractProtocol init
              Oct 23, 2016 9:20:30 PM org.apache.tomcat.util.net.NioSelectorPool getSharedSelector
              Oct 23, 2016 9:20:30 PM org.apache.coyote.AbstractProtocol init
              Oct 23, 2016 9:20:30 PM org.apache.catalina.core.StandardService startInternal
              Oct 23, 2016 9:20:30 PM org.apache.catalina.core.StandardEngine startInternal
              Oct 23, 2016 9:20:37 PM org.apache.jasper.servlet.TldScanner scanJars
              Oct 23, 2016 9:20:38 PM org.apache.catalina.core.ApplicationContext log
              Oct 23, 2016 9:20:56 PM org.eclipse.jetty.util.log.Log initialized
              INFO: Logging initialized @37176ms
              Oct 23, 2016 9:20:57 PM org.eclipse.jetty.server.Server doStart
              Oct 23, 2016 9:20:58 PM org.eclipse.jetty.server.handler.ContextHandler doStart
              INFO: Started o.e.j.s.ServletContextHandler@6d769efb{/,null,AVAILABLE}
              Oct 23, 2016 9:20:58 PM org.eclipse.jetty.server.AbstractConnector doStart
              INFO: Started ServerConnector@627c9d8c{HTTP/1.1,[http/1.1]}{0.0.0.0:5500}
              Oct 23, 2016 9:20:58 PM org.eclipse.jetty.server.Server doStart
              INFO: Started @39206ms
              Oct 23, 2016 9:21:00 PM org.apache.catalina.core.ApplicationContext log
              Oct 23, 2016 9:21:08 PM org.apache.coyote.AbstractProtocol start
              Oct 23, 2016 9:21:08 PM com.adobe.coldfusion.launcher.Launcher run
              INFO: Server startup in 44220 ms
              • 4. Re: Why is Cold Fusion 2016 taking so long to start
                nellie8912 Level 1
                Since this server is in production, I will have to wait until the weekend to get that start log information for you because it can sometimes take up to two days before coldfusion starts after it is stopped.
                • 5. Re: Why is Cold Fusion 2016 taking so long to start
                  Please try this, clear the classes from cfclasses folder.
                  Location: \ColdFusion\cfusion\wwwroot\WEB-INF\cfclasses.
                  Priyank
                  • 6. Re: Why is Cold Fusion 2016 taking so long to start
                    nellie8912 Level 1
                    Can this be done while the server is in production? Or must it be done after hours?
                    • 7. Re: Why is Cold Fusion 2016 taking so long to start
                      You can clear the classes while ColdFusion is running, but if you want to try this after hours that would be fine.
                      Priyank
