4 Replies Latest reply on Oct 26, 2016 12:03 PM by Johnwhite
    How to create Folder(File.parent); in other location
    Johnwhite Level 1
      Hi experts,
      My aim is to make a backup in other location with file.parent before save the file.
      My script failed in file.parent creating.
      Could someone help me to correct my script, please.
      here is my script.
      #targetengine backupCopy
      (function () {
          if (app.eventListeners.itemByName ("backupCopy").isValid) app.eventListeners.itemByName ("backupCopy").remove();
          var mySaveCopyEventListener = app.eventListeners.add("beforeSave", doBackup);
          mySaveCopyEventListener.name = "backupCopy";
      Date.prototype.monthName = function()
       var myMonth = ['January', 'February', 'March', 'April', 'May', 'June', 'July', 'August', 'September', 'October', 'November', 'December'];
       return myMonth[this.getMonth()];
      function doBackup(event)  {
          if (event.target.constructor.name !== 'Document') return;
       var
              cDoc = event.target,
              startTime = new Date();
              cTime = new Date;
              cName = cTime.monthName() +
                              ("0" + String(cTime.getDate()) ).slice(-2);
          doBackup.folder = "~/Desktop/BACKUP_B4Open/"+ cName;
          if (!Folder (doBackup.folder).exists) {
              Folder (doBackup.folder).create();
              $.sleep(400);
          var
          backupFolder = doBackup.folder;
              cTime = new Date;
          rootFolder = Folder(File.parent);
          newBackup = doBackup.folder + "/" + rootFolder + cName;
          if (!Folder (newBackup).exists) {
              Folder (newBackup).create();
              $.sleep(400);
       var
        timePart = dateCalc (startTime),
        newPath = doBackup.folder + "/" + newBackup + "/" + event.fullName.name.replace(".indd", "_" + timePart + ".indd");
          if (!event.fullName.copy (new File (newPath) ))
              alert ("Something wrong, backup failed");
      function timeCalc (start)
       var
        end = new Date(),
        diff = end - start,
        m = Math.floor(diff/60000),
        s = Math.floor( (diff - (m*60000))/1000 );
       return ("0" + m).slice(-2) + ":" + ("0" + s).slice(-2);
      function dateCalc (start)
       var
        d = start.getDate(),
        m = start.getMonth() + 1,
        h = start.getHours(),
        mm = start.getMinutes();
       return " " + ("0" + m).slice(-2) + ("0" + d).slice(-2) + "-" + ("0" + h).slice(-2) + ("0" + mm).slice(-2);
      Regard
      John
        • 1. Re: How to create Folder(File.parent); in other location
          Peter Kahrel Adobe Community Professional & MVP
          returns ~/Documents/tmp00000001, which is definitely not a root folder. What are you after?
          Peter
          • 2. Re: How to create Folder(File.parent); in other location
            Johnwhite Level 1
            Sorry, Peter,
            I just want to know how to create file's parent folder in other location.
            so about the create folder part, I changed it like this:
             var
                    cTime = new Date;
                    cDate = cTime.monthName() +
                    eDate =  "-" + cTime.monthName() +
                    myDoc = app.activeDocument;
                    myFolder=Folder(myDoc.fullName);
                    myFileParent = decodeURI(myFolder.parent.name);
                doBackup.folder = "~/Desktop/BACKUP_B4Save/" + cDate + "/" + myFileParent + eDate;
                    $.sleep(400);
            Regard
            John
            • 3. Re: How to create Folder(File.parent); in other location
              Hi John,
              I hope, this is working as expected…
              However, if I were you I'd change the names for some variables so if you will come back to your code a year from now, you'll be able to understand better what is going on. And I'd do variable declaration always with var . That's not the case with the variables beginning with cTime, cDate etc. because you ended the var declaration statement in the line with: startTime = new Date(); using the ; at the end.
              My proposed changes would go like this perhaps:
              var myInDesignDocFile = File(myDoc.fullName);
              var myParentFolderName = decodeURI(myInDesignDocFile.parent.name);
              Or even better:
              var myInDesignDocFile = myDoc.fullName;
              Because:
              // With an already saved document:
              app.documents[0].fullName.constructor.name
              // Returns: File
              Regards,
              Uwe
              • 4. Re: How to create Folder(File.parent); in other location
                Johnwhite Level 1
                Thank you guys,
                thank you for your help.
                Regard
                John
