5 Replies Latest reply on Dec 2, 2016 6:15 PM by jamesadamtaylor
    Drifting Tone Curve post-macOS Sierra update?
    benjaminh33274247
      Has anyone been having an issue with the tone curve after updating to the new macOS Sierra?
      The best way to describe it would be that the tone curve points feel very heavy when I'm adjusting them.
      As I'm moving a point up and down, it would be mysteriously drawn to the left, down the slope, as if weighted down by gravity.
      This can, as you can imagine, be incredibly frustrating when you're trying to make minute changes to your curve and witness as you're point is inevitably drawn downwards. To compensate, I have had to drift my mouse rightwards as I make simple up-and-down movements.
      Has anyone else experienced this/figured out a fix?
        • 1. Re: Drifting Tone Curve post-macOS Sierra update?
          Akash Sharma Adobe Employee
          Hi Benjaminh,
          Which version of Lightroom are you using?
          Does it help if you try resetting the Tone curve? Resetting Lightroom’s Tone Curve « Julieanne Kost's Blog
          Regards,
          Akash
          • 2. Re: Drifting Tone Curve post-macOS Sierra update?
            Todd Shaner Adobe Community Professional & MVP
            This issue (and many others) has been reported by other users after upgrading to Sierra:
            LR Curve adjustment difficult on MacOS Sierra
            Re: Is Lightroom compatible with macOS Sierra?[was: Sierra]
            I suggest adding a new 'Problem' report at this link: Photoshop Family Customer Community
            • 4. Re: Drifting Tone Curve post-macOS Sierra update?
              axmelissarios1 Adobe Employee (Admin)
              This bug has now been acknowledged. The team is investigating.
              Any updates to the issue will be shown here: Lightroom 6: Tone curve is insensitive to MacBook Pro touch pad | Photoshop Family Customer Community
              It would help if you could add your voice there and your System Info (Help > System Info > Copy or Save As) to provide the team with more info.
              Melissa
              • 5. Re: Drifting Tone Curve post-macOS Sierra update?
                jamesadamtaylor Level 1
                this one is killing me!
                Lightroom version: CC 2015.7 [ 1090788 ]
                License: Creative Cloud
                Operating system: Mac OS 10
                Version: 10.12 [1]
                Application architecture: x64
                Logical processor count: 4
                Processor speed: 3.4 GHz
                Built-in memory: 32,768.0 MB
                Real memory available to Lightroom: 32,768.0 MB
                Real memory used by Lightroom: 2,859.2 MB (8.7%)
                Virtual memory used by Lightroom: 5,485.8 MB
                Memory cache size: 3,210.4 MB
                Maximum thread count used by Camera Raw: 4
                Camera Raw SIMD optimization: SSE2,AVX,AVX2
                Displays: 1) 2560x1440
                Graphics Processor Info:
                NVIDIA GeForce GTX 775M OpenGL Engine
                Check OpenGL support: Passed
                Vendor: NVIDIA Corporation
                Version: 4.1 NVIDIA-10.12.68 355.10.05.05b16
                Renderer: NVIDIA GeForce GTX 775M OpenGL Engine
                LanguageVersion: 4.10
                Application folder: /Applications/Adobe Lightroom
                Library Path: /Users/jamesadamtaylor/Pictures/Lightroom/JAT Archive LR CAT/JAT_Archive_2015-2.lrcat
                Settings Folder: /Users/jamesadamtaylor/Library/Application Support/Adobe/Lightroom
                Installed Plugins:
                1) AdobeStock
                2) Aperture/iPhoto Importer Plug-in
                3) Canon Tether Plugin
                4) Facebook
                5) Flickr
                6) Leica Tether Plugin
                7) Nikon Tether Plugin
                Config.lua flags: None
                AudioDeviceIOBlockSize: 512
                AudioDeviceName: Built-in Output
                AudioDeviceNumberOfChannels: 2
                AudioDeviceSampleRate: 44100
                Build: LR5x102
                CoreImage: true
                GL_ACCUM_ALPHA_BITS: 0
                GL_ACCUM_BLUE_BITS: 0
                GL_ACCUM_GREEN_BITS: 0
                GL_ACCUM_RED_BITS: 0
                GL_ALPHA_BITS: 8
                GL_BLUE_BITS: 8
                GL_DEPTH_BITS: 24
                GL_GREEN_BITS: 8
                GL_MAX_3D_TEXTURE_SIZE: 2048
                GL_MAX_TEXTURE_SIZE: 16384
                GL_MAX_TEXTURE_UNITS: 8
                GL_MAX_VIEWPORT_DIMS: 16384,16384
                GL_RED_BITS: 8
                GL_RENDERER: NVIDIA GeForce GTX 775M OpenGL Engine
                GL_SHADING_LANGUAGE_VERSION: 1.20
                GL_STENCIL_BITS: 8
                GL_VENDOR: NVIDIA Corporation
                GL_VERSION: 2.1 NVIDIA-10.12.68 355.10.05.05b16
                OGLEnabled: true
                GL_EXTENSIONS: GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_depth_bounds_test GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_point_sprite GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
