0 Replies Latest reply on Oct 26, 2016 5:28 PM by oliverk48459247
    Redirect issue with Phonegap/Laravel
    oliverk48459247
      When attempting to send a post request to http://med.app/tour/pull (a laravel route) as an attempt to pull data from the server; my application then realises the user is not authenticated so it redirects them to another page.
      enter image description here
      Because the application is under the Phonegap serve proxy; It becomes confused and appears as 'http://undefined/proxy/http://med.apphttp://med.app/login' instead of redirecting it tohttp://med.app/login.
      For reference; the Laravel code causing the redirect is the following in Exceptions/Handler.php
          protected function unauthenticated($request, AuthenticationException $exception) { if ($request->expectsJson()) { return response()->json(['error' => 'Unauthenticated.'], 401); }  return redirect()->guest('login'); }
      What solution would be the best for this issue? Is this something I should resolve on Laravel or with Phonegap?
