1 2 Previous Next 55 Replies Latest reply on Oct 31, 2016 9:50 AM by Test Screen Name
    Dynamic Date On Printouts - Saving Routine
    SimplyOtto Level 1
      Hello everybody.
      To add a field with a dynamic date + "expiry date" i used this script:
      var inch = 72;
      for (var p = 0; p < this.numPages; p++) {
      var aRect = this.getPageBox( {nPage: p} );
      aRect[1] = .5*inch;
      aRect[3] = aRect[1] - 24; // and 24 points high
      var f = this.addField("PrintField", "text", p, aRect )
      f.delay = true;
      f.textSize = 10;
      f.textFont = font.Cour;
      f.textColor = color.black;
      f.alignment = "center";
      f.readonly = true;
      f.display = display.noView;
      f.delay = false;
      var d = new Date();
      d.setDate(d.getDate()+3);
      this.getField("PrintField").value = "Dokument gültig bis " + util.printd("dd.mmm.yyyy", d);
      this.setAction("WillPrint", myWillPrintScript);
      It works pretty well, but i have an issue about the need to save the file each time i print it.
      Is there a way to avoid the saving (as no changes are made to the document...) or as a workaround
      to automize the saving-procedure?
      Another thing, is there a way to forbid users to make changes to an implemented java script?
      Thanks in advance,
      Otto
        1 2 Previous Next
