6 Replies Latest reply on Oct 27, 2016 10:09 PM by BKBK
    How to use autocomplete to get first and last name from database
    BACFL
      I have tried the cfinput autocomplete and some jquery examples but I just can't get them working.
      Does anyone have a full jquery or coldfusion example of how to autocomplete a text field using first and last name pulled from a database?
      Thank you!
      B.
        • 1. Re: How to use autocomplete to get first and last name from database
          WolfShade Level 4
          I recommend not using CFFORM or any CFINPUT, CFSELECT, etc.  The binding can be appealing, but a few more keystrokes can get you better granular control, validation, etc., if done manually.  No veteran developer (that I am aware of) uses CFFORM et al for anything.  It started out as a great idea, but it uses an outdated javascript library that can sometimes glitch up on you.
          A standard FORM can do at least as good as, more likely better than, CFFORM, granted it means a little more work on your part (it's totally worth it.)
          Basically, using jQuery, you can set the onKeyDown or onKeyPress of the input fields to actuate a function that will use AJaX to send the field value to a CFFUNCTION in a .CFC component file that will query the database (SELECT firstName FROM users WHERE firstName like <cfqueryparam value="#form.firstName#%" /> -- notice the wildcard) and will return a query on each keystroke.  You use the query object converted to JSON to populate a variable and use a jQuery plugin to display the clickable options in an almost drop-down fashion.  jQueryUI has this capability.  Click here for an example.
          HTH,
          ^_^
          • 2. Re: How to use autocomplete to get first and last name from database
            Steve Sommers Level 4
            To expand on what WolfShade said, I recommend looking at jquery.typeahead: GitHub - twitter/typeahead.js: typeahead.js is a fast and fully-featured autocomplete library. It works great with AJAX calls or local data.
            • 3. Re: How to use autocomplete to get first and last name from database
              BACFL Level 1
              Thanks for your answer.  In the meantime I have found this nice .cfc by Ben Forta.  However, I don't know how to make it work for last AND first name.  Any ideas?
              <cfset THIS.dsn="cfartgallery">
                  <!--- Lookup used for auto suggest --->
                  <cffunction name="lookupArt" access="remote" returntype="array">
              <cfargument name="search" type="any" required="false" default="">
              <!--- Define variables --->
              <cfset var data="">
              <cfset var result=ArrayNew(1)>
              <!--- Do search --->
              <cfquery datasource="xxxxxxxxx" name="data">
              SELECT lname, fname
              FROM users
              WHERE lname LIKE '#ARGUMENTS.search#%'
              ORDER BY lname
              </cfquery>
              <!--- Build result array --->
              <cfloop query="data">
              <cfset ArrayAppend(result, lname)>
              </cfloop>
                      <!--- And return it --->
              <cfreturn result>
                  </cffunction>
              </cfcomponent>
              • 4. Re: How to use autocomplete to get first and last name from database
                BKBK Adobe Community Professional & MVP
                autosuggest.cfm
                <cfform name="empForm" id="empForm" action="#cgi.SCRIPT_NAME#">
                <p>
                Employee first name: <cfinput  autosuggest="cfc:employee.getFirstname({cfautosuggestvalue})" autosuggestminlength="1" type="text" name="firstName" size="50" typeahead="yes">
                </p>
                <p>
                Employee ID: <cfselect name="employeeID" bind="cfc:employee.getEmpID({firstName})" />
                </p>
                <p>
                <cfinput type="submit" name="sbmt" value="Send">
                </p>
                </cfform>
                employee.cfc
                <!--- Within same directory --->
                <cfcomponent>
                    <cfset selected_emp_id = "">
                    <cffunction name="getFirstName" access="remote" output="false" returntype="array">
                        <cfargument name="suggestedValue" required="true" type="string">
                        <cfset var getEmpFirstName = queryNew("","")>
                        <cfset var fnameArray = arrayNew(1)>
                <!--- Uses datasource cfdocexamples which is in-built, hence already configured  --->
                        <cfquery name = "getEmpFirstName" dataSource = "cfdocexamples">
                            SELECT FirstName
                            FROM Employees
                        </cfquery>
                        <cfloop query="getEmpFirstName">
                        <cfset fnameArray[currentrow]=FirstName>
                        </cfloop>
                        <cfreturn fnameArray>
                    </cffunction>
                    <cffunction name="getEmpID" access="remote" returntype="array">
                        <cfargument name="fName" required="true" type="string">
                        <cfset var getEmployee = queryNew("","")>
                        <cfset var empArray = arrayNew(2)>
                        <cfquery name = "getEmployee" dataSource = "cfdocexamples">
                            SELECT Emp_ID, FirstName || ' ' || LastName as empName
                            FROM Employees
                            WHERE FirstName = '#arguments.fName#'
                        </cfquery>
                        <!--- Values for the first - the default - select option --->
                        <cfset empArray[1][1]="">
                        <cfset empArray[1][2]="Select employee">
                        <cfloop query="GetEmployee">
                        <cfset empArray[currentrow+1][1]=Emp_ID>
                        <cfset empArray[currentrow+1][2]=empName>
                        </cfloop>
                        <!--- Alternative, if you require no "Select employee" option --->
                        <!--- <cfloop query="GetEmployee">
                        <cfset empArray[currentrow][1]=Emp_ID>
                        <cfset empArray[currentrow][2]=empName>
                        </cfloop> --->
                        <cfreturn empArray>
                    </cffunction>
                </cfcomponent>
                • 5. Re: How to use autocomplete to get first and last name from database
                  BACFL Level 1
                  I was ultimately able to do it with this .cfc
                      <cffunction name="lookupname" access="remote" returntype="array">
                  <cfset var data="">
                  <cfquery datasource="xxxxxx" name="data">
                  SELECT lname + ',' + fname as fullname, userid
                  FROM users
                  ORDER BY lname,fname
                  </cfquery>
                  <cfset ArrayAppend(result, fullname)>
                  <cfset ArrayAppend(result, userid)>
                  </cfloop>
                  <cfreturn result>
                      </cffunction>
                  </cfcomponent>
                  THE HTML:
                  <cfform>
                  <cfinput type="text"
                          name="fullname"
                          autosuggest="cfc:getname.lookupname({cfautosuggestvalue})">
                  </cfform>
                  • 6. Re: How to use autocomplete to get first and last name from database
                    I am sorry to say, your answer is incorrect.
                    For the autosuggest part, use the ideas in my getFirstName(), in particular
                    <!--- Build one-dimensional result array --->
                    </cfloop>
                    In the second step, after the user is selected, you need to be able to identify her by ID, hence a 2-D array:
                    <cfset ArrayAppend(result[1], userid)>
                    <cfset ArrayAppend(result[2], fullname)>
                    </cfloop>
